My hinge is cracked, is it possible to get just the hinge without replacing the entire lid?
    Top Expert:
  • Computers & ... Master
  • 26,740 Answers
You may find a hinge on fleabay.
Posted on Dec 27, 2016
5 Suggested Answers
DarkmanUK
  • 94 Answers
SOURCE: acer aspire 3620 lid broke and screen needs to be replaced
If a 'qualified' tech damaged the screen, then it is up to them to replace the screen at their cost.
You could try finding screws slightly bigger and see if they will realign and stop it from being floppy.
Personally I would go back to the tech and complain untill they repair it properly.
Hope this helps a little.
Posted on Nov 27, 2008
benwabnick
  • 2404 Answers
SOURCE: acer extensa 5420 - crack on lid near both
Anything cosmetic is never covered under warrany unless there is a recall from the company and I don't remember hearing any recalls from Acer recently.
Only thing I can suggest is to get a hold of Acer and explain the situation and see if threre was or is a recall on your model.
My best solution, go to this page:
https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
Either fill out the form or call the number and see what they can do.
Let me know what they say and If they can't help at all then there is other routes we can try to take to keep costs down.
Posted on Jun 25, 2009
  • 305 Answers
SOURCE: crack to hinge and lid of laptop
just be carefull when opening or closeing undo catgh then lift from as close as possible to hinge to stop stress on cracks to close do same.
hope this helps.
Posted on Apr 28, 2010
  • 8 Answers
SOURCE: The back lid of the
new hinges are not available in the market what you can do is that
  1. you can veld it
  2. or you can check for the used one from the person who is doing work of scrap
  3. it will cost you near about 10 to15 $
Posted on Jan 12, 2011
Testimonial: "thanks for the feedback"
Whirlpool cabrio washer lid repair by kevin miller
Hello, Joan -
Are you referring to the review by ChrisG on Amazon.com regarding the Whirlpool W10349235 Lid Assembly Washer (link):
https://www.amazon.com/Whirlpool-W10349235-Lid-Assembly-Washer/dp/B00LTYSPNK
This is a copy of ChrisG's review there:
[Quote]
USE DIFFERENT PARTS AND THE PROBLEM WILL BE SOLVED FOR GOOD
July 7, 2016
Don't waste your time replacing your cracked lid with yet another lid that will crack. The tension in the springs is too much for the plastic frame of the lid.
The CORRECT FIX was recommended by Kevin Miller on the fixya website.
Use lid part # 8572026. It's a completely solid metal lid. Use two hinges, part # 8563964, since the existing hinges wont work with the new lid. Use four screws, part # W10119828, for mounting the new lid to the new hinges.
I used the above parts that Kevin recommended and it worked perfectly. Check my before and after photos.
Replacing it was easy. I simply removed the two screws on each side of the lid connecting it to the hinge. Pulled the lid off. One of the hinges pulled out easily. The other I had to spray with lubricant and eventually it came out.
The installation was just the reverse. Slide the hinges into the holes of the lid and into the holes in the washer and then drive in the screws through the lid into the hinges.
BTW, at one point my washer was spinning and did sound like a jet engine but it was still covered so they came and replaced the bearings. So I am good for now.
[End quote]
Note: I have not been able to find Kevin Miller's answer on Fixya.com. Unfortunately, ChrisG did not provide a link to Kevin Miller's answer on Fixya.
Jan 03, 2018 | Whirlpool Washing Machines
ASUS U46E broken hinge
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges for your laptop maybe available from thia WEB site.
http://www.laptopparts101.com/display-screen-hinges/
Aug 27, 2012 | ASUS Computers & Internet
The lid is very stiff to open and is cracking the casing
The hinges need to be serviced by a computer technician, using light oil. They may need to be replaced. I have seen this happen and if not sorted out, the hinges themselves break or the main chassis frame breaks. In which case it may be better to buy a new laptop. Get it sorted as soon as possible!!!
damnor01
Nov 26, 2010 | Acer Extensa 5620 Notebook PC
Crack to hinge and lid of laptop
hope this helps.
Apr 28, 2010 | Computers & Internet
Broken hinge on reservoir cover for Cuisninart model DCC-2200
The hinge itself is not orderable, but a lid with the element that fits into the hinge was available from Cuisinart the last time I checked. Call 1-800-726-0190 to be sure. It is not easy to put the replacement lid into the right place without breaking the part, but it is possible - you have to put one bar into the hinge, and then pull the other bar just enough to fit it into place without breaking it. If you are out of warranty, the lid will cost somewhere betwen $15 and $20 with shipping.
Feb 26, 2009 | Cuisinart DGB-300 Coffee Maker
The locking lid on Crock Pot SCVS600 has broken.
I had this same broken lid handle problem so I called the 800 number on the crock-pot.com website and got right through to a live person. Since my product is still under warranty (they asked for the manufacturing date code on the plug), instead of providing me a replacement part, which the very nice woman said is unavailable, they are sending me a whole new crock-pot. Not the same model (which the nice woman also said is unavailable) but a comparable unit which is OK with me. Maybe this is their solution to the lid hinge and handle problems.
Dec 24, 2008 | Rival SCVS600 6-Quart Slow Cooker
Acer 3610 crack by hinges on monitor
Unfortunately the LCD back cover is not readily available but you can find it here http://www.computercare.ca/product.php?productid=18048&cat=1648&page=
I bought this part and replaced my back cover for LCD. be careful while replacing LCD inverter you might be needing a new one.
Aug 19, 2008 | Acer Aspire 3610 Notebook
Brother Fax Machine MFC8840Dn broken hinge
you can actually by the hinge itself for only 27$
the website is here: http://www.precisionroller.com/search.php?q=brother+mfc+8440+hinge&x=0&y=0
Mar 19, 2008 | Brother MFC-8840DN (Bundle) All-In-One...
Lid/Top Loose
I have a Tecra M2 S630 and was able to fix my left hinge by removing it and drilling out the rivet and replacing it with a 6-32x1/4 inch machine screw and a nut. Total cost was $4 for a package of nuts and screws from Radio Shack.
Nov 30, 2007 | Toshiba Tecra M1 Notebook
Brother MFC 7820N
just order a new hinge and replace it yourself! why buy the entire lid/cover?
Aug 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
