Question about Sewing Machines
Raising the feed dogs from underside of machine 758 touch and sew
  • Sewing Machines Master
  • 10,291 Answers
Not sure what you are asking, but here's the manual:
Singer Touch Sew 758 Instructions Manual
Posted on Dec 27, 2016
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
Feed dog will not pull thread through model 758
Difficult to understand the question. Feed dogs pull the fabric through the machine. Feed dogs have very little, if anything, to do with how the thread moves in the machine other than determine the length of the stitches the machine makes.
Jun 27, 2017 | Sewing Machines
Does singer model 758 have a feed dog?
Yes, the vast majority of sewing machines have feed dogs. That is how the fabric is pulled through the machine to produce the line of stitching.
Jun 27, 2017 | Singer Sewing Machines
The feed on my Singer 538 will not pull my fabric thru. Help appreciated.
Without fabric in your machine and with the presser foot raised, do the feed dogs move front->back? Are the feed dogs in the raised position? Is the stitch length at a 10-12 stitch per inch setting so that the fabric actually moves (try increasing the stitch length to see if it makes a difference)?
Does your machine have a presser foot pressure adjustment? If you are sewing light weight fabric, the pressure may need to increased so there is more pressure applied by the presser foot to the feed dogs. You can also try adding a strip of tear-away or wash-away stabilizer to the underside of the fabric as you stitch so the feed dogs have something to grip.
Are the tips of the feed dogs rounded? Could be worn and need replacement.
If the feed dogs are not moving, how long has it been since the machine was cleaned and oiled?
It was working now it seems to be frozen the needle part wont move
If the feed dogs remain below the needle plate, and the feed dog lever does not activate them, then perhaps something is disconnected in the feed dog mechanism. The feed dogs should rise when stitching begins.
Feb 07, 2016 | Singer Sewing Machines
I have a singer touch & see sewing machine, I need to change for quilting but there are no visible switches to lower the metal times under the foot.CAN ANYONE HELP I'M ON A DEAD LINE. THANKS,
I don't know this machine but in most machines the feed dogs are normally lowered from a switch beside the bobbin case behind the door of the bobbin case.
Jun 14, 2015 | Singer Sewing Machines
How do i raise the feed dogs on my singer 30215 machine
Slide of the the little table with the accessories in.There is a feed dog adjustment lever at the back of the machine. sliding the lever to the 2 filled in arrows pointing down, will lower them and the 2 filled in arrows pointing up will raise them. The feed dogs will not rise up if you do not turn the hand wheel manually, even if the lever is slid to the right.You must make a complete turn of the wheel to raise the feed dogs.
Best wishes.
Jun 29, 2014 | Euro-Pro Shark 9110 Sewing Machine
Singer 758 model and the material is not feeding through the machine. Needle is only going up and down in one spot.
here is a link for a free manual, check to see if the feed dog lever is up in the sewing position, if the feed dog lever is down then try to raise it up. if it will not raise then the machine needs to be check to see what's wrong with the feed dog.
http://www.singerco.com/uploads/download/6dc4cd61b0c61a5fc13e60785f01d29199328059.pdf
Nov 18, 2013 | Singer Sewing Machines
Can't raise the feed dog on Quantum XL 1000
If I remember correctly you have to raise the feed dog then turn the fly wheel 1 revolution to lock them in place
Feb 07, 2013 | Singer Quantum XL-1000 Computerized Sewing...
Feed dogs will not raise, I have lifted the presser foot, pushed the feed dog lever to the raised positon and turned the handwheel till i heard the click. They still will not snap into place in the raissed...
Hello
First, lift the presser foot; next, push the feed dog lever to the raised position; finally, turn the handwheel towards you until you hear the feed dogs snap into place
If it doesn't, you will have to run a maintenance check on your feed dogs,
Unplug the machine and examine the feed dogs. The newer machines have metal feed dogs, but older models may have rubber ones, which often need replacing. Examine the feed dogs and check for damage.
Remove the throat plate, which is the covering over the feed dogs, and clean it with a soft cloth. Use a small soft brush to clean the feed dogs. Make sure to remove all lint and thread from the grooves of the teeth. Some machines have an adjustment that lowers the feed dogs for specific sewing procedures. They should be in the raised position for better viewing during the cleaning process.
Clean the area around the feed dogs with a soft brush. Compressed air is a good choice to use in the small tight areas.
Wipe down all areas with a clean, lint free cloth before replacing the throat plate.
Prepare to clean the feed dogs and all other areas that lint may accumulate on, after every project. Your sewing machine will last longer and need fewer repairs if kept clean and lint free.
Always unplug the sewing machine before any type of maintenance or cleaning.
Never use a sharp tool when cleaning the feed dogs as this may cause damage to the sewing machine.
Apr 16, 2011 | Singer 7436 - INGENUITY
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
