Question about Building Materials
My Dr 966 garage heater is cold and the warning button keeps flashing????
2 Suggested Answers
  • 1420 Answers
SOURCE: I have a rinnai energysaver
It is telling you that there is an error code stored in the EPROM. Press and hold the Economy button and the Up and Down arrows for 5 seconds. Get ready to tell an assistant the codes as they pop up. You may have to do this a few times to get them all. Repost the error codes here on Fixya if you don''t have an owners manual to interpret the codes.
Posted on Feb 25, 2011
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
Dell photo 966 streaked copies
Turn off the printer and open its front cover.
Press and hold the "Continue" button. While holding it down, turn the printer on. The power LED light will now start flashing. Once it stops flashing, release the "Continue" button and close the front cover.
Press the "Cancel" button four times in a row.
Press and hold the "Continue" button. The front panel lights will now start flashing. When they stop, release the button.
Turn the printer off and then turn it on again
Mercedes Custom Parts
Jun 06, 2012 | Dell Photo 966 All In One Print Copy Fax
I have a PRO100 Reddy Heater would not stay lit when you release the ignite button. I replaced the thermocouple and it did nothing. What else could be the problem besides the valve?
I had the same problem. Heater was propane with a long hose for movement.
I put the heater on my garage work bench and the thermocouple tested okay.
Tried to restart and it ran like a champ. Reassembled bottom panel, retested great.
When I set it on the floor, it went out! Hmmmm.
Restarted back on the benck. Great. No good on floor....Very cold (28 F) in the garage.
Think the propane might be going liquid in the hose...when heater hose has a "drip loop"
it works fine.
Maybe this is nuts, but it works keeping the heater up a bit on a STABLE surface.
Dec 17, 2010 | Reddy Heater RLP100 Portable Forced Air...
The fuel heater light on my xtype started flashing and the ABS lights. After a few more short journeys the ignition engine warning light is now on and staying on . I've also noticed a loss of power and...
I had a very similar problem (did not have the abs light) but had the other lights. Changed fuel filter as the problem seemed to be a fuel pressure problem. Turbo was back and no flashing heater light, engine light will go out after about three cold to hot starts as long as no other problem exists. It's worth a try as it is a cheap and relatively easy repaire to do. If not the answer take to a garage who can interrogate the computer.
Oct 06, 2010 | 2002 Jaguar X-Type
Lennox lf24 garage heater, starts then shuts down.
Here is a link to the manual for your unit heater:
The 4 flashes is a high limit or roll out switch is open. There are 2 or 3 little brown or black button looking switches with a little button on the top and a wire attached to each side. Press the button on each, you may hear a slight "click". If you do, that is the one that was open. Hope this helps.
Oct 31, 2009 | Heating & Cooling
Garage kit (heater)to install on kenmore ref. #106 5155 102 to operate in unheated gagage instructions in step 4 says to unplug 2 wires from cold control orange - black ..plug orange lead to orange heater...
The kit should just be a heater that piggy backs off the 2 wires going to your cold controle or thermostat. orange and black go back on the cold control with the heater piggy backed. The kit heats the cold control to make it think its warmer in the room or box than it is so it will run long enough to keep frezer frozen.
Oct 31, 2009 | Refrigerators
Sear garage door wall mount contol light keeps blinking
One of the buttons has a lock icon. Hold that button in for 3 seconds.
May 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Heater won't refire after it warms up
CAD flame sensor is bad, 3$ part and easy to install.
Jan 22, 2009 | Reddy Heating & Cooling
A few questions...
Does the remote work very close to the garage, but not farther away - If so, then likely IS a battery problem....
Is the weather very cold where you live? - battery strength diminished quite a bit in the cold (try keeping the remote indoors for awhile & see what the results are). Also could be moisture in your unit - keep it inside & on a warm ( but NOT HOT ) surface for a day or 2
Did you get a good battery with an indicated shelf-life that is a couple of years into the future? (some 'dollar store' batteries are not very good). Also Alkaline batteries (if permitted by the user manual) are quite a bit more powerful than even the 'heavy duty' batteries of the same brand.
Finally, Is your unit at the garage powered electrically, or is it a battery also? If the garage portion is battery operated, try replacing that battery (in your receiving unit).
Hope at least 1 of these ideas helps...
Jan 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
54 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
