Question about Cell Phones
Screen locked. password is 1950 and the #5 will not enter. rebooted and restared many times...no help. please help me unlock or make the #5 to work again
How do I unlock my galaxy j3 forgotten my password
Pompeo, You may have to do a hard/factory reset to get it up and running. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
FAQ SAMSUNG J320P Galaxy J3 2016
How to Hard Reset Remove Password Samsung Galaxy Core Prime
How to reset your android if you forgot your password and google account
Galaxy J3 What do do if Forget my Screen Lock Password on my Samsung...
Jul 02, 2016 | Cell Phones
Galaxy 6. How can I bypass password?
Samsung Galaxy S6: How to bypass Password:
Hello. You'll need to enter in your password first in order to get into the phone, and then set the phone to no security so that you can get into your device without having to enter it all the time, if it has become annoying. I would suggest at least using a simple swipe pattern to lock your phone
1. Enter screen unlock password
2. Go to:
Settings>Device>Lock screen>
(under screen security)
tap on "Screen Lock"
(enter your screen unlock password to confirm)
select: None, or Swipe, or pattern
if you are unable to select: None or Swipe
because they are greyed out
like this:
bypass-password-galaxy-6-kyzl0pi20tqzz121bvlihxv0-2-0.jpg then you will have to just clear the credentials in security..
(this happens when you select a high security option)
go to:
Settings>Security>Clear Credentials
then go back to
selecting your new lock screen option
then, Go to:
(enter your last screen unlock password to confirm)
Feb 12, 2016 | Samsung Galaxy Cell Phones
Screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storageā€¢ : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Dec 08, 2013 | Samsung Cell Phones
How to unlock hdd password on a acer laptop it's a acer aspire 7731z-5731
Try these WEB sites, you will need a computer with Internet access.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/ b>
Mar 08, 2013 | Computers & Internet
HOW DO I UNLOCK THE BIOS PASSWORD HP PROBOOK 4510S
Download the service manual from HP then remove the keyboard i think you will find the COMS battery under it remove that battery short battery connectors then restar and try to enter the bios setup see if password cleared otherwise...Some laptops using small EPROM to store the password and if this is your case i advice to send it to expert technician...............Good Luck
Feb 01, 2013 | HP ProBook 4510s FM849UT Notebook
I am locked out of my blackberry 9500 i have forgot my screen pattern and i need to reset it please help!
Enter any password until you fail 10 times, it will make your blackberry storm 9500 unlocked from old password and erase your previous data. There is no option to unlock blackberry password without loosing the data, that's feature of RIM security system. So good luck!
May 29, 2011 | RIM Research In Motion Blackberry Storm...
Would like to unlock cell phone
The Pantech phone was formerly sold by Cingular, but it is now sold by AT&T. Because it is a flip phone, the Pantech does not have a keypad lock. It does, however, have a feature to lock the device and prevent unwanted phone calls being made by other people. Locking and unlocking the phone requires you to know your password.
  1. ep 1 If the main screen reads "Phone Locked," choose "Unlock" from the lower left-hand portion of the screen. Enter your password and select OK. Entering the wrong password three times will display "ENTER PUK." You will need to call customer service to resolve the issue.
  2. Step 2 To lock the phone, choose "Menu" from the main screen. Select "Settings" and then scroll down and select "Security." Choose "Phone Lock" and press the left or right arrow on your directional pad. Press "OK" and enter your password.
  3. Step 3 Change your password by selecting "Menu" from the main screen. Go to "Settings," then "Security," and then "Change Password." If you have not yet set a password, the default is 1234. Enter either your password or the default and press "OK." Enter your new password, press "OK," and then verify the password by re-entering it.
Nov 17, 2009 | Pantech C150 Cellular Phone
Unlock password on acer aspire 5730z.
I BOOT THE LAPTOP WITH AN UNLOCKED HDD ENTER TO THE BIOS PUT A PASSWORD YOU CAN REMEMBER SAVE AND REBOOT THEN ENTER AND TRY TO CHANGE THE PASSWORD THIS TIME ENTER YOUR PASSWORD THEN LEAVE IT IN BLANK ONE TIME AND BEFORE COMFIRM SWAP THE HDD PUT THE LOCKED ONE IN THE BAY AND COMFIRM A BLANK PASSWORD AND VOALA!!! UNLOCKED.
/uploads/images/unlock-password-acer-aspire-5730z-5408997-2-1.jpg
Jan 29, 2009 | Acer Extensa 5620-6119 Notebook
Password
hi
Try with all the code to see whether you can get one to unlock your phone. If all still cannot help then you can only contact Samsung Support for help. I hope these information below at least can give you some hints:
Note try codes which help direct unlock for either SIM Lock or Security Lock first before try other codes
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*2767*2878# (Temporary Unlock)
*7465625*638*00000000*00000000# (Set Code)
#7465625*638*00000000# (Clear Network Lock)
*#7465625# (Verify the network lock is “inactive”)
*2767*3855#
*2767*3855# - FULL E2P RESET
*2767*2878# - CUSTOM E2P RESET
#*7337# - UNLOCK
*2767*688# - UNLOCK
*#0523# - CONTRAST
*#9998*523# - CONTRAST
*#8999*8378# - Service Menu (X100)
First with different carrier SIM in phone at WRONG CARD screen ENTER on the keypad
*2767*3855# (wait 10-15 seconds) phone will reboot(restart)
When phone completes reboot ENTER
NEXT ENTER
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
Good Luck
Feb 22, 2008 | Samsung SGH-U600
Reset password on Samsung SGH-E250
*2767*3855# resets all locks xx hope it helps
Sep 06, 2007 | Lands Phones
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
