Is it possible to replace only the hinge? - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 26,665 Answers
Hinge for what.
Posted on Dec 27, 2016
Hinges not closing fridge door -is it possible to replace hinges
possible door seal bad or try raising front so doors close
Apr 05, 2018 | Refrigerators
The pin of my lower hinge of the driver side need to be replace, schould i remouve the hinge to do that or it could be done just by oppening the door.
remove the hinge and make your life easy to do it in place is sometimes possible but a mess on and it will take alot longer
Mar 03, 2018 | Cars & Trucks
Bemis whisper close toilet seat stopped being quiet, lid slams
This is probably a friction hinge. The slow closing feature is a result of friction within the hinge. So it sounds like the hinge has worn to the point of the friction being reduced. Another possibility is that some kind of lubricating fluid entered the hinge. If so, perhaps it will regain friction with time. Most likely the seat needs to be replaced.
Sep 02, 2017 | Bemis Home
This hinge has snapped in two Can it possible be welded back together again?
It depends on what material it is made from. The easy answer is yes most materials can be successfully welded but some materials are more problematic than others and need specialist equipment and skills.
If the material is mild steel you will have no trouble getting the welding done once the hinge has been removed from the door and the oven. I think that could be the major problem of the exercise.
A hinge wouldn't break for no reason. I think it would be wise to discover the reason before carrying out a repair. I suggest checking the price and availability of a new replacement hinge from the manufacturer before going ahead. The broken hinge might be a design flaw (whoever heard of a broken oven door hinge?) and a replacement might be a modified part that would resist breaking.
It is possible a new part could be cheaper than having it welded but you won't know until you check.
Apr 02, 2016 | Ovens
Car door is sagging
Take a good look at the door hinges. Often, there will be replaceable bronze bushing inserts in the hinges, and the hinge pins are also prone to wear, especially if the recommended lubrication is not done.
If the bushings and/or pins are not replaceable and the wear is in the hinges, the hinges willl need to be replaced.
Other possible causes are loose hinge mounting fasteners, failure of the door or "A" pillar (for front doors) at the hinge mounting location(s) due to rust or physical damage, and (of course) collision damage to the door or door frame.
Oct 04, 2012 | Toyota Celica Cars & Trucks
The oven door doesn't quite close properly. Thought it may have something to do wit the hinges but upon inspection I was unable to unscrew the the hinges to get a good look. Possibly could be the seal. I...
It sounds like the hinges may be going bad on you. You can inspect them if you want to.
  1. First pull out the broiler oven.
  2. Now you can lift up on the oven door and remove it.
  3. The springs in these hinges have a lot of tension in them. Please be very careful when doing testing the hinges.
  4. Now take a pair of pliers and carefully grab the hinge and pull it towards the the oven.
  5. The hinge should be able to set itself up against the frame of the oven itself. If it does not then that hinge will need replaced.
  6. Check the other hinge.
  7. I am willing to bet that at least one of the hinges needs replaced.
Mar 23, 2011 | Ovens
Loose Screen on Dell Inspron 1525
If the hinges are loose, it is not possible to tighten them, the hinges need to be replaced.
For details on replacing hinges, please click on these WEB sites :-
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
and these WEB sites for parts :-
LAPTOP PARTS www.laptoprepairco.com/
www.laptopparts.com.au/
www.laptopking.com/
www.lappy.com.au/
www.excelcomputerinc.com/
www.laptoprepairparts.com/
www.lapzone.com/servlet/StoreFront
www.laptoppartsexpert.com/
www.sparepartswarehouse.com/
Sep 09, 2010 | Dell Inspiron 1525 Notebook
My screen won't stay open. i think the hinges are broken
Hi. The hinges are either broken or worn out. It is possible to replace them but it can be difficult to find them. I recommend calling around to a few local repair shops as they may have an old one of your model that they are using for parts. Here is a link that shows you how to replace a hinge http://www.insidemylaptop.com/repair-replace-broken-hinges-hp-pavilion-dv9000-notebook/
Also, here is a link to get actual HP parts http://h20141.www2.hp.com/hpparts/CountryChoice.aspx
Nov 11, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Oct 17, 2008 | Belling XOU252 Electric Single Oven
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
