Question about Garden
Model # 944.523050 to find spark plug location on Craftsman Snow Thrower
  • 472 Answers
SOURCE: i would like to know if a 42
Posted on Dec 16, 2009
  • 714 Answers
SOURCE: Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
Posted on Jan 23, 2010
  • 448 Answers
SOURCE: Will a Craftsman 42" model 486248392 snow thrower
it shooed fit with no problems but first check the crank shaft
to make sure they are the same size that's always ben the
problem trying to switch motors let me no if you need more
i hope this helps you
Posted on Jun 07, 2011
  • 417 Answers
SOURCE: craftsman 32" 10 hp snow thrower
Around the back of the engine, just below the cylinder cooling fins. The shut off should face you if standing in front of the recoil starter, for the fuel tank. The fuel line should wrap around I the side of the carb and be protected by the metal cover surrounding it.
Posted on Nov 22, 2013
  • 776 Answers
SOURCE: Need to find correct spark plug for Troy-Bilt
Several engines were available, you need to look for the number on your current plug - easiest method.
otherwise, you will need to give the motor manufacturer and nameplate info (Tecumseh SnowKing 8HP?)
Posted on Nov 16, 2014
My Craftsman snowblower 26# model 247.889702. I runs and throws snow but makes a very loud clanking sound like something is broken. Both belts appear to be good.
Check inside and see if anything is loose. Pull the spark plug wire before you do. You could have bad bearings in the thrower itself.
Dec 10, 2017 | Craftsman Garden
Manual for sears snow thrower 536.886621
They are basic what do you need to Find in the Manual?
Feb 12, 2014 | Craftsman Sears Snow Thrower Manual Model...
Carberater for my snow thrower isn't getting gas
The carburetor could be clogged. Try spraying some carb cleaner into the engine to see if it starts. If it does, then some part of the carb may have varnish clogging some of the ports.
Jan 30, 2014 | Craftsman 24" 208cc Dual-Stage Snow...
Spark plug location
My 8 horse Craftsman blower has the spark plug right on top of the engine.
Jan 21, 2014 | Craftsman Sears Snow Thrower Manual Model...
Where is the throttle on a craftsman 536.881800 snow thrower?
Manual is available at
Dec 14, 2013 | Craftsman Sears Snow Thrower Manual Model...
Snow thrower not starting
Two ways to find out:
start with elctric, take the plug cable out and see if have
if you have spark go to fuel :
change the old fuel to a fresh one.
Dec 13, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Carb adjustment and what is the correct spark plug
If the snow thrower worked last year I would suspect old fuel in the tank. Dump out the old fuel in the tank and put in fresh. Put a squirt of starting fluid in the carb and try to start it. If it fires the ignition is good. Do this a few times to pull the old fuel through the carb and fuel line. When the new fuel gets through the fuel system to the engine it will stay running. The spark plug in the engine will have number on it. Get one with the same number if you want to replace it.
Dec 10, 2013 | Craftsman Sears Snow Thrower Manual Model...
My snow thrower wont start
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
Jan 12, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
