Question about Health & Beauty
Jazzy 1103 VSI lights flash but chair won't move but will lift and lower
dromtonpa
  • 40 Answers
SOURCE: problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Posted on Apr 01, 2009
dromtonpa
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
  • 4 Answers
SOURCE: my jazzy 1115 joystick controller flashing and the
look on jazzy web site for lockout procedures.I have seen people accidentally engage the lockout thru the joystick.It is a simple procedure
Posted on Nov 21, 2009
HoverTech
  • 232 Answers
SOURCE: chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
The speed lights keep flashing. It still moves.
The speed light flashing usually indicate that the chair is in "Limp Mode" This could be either the motor is getting too hot or the chair has a lift on the seat. If the chair runs fine for a while and then this condition appears, you may have a bad motor or a brake dragging causing the motor to get hot. the controller will allow less power to the motors to help it cool down and still keep you mobile. If you have a lift on the chair that raises up the chair, you will have to lower the chair down to gain the full power back. If neither one of these solutions are the problem, then you will need a Tech to come out and look at the problem. you may have a more serious problem that a tech can troubleshoot.
May 11, 2015 | Pride Jazzy 1103 Ultra Standard Power...
How do you reset the chair when all the lights are flashing?
Hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
May 30, 2014 | Pride Jazzy 1103 Ultra Standard Power...
Jet 7 vsi controller shows no green lights, nothing flashing?
Make sure the controller cable is fully seated in the chair. The service manual from Pride's website will have detailed information in it. You can freely download it.
Mar 23, 2014 | Pride Jazzy 1103 Ultra Standard Power...
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
When i turn my chair on the joystick lights are all flashing like when it's plugged in. what does this mean?
The first thing you should do is to narrow down the problem you are experiencing, If the flash code looks like the flash code for the charger plugged in check to verify this at the following link:
You either have a VSI controller or remote plus joystick with the Jazzy 1103 Ultra.
If you have an off-board charger unplug the charger and turn the chair off and on to clear the error code. If you have an on-board charger that is inhibiting the chair from driving you need to unplug it in the rear electronics area to see if that clears the error. If you have tracked the problem to the charger or charger wiring it is a matter of replacing that component. If you need further help after these initial steps I can provide more specific information if you post again. Hope this helps.
Nov 26, 2010 | Pride Jazzy 1103 Ultra Standard Power...
My chair wont move the lite diplay shows 7 lights the joy stick feels like it is out of the sosket
If you have a vsi joystick seven bars means there is a possible joystick trip
a joystick trip is indicated . Make sure the joystick is in the center postion before switching on the VSI.
It may also be locked try this.
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
Oct 08, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Re: Pride Jazzy 1103 Ultra. Chair is acting like the seat is still elevated and the speed is set to slow (with indicator light flashing). Please let me know what should I be checking?
When the power seat lift lowers down, there is usually a bracket that pushes a button under the seat that tells the motor the seat is lowered and the power chair is safe to operate. Sometimes the bracket can get bent and the button does not get pressed when the seat goes down. Check under the seat around the seat post for the button and make sure the bracket is connecting to it. Carefully bend it back into place if it is not hitting the button properly. If the bracket came off, it will need to be replaced.
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
It just flashes all the time when it's on and won't move. pride 7. what error do you get when the joystick goes bad? can I replace the joystick myself?
These are called VSI error lights. The VSI is the fancy name for your electronic controller. [Basically the joystick :) ] The number of times they are flashing, gives you the codes of the problem. The system locks until it is sorted to prevent injury. Follow the link below for the User Manual for your model. First check page 37 to see if it isn't just locked, then page 38 for code meanings. If its flashing lots, most of those high numbered ones are just a case of checking things are all plugged in tight.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Jazzy%201103%20Ultra%20Owner%27s%20Manual.pdf
Hope this helps.
Apr 29, 2010 | Pride Jazzy 1103 Ultra Standard Power...
The power lift seat on my wife's Jazzy 1103 Ultra won't actuate.
most actuator motors have an in-line fuse, I think the one for pride 1103 is located under the cover at rear of chair or close to actuator motor
Mar 15, 2009 | Select Jazzy Used Electric Wheelchair
Health & Beauty Logo
61 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
