Question about RCA Audio Players & Recorders
RCA cd drawer won't open disc off RS3765B - RCA Audio Players & Recorders
SOURCE: toshiba sd-3990 Disc-drawer won't open
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
Posted on Oct 07, 2008
  • 35 Answers
SOURCE: cd spins buts doesn't play I fixed the drawer open closing
Clean the lens of the laser with a cotton swab. Remove the cover, and locate the glass lens at the top of the laser assembly. Pre-wet a cotton swab with glass cleaner and wipe the lens carefully without applying pressure. Use the other end of the swab to dry off and remove any residual dust or gunk.
Reassemble the unit and load a disc. If the problem was caused by dust or smog film on the lens, it should now play without any problem.
Posted on Mar 02, 2009
SOURCE: Hi, my cd drawer on my ucd 100 dosen't open and it
same problem with my dads UCD 100. the problem is the motor is going and the latch spring in now too tight to release. to resolve replce the motor, but temporary solution is to stretch the spring a bit and that should allow the release. you might need to pull it out a bit once it comes out to lock it off otherwise it might slide back in.
hope this helps.
Posted on Dec 23, 2009
There were 2 problems that I found with my daughter's rs2654, which wouldn't open. The first is that a 2.2 ohm resistor opened up near the IC that drives the motor that opens the drawer, so no voltage to the moter. The second was that the grease in the gears was so stiff that the motor barely turned the larger pulley. Changing the resistor and cleaning up and regreasing the gears fixed it.
Posted on May 20, 2010
  • 6771 Answers
SOURCE: my jvc compact component system cd drawer won't open
The loading belt is broken, or the gears are jammed and locked down, either way a major dis-assembly will be required to attempt repair.
Posted on Mar 28, 2012
RCA 5 disc changer MOD@ RS2767iFE drawer want open
Mechanical fault. Contact any service technician to get it repaired. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 22, 2016 | RCA Audio Players & Recorders
Rca rs2767i
You have a mechanical or electrical problem(related to the drawer motor). For more information, please visit my website at Thank you.
Dec 12, 2013 | Audio Players & Recorders
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
How to turn on rca cd player
1. Press 'SOURCE' repetedely to select 'CD' mode.
2. Press "Open/Close" button to open the drawer.
3. Insert disce and press 'Open/Close' again, and the inserted CD will play automatically. OK.
Jul 29, 2011 | RCA RS2635 CD Shelf System
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
Disc drawer won't open and sometimes doesn't power off
The disc drawer is broken, there are motors that open the drawer (what you hear when turned on and off) and it must of got damaged by a cd or some other way. If you want to open it, pry it open with your fingers or screwdriver. I had to take the 5 cd holders out to see the problem and there was a cd that jammed everything. But you might not have that, take a look. And the "bye bye" thing is normal but not if it wont go off at all.
Oct 06, 2009 | RCA RTD207 System
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
56 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
