Question about Nokia 6300 Cellular Phone
I just purchased a new 6300 . when i try to retreive ring tones from micro sd ard it tells me there is no valid activation key available . can you please help me ?
    Problem Solver:
  • 12 Answers
Try restoring your phone settings to default and then retry selecting yopur ringtones from your micro sd card.
Posted on Jul 21, 2009
I WANT TO FORMAT AND ISTALL WINDOWS XP...BUT THE PROBLEM IS THE PRODUCT KEY IS NOT VALID..I'VE TRIED SO MANY TIMES.......PLS HELP ME ASAP....THANK YOU...IBM R40 THINKPAD
I am not sure that a product key is available anymore for XP from Windows. You may have to purchase a new copy of XP with a valid key.
Dec 27, 2010 | IBM ThinkPad R40 2723 Notebook
I bought a 4Gigabyte Micro SD card for my Nokia 6300 and i put it into the Micro SD card slot. When i turned on my phone i went into gallery and there was no folder called Memory Card. I'm not sure if it...
hope you still have the receipt (take it back to store and tell them you picked up the wrong card, you need a 2gb) 2 gigs is the max for this cell
Nov 13, 2010 | Nokia 6300 Cellular Phone
Nokia 6300 has stopped ringing anyone any ideas?
o.k. does it vibrate?
have you dropped it?
You may have accidentally put it on silent mode:
HERE IS HOW TO CHECK YOUR TONES OR PROFILE:
10. Settings
Profiles
Your phone has various setting groups called profiles, which you can customize with
ringing tones for different events and environments.
Select Menu > Settings > Profiles, the desired profile, and from the following
options:
● Activate — to activate the selected profile
● Personalise — to change the profile settings
● Timed — to set the profile to be active until an end time. When the time set for the
profile expires, the previous profile that was not timed becomes active.
Themes
A theme contains elements for personalizing your phone.
Select Menu > Settings > Themes and from the following options:
● Select theme — Open the Themes folder, and select a theme.
● Theme downloads — Open a list of links to download more themes.
Tones
You can change the tone settings of the selected active profile.
Select Menu > Settings > Tones. You can find the same settings in the Profiles menu.
If you select the highest ringing
all this can be found in your manual:
here is a link to the manual for: nokia 6300
please remember to rate my help if it was of assistance it helps me too.
Mar 26, 2010 | Nokia 6300 Cellular Phone
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
My new SciPhone i68 does not recognize the memory card.
when i put my micro sd into my sci phone and then go to documents it is not there it says just the phone memory. how do i format the memory card to my phone or even to get it to work ?
Feb 22, 2010 | Computers & Internet
I've just bought a new Uni take and talk Nokia
there are two cradles available for the 6300, one has two connectors should work when you put the phone in the cradle and switch on the key, the other has one connector and is bluetooth, this requires pairing, you will need to search for bluetooth devices and pair using code 1234. The use of steering wheel controls is not possible with bury car kit. hope this helps. dan
Nov 20, 2009 | 2007 BMW 525xi Sedan
Unlock micro sd 1gb
hi,
first try to put the same code/password as of your old phone if it will work then good
otherwise
try to unlock with the new phone code.
if none of them work
then format the card from pc and format using FAT not FAT 32.
this will solve your problem.
Mar 24, 2009 | Nokia N95 Cellular Phone
My phone NOKIA 6300 could not find micro SD card. please what do i do?
If it is a 4GB micro SD card it won't work, a nokia 6300 doesn't accept HC (high Capacity) micro SD cards. Maximum you can use is a 2 GB micro SD card.
Don't forget to rate, thks
Oct 28, 2008 | Samsung SGH-D900 Cellular Phone
Micro sd unlock (6300)
I having 1 GB micro sd memory card for my mobile nokia 6300 and it is password protected.i have forgotton the password. can u plz solve my problem
Jun 29, 2008 | Nokia 6300 Cellular Phone
Ringtones
There are two types to get you many ringtones- the first is by
bluetooth,need two phone and on the bluetooth both phones
send the ringtone first phone to second phone.
AND the second formula is-- by nokia.com you will purchase from this site.
Feb 21, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
66 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
