Question about Frigidaire Washing Machines
Mine is flashing EFO90 what does this mean it a front load washer by Firgidaire
We just move it from one houe to the new one and I was not sure it that had something to do with it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 81 Answers
Frigidaire Refrigerator Error Code = EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Posted on Dec 29, 2016
It wont let me start a new load. it keeps flashing F-24. why?
Hi, the "F24" error means that the washer temperature sensor has found an error. This could mean that the water is too hot, too cold or the sensor has malfunctioned. Find the water temperature sensor on the inside of your washer. Make sure it is properly connected to the washer. Unplug the sensor, plug it back in and start the clothes. If the error persists, you may need to order a new part. Use a thermometer to make sure the problem is not with your water heater. Use your washer's manual to find proper parts or look online at websites like Advantage Supply and Appliance Parts Pro
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer has a symbol on iy . It flashes H then F Do you know what this means
That code means its not getting water. Has it recently been moved? If yes check and make sure the drain hose is not too far down in the stand pipe causing a siphoning effect. Also check that pressure switch hose is clear. To clear code press pause/cancel twice.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer doesn't spin or wash -
Here is what you do:
Disconnected every cable to the MCU and CCU (one at a time) and reconnected them making sure each connection is good the run the machine. If the error code
is comes back, replaced the motor that has the tachometer.
Go www.appliancerepairclinic.com and order a new motor.
Oct 12, 2009 | Kenmore 44102 Front Load Washer
F-21 flashing washer stops
The F-21 means slow drain. There is a filter in the front of the machine, you have to remove the bottom front piece to get to it. The screws are on the bottom. You then will have to open the filter. It is a white tube. Mine was pretty tight. Be prepared for water to pour out. I have had to empty mine twice in the 2 years I have had it. Hope this helps.
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cloths still soking wet after rinse cycle
remove the front panel on the bottom look for a screw out filter bout 2 inches long youll see it screw it out clean the filter and reinstall the filter then the water should flow out on spin good luck
Apr 12, 2009 | Frigidaire ATF6000ES Front Load Washer
When the washer go s on rinse the prewash flashes Problem
Mine has been doing the same ... each time it goes to the next part of the cycle the red light flashes but the machine doesn't do anything ... so up till I have been able to get the machine moving to the next stage by pressing the "Start" button ... unfortunately the machine will pause on each stage - meaning I have to press "Start" at each stage!
Dec 15, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Firgidaire washer
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Dec 11, 2007 | Frigidaire Affinity ATF7000E Front Load...
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
