Question about Cell Phones
Can not unlock screen because the password 1950 the number 5 is not working. locked out. reboot and restated many times. no resolve help
How do I unlock my galaxy j3 forgotten my password
Pompeo, You may have to do a hard/factory reset to get it up and running. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
FAQ SAMSUNG J320P Galaxy J3 2016
How to Hard Reset Remove Password Samsung Galaxy Core Prime
How to reset your android if you forgot your password and google account
Galaxy J3 What do do if Forget my Screen Lock Password on my Samsung...
Jul 02, 2016 | Cell Phones
Changing passwords on a used D 307.
Try this:
1. Reset to original factory setting by typing *2767*3855#, youre phone will reboot
2. Then insert a sim card that is from another network that your phone is not locked to.
3. An Wrong sim message will come up on the screen
4. When message appears type in* #9998*3323#
5. At this time a white screen will appear which says “exit”
6. Tap the rigth soft key, (occasionally it will not go to the next screen, if so press the down key)
7. From the menu that appears scroll down to the malloc Fail option, this will reboot, and normal service screen will appear.
8. Then type *0141# and press the green call key, Personalized will appear on the screen, and the name of the current sim card provider will appear on the screen.
9. Turn phone off, and then turn on
10. Go to menu by tapping left soft key, then settings in bottom right hand corner, then choose option number 7 security, then choose option number 6 Sim Lock, select option 1 disable
11. Then enter 00000000 (eight zeros), the message will come up sim lock disabled with a check mark, your phone is now unlocked to use with other carriers.
Dec 24, 2007 | Cell Phones
How do i unlock my screen lock since it is blocked
Dont worry, you can reset that PIN with your google account. Just try to input PIN 5 times (any number), now you can see option "Forgot PIN?" or similiar. Tap that option, enter your Google username and password, and you can find your password on your email.
Nov 26, 2014 | Lenovo 5.5-inch Unlocked White A850 3g...
Vtouch v705 is locked how I can reset the password
I read an article on how to reset the Vtouch V705 and although I have not performed this operation my self, you may want to investigate the following and see if it something you can work with that may help solve your issue. If this does not work or apply please reply and I will continue to look for possible solutions to solve your problem. Here is the quote on what you might try (if this applies) to possibly solve your issue.
"works well on chines android tablets! 1.Download the android tool. https://www.mediafire.com/?7se8s62sj1y5fpo2.extract and save to any location on computer2.open extracted folder and open software use the appropriate number for whatever job you would like to do.number 4 to reset Gmail lock, pattern lock, or password.when device reboots you may need to restart it a second time that's it all done. subscribe, like, share, comment.User Manual for Android Multi Tools v1.02bfirst device must install correct driver This program works with any Android device .Requires root and enable Debug mode or fast boot mode.choice 1-6,S,H can work with Debug Mode only.choice 7-9 can work with Fastboot Mode only.choice detail1.Check Device for check connection of device to PC.2.Reset Face/PIN Lock for reset face lock on android 4.1.x and PIN lock without lost data.3.Reset Face/Gesture Lock for reset face lock on android 4.1.x and Gesture lock without lost data. After device reboot Then you can draw anything for unlock.don't forget close lock in security menu4.Reset GMail for reset gmail login after try many time wrong unlock 5.Wipe Data for reset all data to factory setting.6.Reboot for reboot device to normal mode or exit from adb shell.7.Check Device On Fastboot Mode for check connection of device to on FastBoot mode.8.Wipe Data / Cache On Fastboot Mode for erase user datat and cache on Fastboot Mode to resolve freeze,stuk on boot logo or slow down device. That is often found in the CPU Spreadtrum SC6280/SC8810.9.Exit Fastboot Mode for reboot your PC or exit FastBoot.0.Go To Command Promt for entering DOS promt.you can use command in this soft folder And can return to the main program by type exitS.Software Info for info CPU inside,firmware version and etc.H.Hardware Info for determine the IC number of Gsensor,touch screen,Camera,WIFI and moreR.Report / Contact Me links to the specific problems of the Phase I program and a bookmark.D.Driver Download for loading the drivers in case you do not have the driver installed in your PC - See more at: http://celularmovil.info/video/view?videocode=okEyk5LrNDc&startpage=6#sthash.j9wiRuoL.dpuf
Please let me know if this works out or if you have any additional comments or questions. Like I said before I have not actually used this method myself so PLEASE be cautious when downloading and installing any type of software. Thank You!!
Nov 20, 2014 | Computers & Internet
I selected advance recovery setting on my acer
try going here http://www.hirensbootcd.org/download/ burn to disk so many useful things.. Run Mini XP
Oct 03, 2014 | Computers & Internet
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
My htc is lockd it can make emergency calls only and i forgot my password
It says Emergency Calls means it locked to Network Lock,You need to Unlock it from Network Lock,You can get the Unlock code at
http://www.mobileunlocksolutions.com/htc-touch-hd/rs1wp9/ and Unlock it,Then You can get the password code from service provider as free of cost,.
Apr 13, 2011 | HTC Cell Phones
Hi, my name is Michael as I UPGRADED my cellphone contract in 2008, I set aside my old handset which is HUAWE U120, now I want to give it to my son but he cannot use it as I forgot the password. How can I...
Unlock procedure:
1. Connect cable to phone. Also insert locked SIM card ( not Vodafone card )
2. Switch on phone. When keyboard light comes on, press "Reset Unlock Code" button. Phone will freezed. After few second phone start work again and show locked message.
3. Press left button under screen on phone and enter 16 zeros (0000000000000000), then press OK.
4. If code resetted ok, phone show correct code and ask for reboot. Reboot phone.
5. After reboot phone will be unlocked.
IMPORTANT: you must use JTAG socket in box and your box must be updated to latest version - otherwise you will get error:
hope this was helpful
Nov 15, 2009 | Cell Phones
My Samsung SGH-d807 is locked, and i have tried to unlock it 5 times after which it says a message that permanently locked to cingular network.
1. If you have changed your phone password, change your password back to the default 8 zeros (00000000).
1a. NOTE: Go to SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone is locked to
3. When Incorrect SIM (I got invalid card and there was a sim card graphic spinning) error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey. (you may have to push the down key to get a menu)
5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK Mentioned earlier gets switched back on)
10. Completed. You have now unlocked your phone.
this may be what you allready tried, but it worked for me, good luck
Dec 30, 2008 | Samsung SGH-d807 Cellular Phone
T-mobile phone
just give me the phones serial number........send it to edwinsheringham@lycos.com and i will try and  give you the code for unlocking.
In newer phones:
#*7337#
this step sometimes also works
1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
3. When Incorrect SIM error comes up, type *#9998*3323#.
9. Type 8 zeros (00000000) (This is because the SIM LOCK mentioned earlier gets switched back on)
tested on e-series phones - may work on similar models but not sure
please let me know the outcome
May 11, 2008 | Lands Phones
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
