Question about Dishwashers
Power lead has come out of my trinity bendix dishwasher DH103. How do I reattach it please?
3 leads coming out of main power lead with plastic attachments on them
  • 78 Answers
SOURCE: Having problems fitting Panasonic CQ-C1323NW car stereo into Ford Fiesta
YOU SHOULD HAVE TWO LEADS IN THE CAR, ONE FOR POWER AND ONE FOR SPEAKERS, YOU WILL NEED A FORD TO ISO ADAPTOR LEAD AND THEN YOU WILL NEED THE LEAD WHICH CONNECTS TO THE PANASONIC RADIO
Posted on Dec 06, 2007
  • 26 Answers
SOURCE: Reattach Power LED, Power SW, and HDD LED leads
go to the manafacturer website, there should be plans for the motherboard somewhere on there
Posted on Nov 24, 2008
Democritus
  • 120 Answers
Try page 18 of this manual:
http://static.tigerdirect.com/pdf/ECS_ECS%20915G-M_Manual.pdf
Posted on Nov 28, 2008
  • 86 Answers
SOURCE: MAINS ELECTRICITY FUSE TRIPS WHEN DISHWASHER TURNED ON
Hi, I think you will need to check the heater or the wash pump, as these are the first things to energised. IOf yo could give me some more information then i could tell you where to after these things have been tested ok!
Get back to me......
Posted on Jan 10, 2009
  • 45 Answers
SOURCE: Iomega Minimax HD, no power but lead light is on
In your situation I would :
open the minimax enclosure, and take the hd out, (just open the enclosure, not the hd itself), and then open your desktop and connect this hd as slave (I am guessing you have a desktop with IDE hd and that the minimax has an IDE hard drive in it.... or both your desktop and the minimax has SATA hard drives) and then when you turn on your computer you should be able to see your second hd as a partition and be able to see the info in there, yet if windows does not recognize it, that means your hd is useless., yet remember you have to change the pin on your external hd to be slave or auto detect, if you let it as master your computer won't boot, bout do not worry, after you unpluges the hd from your desktop everything will be normal
p.d.
shutdown and unpluged the power cord from your desktop when adding/removing the hd.
Posted on Apr 19, 2009
Display light ( 3 nos. ) are flashing & can not running.
make this test and fix it. Merry Christmas.
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check the 120 volts in p. box.
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi-limit fuse
Door Switch
This is the second place to look. Again an inexpensive easy fix. The power comes into the main power box and usually runs to the door switch next before entering the main control module. Replace the door switch if is faulty, use the Multimeter
Main Control Module / Timer
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the main control modul l/timer this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor Make sure the the motor is having power 120v
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace.
Dec 19, 2013 | Meiko DV80.2 High Temp Door Type...
Whirlpool dishwasher du1055xtvqo lights flashing
please see this causes and use the common sense. God bless you
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check for 120 volt at the power box.
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi limit fuse.
Door Switch
This is the second place to look. Again an inexpensive easy fix. The following video will walk you thru checking the door switch. The power comes into the main power box and usually runs to the door switch next before entering the main control module.
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the control module, this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor. Make sure the motor is recieving power.
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace. We have video and tutorials that cover several style
Sep 19, 2012 | Whirlpool Dishwashers
My washing machine wont turn on, it is plugged into an extension lead which also supplies the power for my dishwasher. the dishwasher works fine but the washing machine wont turn on at all, the lights...
It is nothing to do with the extension lead you are using, sounds more like a board problem to me, or another fault causing the lights to flash.
Jan 03, 2011 | Washing Machines
The power cord in my install kit for the Kenmore 1344 dishwasher, isnt color coded. The power cord is 3 leads of course but the manual says nothing about which lead to connect to the color coded wires...
It does not matter what lead goes to the white or the black. You just need to make sure that you have the ground in the right place. If it is a flat cord then the center wire is the ground and if it really matters the lead on the right of the ground is the hot/black.
May 07, 2010 | Kenmore Dishwashers
Hi I have a hotpoint washing machine model wt761 and it has stopped working ,no display no power ,nothing ,ive changed the fuze in the plug but to no avail, please help .
possibly mains lead you need to check there power coming out from mains filter the other end of lead-if not you can purchase a lead complete
Nov 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wiring a STARTER I A 87 SUBURBAN
I presume the two leads you mention are:-
a) very heavy main +12V power lead from the battery terminal with approx 3/8" eyelug terminal,
b) less heavy wire that connects battery power to main vehicle fusebox for power distrubution- this cable may incorporate a fusible link.
The two leads (as above) connect onto the same heavy duty 3/8" terminal on the starter motor.
The lower 3/8" power post (closest to the motor housing) connects only to the starter motor and should not normally be tampered with.
There should be one more light duty wire that operates the starter motor engage solenoid .- This is connected back to the ignition switch 'Start' +12V control output.
Jul 11, 2009 | 1987 Chevrolet Suburban
Nov 24, 2008 | Gateway MS-6389 Ver.1 S462 Motherboard...
Tricity bendix keeps turning off !!
assuming you still have power to machine, it could be that the main circulating pump has a thermal overload in it which is tripping off. can you give me more detail?
Apr 23, 2007 | Tricity Bendix 18 in. DH090 Free-standing...
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
Owen Barnes
