Question about Kenmore Vacuums
Beater bar wont spin on kenmore intuition upright bagged vacuum
  • Kenmore Master
  • 1,534 Answers
Start with a new belt if your model has one.
Posted on Jan 03, 2017
Beater bar only spins when vacuum is locked & upright.
Your belt is probably stretched and can't turn the brush when it's on the floor. Replace the belt at least twice per year.
Feb 23, 2016 | Bissell Pet Hair Eraser Bagless Vacuum
Beater bar not turning
need new belt remove bottom cover to replace it
Nov 02, 2014 | Kenmore Progressive 35922 Bagged Upright...
My roller do not spin
There is also a circuit protector which trips if something gets caught in the roller, so that might be the problem. There is a very small red button on the right side at the bottom of the vacuum (IT'S VERY TINY), and you just push that in and it will reset the circuit.
Aug 22, 2009 | Kenmore 31913 Progressive Direct Drive...
Handimate doesnt spin!
try ajusting the height if the beater bar also check the belt and motor
somtimes **** gets stuck in the end bearings and add resistance to the beater bar slowing it down remove beater bar abd check assemby for thread and **** build up
Aug 03, 2009 | Kenmore Progressive Bagless Upright with...
It has no suction...
Assuming that the vacuum will run, remove the bag and check the discharge to the bag from the machine for debris. Also check the suction to the vacuum blower by removing the beater bar cover plate and beater bar. Inspect the belt. While the bar is off, inspect the suction hose behind the beater bar. This is where I usually find the debris.
Regards, --WoobieDog--
Jul 10, 2009 | Oreck XL Ultra Bagged Upright Vacuum
I have a kenmore beltless upright the beater brush dosetn spin
If it is direct drive then the motor or the wireing to the motor are bad. If it is gear driven then the gears are probally stripped.
Apr 11, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Kenmore upright vacuum model 116.35923500. not rotating when on. Easy way to clean without taking apart?
There is a switch that tells the cleaner that the upright is locked upright and the beater bar won't spin until you depress the foot release and tilt the cleaner. This switch mount is poorly designed, its just sitting in a pocket at the pivot of the cleaner. I had to double stick tape it in the pocket to keep it from moving around and put silicone spray on the pivot. The pivot actuates the switch, but its a bad design.
  • Remove front cover, to do this, pull out the bag, remove the screws under the bag and on the outside. 12 screws total.
  • Locate switch on pivot
  • Confirm mounting of switch, re-adjust and use tape or epoxy.
  • Reassemble and test.
  • This is for a Kenmore 35923500 upright direct drive.
Jan 25, 2009 | Kenmore 22812 Bagged Canister Vacuum
Belt burning
the beater bar probably needs to be removed & cleaned. the shaft & bearings get bound up with hair, string, etc.. with the belt off the bar, it should spin fairly easily. if it's hard to turn,(belt off) then it's bound up.
Jun 14, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
51 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
