Question about Samsung Televison & Video
Zvox popping sounds after 3 minutes. Samsung smart TV
Accuvoice TV Speaker after 3 minutes starts popping real loud
  • 979 Answers
SOURCE: Loud Cracking/Popping Sound
Any other symptoms? You may be just hearing the occasional sound of static being bled off, or, if the set is not working properly, the sound of the high voltage section trying to compensate...accordianman
Posted on Feb 25, 2008
pilot210
  • 39 Answers
SOURCE: on one minute then POP loud noise, burning smell
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
Posted on May 19, 2009
SOURCE: Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Posted on Jul 09, 2009
  • 5 Answers
SOURCE: I have a samsung LE40R87BDX LCD tv which has
It is the capacitors in power supply, samsung have fitted underrated capacitors in some of their models.
Posted on Sep 15, 2010
  • 362 Answers
SOURCE: my Samsung TV has a
its fixable if under warranty also suggested but if you wanna save money use another audio source such as home theater receiver or cheap 2.1 pc speakers with the proper inputs ok hope this helps
Posted on Nov 17, 2010
I have a ZVOX 580 soundbar. Using the digital optic cable I have no sound. I have sound through RCA cables. Can you help?
They to check the menu of the TV is there is any option to activate the Digital out or is there is any setting which allow you make a selection between internal speaker or external speaker. if its there the make the setting as external speaker .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 15, 2016 | ZVOX ZBase 580
Had a loud snap when watching then no power.
TV repair, clicking and will not power on, loud snap, no ...
? 13:57
https://www.youtube.com/watch?v=UKoR7pWAHzk
Nov 25, 2014 - Uploaded by Robert DIY
TV Power board replacement - 30 - 60 minutes ($20 / $110 / $250 / Replacement) This video will show you ...
Samsung LCD 46 Pop! Then Dead! - TV Forums
www.tv-forums.com/...Repair.../Samsung_LCD_46_Pop!_Then_Dead!_...
Nov 23, 2011 - 7 posts - ‎3 authors
While watching TV, I heard a loud pop, then the tv went dead. ... Ok, so I tested the fuses and the main fuse, by the power plug, had no ...
Samsung power defect causes some TVs to fail, and a class ...
www.cnet.com > Home Entertainment
CNETFeb 14, 2012 - A defective capacitor in some Samsung LCD, plasma and DLP TVs is causing the ... The LN-S4051D is one of the TVs Samsung admits has issues ... In a February 9 report entitled "More than 7 million Samsung TVs plagued by possiblepower defect", ..... Today I heard a loud pop and now I have no picture.
Feb 09, 2016 | Samsung Televison & Video
My samsung 65" curved LED SMART TV. MADE A LOUD POP SOUND AND TURNED OFF AND WONT TURN BACK ON?
If it's still under warranty, call Samsung service. They will replace whatever it is that burnt out.
Nov 19, 2015 | Samsung Televison & Video
I need setup code for my zvox sound bar for a Comcast remote?
I am the same boat. Just bought a bigger tv and my zvox doesNOT work now
Jan 26, 2015 | ZVOX 4002201 Audio Z-Base 220 Low-Profile...
ZVOX v-series 320 no sound
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Dec 11, 2014 | Televison & Video
I have a problem with hiss coming from the sound bar (ZBase 550 HSD) when using my digital cable box. It is not an issue with PS3 etc. I have the sound on the cable box turned to max, but I still hear a...
Hello ZVOX Owner,
The hiss you hear is generated by the analog audio output of the cable box. The best way to eliminate this hiss to use the digital output of the cable box. The preferred way to do this is to connect the digital audio output of both your cable box and your PS3 to the your TV (I presume your TV has two digital audio inputs.)
Your TV has a digital audio output. You should connect the digital audio output of your TV to the digital input of the ZVOX.
This should reduce or eliminate the hiss and provide convenient video source selection via the TV.
From Fred P. at www.zvoxaudio.com
fred@zvoxaudio.com
Jan 27, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
Philips tv with sound going in and out
Try bypassing the set's speaker by running an external audio amp. I use my bookcase stereo for audio direct from the satellite receiver and turn the volume off on the TV. Sounds better this way! Could be the audio amp in the TV is going bad or the speaker may be bad and the TV's audio amp goes through a shut down cycle.
Feb 10, 2010 | Philips 30PW850H 30" TV
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
Tv makes a popping sound, then shuts off
its a cold solder. there are some lose connections. resolder all the boards.
May 10, 2009 | Televison & Video
Bose Acoustic Wave music system popping speaker
Had the same problem on the same machine 15 or so years ago...took it to the Bose factory shop in Framingham (or real close )Massachusetts, and they fixed it in 20 minutes...cost around $50...at the time they said it was a real common problem, and an easy fix.
Jan 20, 2009 | Bose Acoustic Wave music system II -...
Open Questions:
Televison & Video Logo
100 people viewed this question
Jerry Greenberg
Jerry Greenberg
