Question about Refrigerators
Why is my freezer temperature goin up - Refrigerators
The freezer is set at -4. How do I adjust it? Everything is freezing too much.
Hi Marisa:
Following is the instruction for adjusting the freeser temperature for your Samsung refrigerator:
You press the freezer temperature button repeatedly till you see your desired temperature. If you want to set it to -2F, stop when the display shows -2F and don't press the freezer button again. After 5 seconds this new temperature will be set.
The instructions from the Samsung manual is shown below:
Controlling the Freezer temperature:
The Freezer temperature can be set between 8°F and -14°F to suit your particular needs. Press the Freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at 4°F. The temperature display will move sequentially from -14°F to 8°F. When the display reaches 8°F, it will begin again at -14°F. Five seconds after the new temperature is set, the display will again show the actual current freezer temperature. However, this value will be changed to the new temperature.
Feb 15, 2016 | Samsung RF265AA Bottom Freezer French Door...
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Aug 20, 2015 | Miele KFN12923 SD-2 Stainless Steel 369 l...
The temp says 14 and 8 but should be -21 and 3? Can anyone help
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Cant find temperature control knob
Good Afternoon Friend,
I understand that you are looking for the temperature control knob on your Frigidaire freezer, model# FFU2064DW. The temperature control is located inside your freezer on upright models, and on the left outside wall on chest models. The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. Hope this is helpful.
-Best Regards-
WP
May 09, 2014 | Frigidaire 20.3 cu. ft. / 575 liter...
When it runs it makes a noise
it could be something rapped around the condersser fan blad.is the freezer working good? or it could be the motor it self goining bad.
Feb 18, 2013 | Maytag Freezers
My Frigidaire PHSC239DSB2 side by side's digital temperture display is flashing a 2 on the freezer side & the fresh food sides temperature went up to 47 degrees, but has no flash. What is goin
HI this is a difficult one without a visual but i would sugest u disconnect the power supply.re-connect everything again and re-start.reset temp if not pre set.and try before u call an engineer.good luck.Ali
Jun 18, 2012 | Frigidaire FRS26H5AS Side by Side...
My freezer is workin but my fridge isnt cooling. food n milk went sour.... whats goin on?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Magic Chef CTF1826AR Top Freezer...
Freezer is very cold but fridge area is warm. what is up.
Sometimes the defrost drain pan stops up. Instead of the water goin outside is pools up between the compartments. This forms a slab of ice and blocks the air flow from freezer to fresh food. Of course the other thing that comes to mind is the freezer fan could have quit or stopped due to an ice buildup.
Feb 13, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
The refrrigerator and freezer not holding tempreture it started with the freezer - how can i fix - i have defrosted the freezer and removed all food?
hi there,
have you check the temperature?
The temperature controls are preset in the factory at 37°F for the refrigerator compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended
settings.
The temperature controls can display both the SET temperature
as well as the actual temperature in the refrigerator and freezer.
The actual temperature may vary slightly from the SET temperature based on usage and operating environment.
Setting either or both controls to OFF stops cooling in both the freezer and refrigerator compartments, but does not shut off electrical power to the refrigerator.
Jun 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
