Question about Dacor Kitchen Ranges
Control panel dead on Dacor Epicure 36" dual-fuel range--display dark. Breaker not triggered, top burners ignite, so power gets to stove. Worked yesterday. Is there a reset switch somewhere?
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: F1 flashing on Epicure 30" Dual Fuel range and Gas-flame broiler
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor ERDS30 clock and display OK, all bake buttons non responsiv
Most likely the interuption of power is what caused the problem. try shutting down the circuit breaker that controls the range for 30 minutes then turn it back on if this does not reset the electronics. You may need to replace the keypanel and /or electronic control as either or both may have been damaged by the power surge.
Dec 31, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Igniter
Does the knob control both the gas and spark, try turning on the knob only, if it starts to spark right away then it is possible that the switch is bad. because most of these units are designed where you turn on the gas then push in and hold the knob to ignite then release and spark should stop.
Dec 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Oven Death
hi,
i think first you should call dacor, 4 months is marginal - they should cover it
but if all else fail you can try this link ti diagnostics manual:
http://dacorservice.com/PartsCatalog/docs/ProductModels/437/Diagnostic_Manual.pdf
and this link to dismanling instructions:
http://dacorservice.com/PartsCatalog/docs/Ranges/Service%20Manuals/ERD30s06_sm.pdf
good luck
dov
Nov 20, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Kitchen Ranges Logo
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
240cpa
Jaime Hernandez
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
