Question about Nordic Track Exercise & Fitness
I have a nordic track a 2050 and when you go to push the speed up button it jumps to 1 mile an hour and then shuts off immediately what do you think is the problem
  • Nordic Track Master
  • 6,694 Answers
The motor controller board is faulty.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 28, 2016
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Posted on Feb 28, 2010
  • 218 Answers
SOURCE: Nordic Track Elite Pro 9500
the motor controller needs replaced
Posted on Aug 11, 2010
  • 218 Answers
SOURCE: Hello, I have a Nordic Track 2050, and got on this
console is bad no other alternative, check ebay for part
ercupa190
  • 12223 Answers
SOURCE: My Nordic track a2350 speed is not working when
Run the software calibration for easy diagnostic and fix it.
Under the Hood motor there are instruction or follow the manual.
God bless you
Posted on Jun 14, 2013
I hav an a2105 nordic track.. it powers up just fine but when i start the track it starts and shuts down.. and then powers itself back up all over again.. i disconnected the drive belt from the motor to...
hi,
You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will try to run without setting any value or witout pressing the start button. You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i ahve added the picture of IGBT for your refference
ok
Aug 14, 2011 | Nordic Track NordicTrack Treadmill, A2550
When I push to go say, 3mph it says i'm going 5 mph. So i'm worried that my miles are off and i'm training for a 1/2 marathon so it's important to go the right miles
ensure that no setting has been changed to kilometers per hour.
there is about 1.6 miles to one Kilometer this might be the reason for showing slightly different.
check and reset to Miles.
I hope this was helpful
Jan 11, 2011 | Nordic Track NordicTrack Treadmill, A2550
My treadmill is telling me the wrong amount of calories burned and the wrong speed at which I am traveling. For example, I hit the button that says 6 mph, but the treadmill says I am running at 9.7 mph....
I had the same problem with my Nordic Track. I had somehow changed the display to metric readings.
Solution: Hold the stop button down while inserting the key, push the speed up or down button to change it back to english, remove key and you are good to go. Re insert the key and it should work fine. Hope this helps.
Nov 27, 2010 | Nordic Track Nordictrack Adventurer...
The Nordic Track machine's controls seem to be stuck. If I press any button other than "3 mph", it fails to respond and nothing happens. However, when I press the 3 mph button, it will only stay at the 3...
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Jul 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
My question is, last night, I set the speed to 5mile/hr, the treadmill automatically stopped after 12mins( the belt stop, power was on). and I can not restart it immediately, Then after 5 mins, the belt...
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Jul 08, 2010 | Nordic Track /proform Treadmill...
Jul 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
Feb 27, 2010 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
