Question about Cell Phones
Not keeping a charge Only works for about 5 to 10 minutes per charge.
    Top Expert:
  • Cell Phones Master
  • 40,567 Answers
The battery may be exhausted and unable to recharge completely.
Posted on Dec 27, 2016
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Zeepad still freezing i want to keep it, i just followed instructs in box, charged it, held power down for three minutes, and now recharging for two hrs. any tips, i don't like returning things i purc
Upon first use, you have to charge the battery overnight. Then for every recharge, you may have to keep it connected to the charger for at least 4 to 6 hours depending on your tablet, otherwise, your battery will go kaputt in a short period of time.
Mar 12, 2014 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
My battery keeps dying within 3 hours of taking it of the charger
I've found using the internet even briefly KILLS your batterys, especially if you do anything that requires streaming data (ie, youtube, streaming radio).
For instance, I listened to SomaFM streaming radio for about 10-15 minutes the other day (without headphones), and the battery went down 10% in that amount of time. You're basically talking 1% per minute when streamin audio. All I know is once this thing becomes a little more capable with streaming, I'm going to need to get a spare battery or bring my charger to work and just keep it plugged in.
Even worse is watching Youtube. I had a bit of downtime at work and watched 3-4 Bill Maher clips on youtube (this time with headphones). Over a period of 20-30 minutes, my battery went from 85-95% to 25%. It basically kills your battery, so be carefuly with youtube.
When I use my call normally for texts, emails, and calls it seems to hold a charge no problem. Especially when I consider that my brand new FULLY-charged laptop only lasts about 2 hours when
I'm using it for browsing the web.
You could also try disabling Pocketday.
Jan 29, 2011 | RIM BlackBerry Curve 8520 Smartphone
I refilled my go phone account with 15 dollor plan and unlimited messages today. I am keep getting notifications on my phone saying that the last transaction I made for I was charged one cent although I...
Check your balance whether it is decreasing ...
It may not be unlimited plan ..You will be getting messages for $15 at one cent per message...
Sep 16, 2010 | Cell Phones
I have a free cellular phone and the minutes are in dollar amounts. Do you have information on how many minutes $30.34 would convert to in minutes
That depends on what service provider you are using. For instance, if it were AT&T, they charge $1 per day and $0.10 per minute. The $1 per day is only charged if you use the phone that day. Text messages are usually charged at $0.20/msg that includes outgoing and incoming.
May 17, 2010 | Kyocera K132 Cellular Phone
Phone won't charge or turn on
it seems you have not charged your cell for initial 24 hrs and used the mobile as per the policy of every mobile company. Anyway, switch off your mobile and keep it on charging for next 24 hrs. In case it doesnot works after that also, go for replacement with the vendor.
Jun 15, 2009 | Sanyo Katana Eclipse X Cell Phone
Mower will not start will make clicking noise. did start at for one minute
Your battery is dead. Replace it.
In the winter keep a smart trickle charger on the battery to prevent it from discharging. Lead/acid batteries lose 1% of their charge per day and are basically junk in 3 months. They have to be kept charged.
May 04, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Low battery
You need to buy new batteries for your phones. Large retailers charge $10-12 per battery but you can usually find them for closer to $4 online at or eBay.
Jun 22, 2008 | Vtech 9009111 Cordless Phone
Viper MSNV-939 ATX Socket 939 audio connector jumper settings
 u short the pins with jumpers as per the diag
        5    4     3    2    1
       10          8     7    6
in this u short the   5,10  with one jumper &   3,8 wth another jumper
was this helpful to u, give the rating for me
Oct 15, 2007 | Mach Speed (S755) Motherboard
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
