My Dr 966 commercial heater got hot and warning light came on! We unplugged as it said to overnight and is now cold and warning blight is still on??? Is it safe????
NO HEAT. A/C works fine. Air blows but no warmth. blows cold air for front defog and cold air blows when temp cranked high 1-5
warmth comes from the heater in the car
if it is climate control check the climate control module
check for heater control in the vent settings as the hot water tap may not be turning on
Sep 20, 2015 | Pontiac Grand Prix Cars & Trucks
Since installing Rinnai RC80i tankless water heater, the performance of the dishwasher has diminished. The dishes aren't getting clean. I suspect the water temperature is not hot enough. The thermostat is...
follow this steps and fix it. God bless you
Drain a tank:
  1. Shut off power at the electrical service panel and post a sign warning others not to turn it on.
  2. Close the cold-water supply valve and open a hot-water faucet somewhere in the house (to speed draining).
  3. Attach a garden hose to the drain valve and run it outside the house.
  4. Open the drain valve and allow all water to drain out.
  5. To refill the tank, close the drain valve tightly and open the cold-water supply valve. Also open a nearby hot-water faucet. When a steady stream of water flows from that faucet, the tank is full and the faucet can be closed.
  6. Once the tank is full, turn the electrical power back on
Test and replace a heating element:
  1. Turn off power at the electrical service panel and post a sign warning others not to turn it on.
  2. Remove the access panel on the electric water heater.
  3. Disconnect one of the element wires and set a multimeter to RX1000 (resistance times 1,000). Touch one probe to an element mounting bolt and the other to each element terminal screw, in turn. If the tester displays anything but infinity ( open circuit), replace the element.
  4. If necessary, set the multimeter to RX1 and touch the probes to the terminal screws. If there is any resistance reading at all ( closed circuit), then the element is good. If not, replace it. Both upper and lower elements are tested in the same manner.
  5. To remove the element, first drain the heater.
  6. Disconnect the remaining element wire. Remove the mounting bolts holding the element in place. Remove the element.
  7. Replace the heating element with one of the same model, shape, and rating. Make sure you also replace any installation gaskets.
Test and replace a high-limit cutoff:
  1. Disconnect power to the heater at the electrical service panel and post a sign warning others not to turn it on.
  2. Remove the upper access panel and push the reset button.
  3. Replace the access panel and turn the power back on. If the water is hot, the reset was the problem. If not, you'll need to turn the power off again and reopen the access panel.
  4. Use a multimeter to test the cutoff terminals for continuity. If faulty, replace with an exact replacement part.
Oct 20, 2013 | Rinnai MCC-91-2W Commercial Remote...
Samsung snack mate commercial cm1069 comes on when you open the door!!
John,
I have noticed the same...however, I placed a glass of cold water inside the microwave and opened the door a little and stood back whilst the light and fan still on..... Hey presto much to my amazement the water was still cold. So, this light and fan issue with the timer not descending is not a health & safety issue its just the light letting see and the fan extracting thus helping you use the microwave safely.
Mar 19, 2013 | Microwave Ovens
My 99 monte carlo z34 Low coolant light comes on occasionally car almost overheats and than just bounces between mid temp to bout three quarter temp and is blowing cold air
For car running hot and overheating issues, I suggest to you go through this help links.
Click this link below and go through the troubleshooting procedure to take care of the problems: ----
Car runs hot?
http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?
http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
overheating?
http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 25, 2012 | 1999 Chevrolet Monte Carlo
I have a 2004 Dodge Stratus, the car could be cold and the temp reads right in the middle and the fan is on. When I drive it, the temp gauge goes to hot and the temp light goes on. Radiator is full,...
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
Feb 10, 2012 | 2002 Dodge Intrepid
2005 chevy impala overheat light comes on, the car was shaking when I started it and cold air when idling but when given a little gas the car starts blowing out hot air what do you think it might be?
Feb 01, 2012 | 2005 Chevrolet Impala
Overheating
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Jan 30, 2012 | 2003 Chrysler PT Cruiser
I have a 2002 Olds Alero GL my heater is not working and car overheats peoriodically losing antifreeze, please help freezing in Montana
Engine Overheats and heater blowing cold? http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Jan 20, 2012 | 2002 Oldsmobile Alero
Teperature gauge running hot and heater not working
If the car is hot and the heater blows cold air your thermostat is stuck shut or your radiator is really low on water/antifreeze check when engine is cold hasn't been ran like overnight take off the radiator cap and if it is low add so antifreeze/water if heater still blows cold air or water level is ok your thermostat is stuck shut and needs to be replaced.
Apr 08, 2010 | 2004 Hyundai Elantra
Cold wash
Hi if this intended to be used in a commercial environment then it will need to be hot and cold water supplied as commercial machines do not have heaters! I can tell you for sure if you give me the exact model number..
Dec 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
