Question about AEG Ovens
We have a fault with our aeg oven bp5013001m error appears on front panel f908 could someone help us with what is wrong
5 Suggested Answers
SOURCE: AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
Posted on Sep 15, 2008
SOURCE: Wiring Diagram for AEG Build-in Electric Oven B2.6L
can i use 13amp socket for a electric oven
Posted on Oct 25, 2008
  • 906 Answers
SOURCE: U1452 - power lost to both ovens and front panel.
good day,
hope this link below will solve your problem.
ovens
Posted on Aug 03, 2010
SOURCE: AEG U7101-4-M Bottom oven not working
had same fault its a temperature switch at back of oven, you have to remove panel and is located half way up on left and has two spade terminals coming out the back.
Posted on Mar 02, 2011
F908 ERROR CODE
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please provide model number and also the condition when this error occurs. Can you operate the oven after this fault occurs. Try to turn off the mains power and check after turning back on.
Jul 31, 2014 | Zanussi Ovens
The oven has an earthing fault. We suspect an
A commoin fault is for the main oven element to fail.
Try disconnecting it and see if the earth fault disappears.
Jun 16, 2010 | AEG D4101-4 Electric Double Oven
Zanucci Electrical fault. Oven cuts out and fO8
Is the model number correct. ZBF360X.
Anyway the error code fo8 normally relates to a faulty Tangential Fan.(Cooling Fan),which can be found on teh top of the cooker behind the control panel and it is there to cool said panel.
Hope this helps.
May 24, 2010 | Zanussi ZBF360X Electric Single Oven
OVEN WILL NOT OPERATE
F4 is a fault with the temperature sensor for the oven which normally will need replacing.Hope this helps.
May 08, 2010 | AEG B5741-4 Electric Single Oven
I have an AEG Electrolux oven D8800-4 double oven and have ann error code A3, what does this mean?
I hope you mean error code F3. if so then that means a software error and if you disconnect from mains supply then reconnect this should reset the fault if that does not work you may have a damaged circuit board.
Hope I helped.
May 06, 2010 | Electrolux Ovens
Aeg oven d4100 cutting out
There is a cooling fan in the cabinet of the oven which is not working either the fan is faulty or the controling cut in stat is, The fan should run when the grill is selected if does not it is more likely to be the fan/motor at fault.
Dec 07, 2009 | AEG D2100-4 Electric Double Oven
Oct 28, 2009 | AEG U7101-4 Electric Double Oven
Aeg b4101 single oven ,three years od
Sounds like a faulty thermostat.You will need a new one
Nov 07, 2008 | AEG B1180-4 Electric Single Oven
Jan 04, 2008 | Ovens
Nov 04, 2007 | Ovens
Ovens Logo
42 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
