Question about Vacuums
Does it take vacuum bags? - Vacuums
  • kakima Dec 28, 2016
    Hi deborah bastek, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model is "it"?
Bag light wont turn off
Hi there! The vacuum may be still sensing dirt in the cleaner. Try wiping the area down in and around the bag port. Be sure you are replacing the bag with a genuine Hoover Type Q bag. Also, when assembling the bag remember to slide the red bag door lock to the right to lock it on. If the check bag indicator light still comes on there may be an issue with the sensor on the vacuum. We would recommend taking your vacuum in to a Hoover authorized service center for repair. Hope this helps! Service Center Locator
Sep 13, 2014 | Hoover Platinum Collection Upright Vacuum
How do I remove outer bag of oreck vacuum cleaner XL 9000W and how do I clean it? Removable bag broke and outer bag filled up with dirt.
If there is a bag dock on it, seperate large part of bag dock from smaller one, by squeezing bottom of bag dock to release tabs from larger one. Pull smaller part of bag dock apart and off of vacuum. Bag will now release from hole. If there is no bag dock, there is a metal piece around hole that is holding other bag on.
Jul 08, 2014 | Oreck XL Ultra Bagged Upright Vacuum
What does the question mark mean
The question mark means there is no bag in the vacuum.If there is a bag in place, check to see if the bag is covering the bag switch located to the bottom right with the bag door open. Remove the bag that is in it and find the switch. Replace the bag and make sure the cardboard on the bag covers the switch and close the door. The vacuum should run.
If it doesn't run you should take it to a vacuum repair shop that works on Electrolux vacuums.
Jun 29, 2014 | Electrolux Epic 6500 Vacuum
I can't get replacement bags for my Bosch Premium 1300 W vacuum cleaner.
Greetings from GoVacuum,
Your Bosch Premium canister vacuum cleaner uses Bosch Style P Bags.
We carry 2 different types of Bosch Type G bags for your vacuum cleaner.
We have the genuine Bosch Bags Available for Purchase Here;
Bosch Type P MEGAfilt™ Super TEX Vacuum Cleaner Bags
And also in bulk buy here;
3 Pack Bundle Pack of Bosch Style P Vacuum Cleaner Bags Part #BBZ52AFP2U
And we also carry a generic paper style bag that doesn't filter as well as the cloth Bosch genuine bags, but is suitable if you don't have any breathing issues or allergies in your home. Here are the Bosch generic P bags;
Bosch Type "P" Canister Vacuum Bags Generic
I hope that this information was helpful to you. If this helped you, please be sure to rate this as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of my answer.
Feel free to email me at if you have any questions or need further help with your Bosch canister vacuum.
Thank you so much,
Chris Jones
Feb 22, 2010 | Bosch BSG81313UC Premium Bagged Canister...
Need vacuum cleaner bags for euro pro ep055
Needed bags for this vacuum and FINALLY found them at Ten bags and two filters for $10.95 plus shipping. Hope this does it for you and anyone needing bags for this vacuum.
Dec 12, 2008 | Euro-Pro EP055 Bagged Canister Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
