Question about Microwave Ovens
Microwave turns off as soon as we turn it on turn table does not move
  • Microwave Ovens Master
  • 9,085 Answers
To help you, I would need your full model number as shown on the tag in or or the oven.
Q: When you say you "turn it on," does that mean when you plug it in, or when you press "Start" or another key to try to make it cook?
Q: What exactly do you mean by "turns off?"
please e-mail me here
Posted on Dec 28, 2016
Why is my turntable not turning in my microwave oven?
Is your microwave clean under the table? No stuck on food or anything? Does the the oven work without the table?
Does the little prop in the centre that turns the table move when there is no table on it? Try to carefully clean it and see if that helps.
Feb 17, 2015 | In Microwave Ovens
How do I fix a Microwave?
A microwave is not a good candidate for novice repair. However, since it isn't completely dead, the power circuit is likely intact (not a blown fuse). The major components involved are the capacitor and the magnitron. The cheapest is the capacitor. If you have to replace the magnitron, it is not likely economically feasable. Be careful of the cap - it contains energy even when unplugged!
Jan 02, 2015 | Kenmore 30" Microwave Combination...
Galanz Microwave Model WP1000AL30 doesn't go on when the item buttons are pushed?
Does microvave button makes sound and when you start push button does the turn table moves.If yes for sound ,and no for turn table then you might have door switch which is either doesent latching or might broke.
open oven (be sure to discharge capacitors).
check its closing properly(the switch)
and use DMM to check resistance that it doesn't show OL
thanks
please rate my work
Sep 20, 2011 | Microwave Ovens
My daughter just moved into a townhouse and the microwave plate warms, however the plate doesn't rotate. Is there any easy way of fixing this issue
The rotating table in a microwave shouldn't be getting warm unless something is sitting on it and transferring heat to it. The chamber should not be left empty when the microwave is running. The motor that drives the table is of very low mechanical power but should be able to handle about any load it must. I suggest you remove the glass table, the ring on which it rides, put a cup of water in the chamber and turn it on. Look at the drive spindle that engages with the table when installed. If it isn't rotating 9should be easy to see) then the motor is defective which is highly unusual to see one fail. If the spindle is clearly not moving, then I recommend replacing the whole unit since while the part isn't expensive, the labor cost would likely make the repair uneconomical.
Dec 22, 2010 | GE Microwave Ovens
Microwave Drum not moving Problem
Remove the plug and take the turn table out of the microwave cabin. Now keep the microwave rested on the side andopen the back pannel,you can see the turn table belt drive.If this is broken replace.if not trace the motor connection and mark them.Now heat the microwave in normal position,place the turn table and a cup of water.Close the door and switch on the microwave set for a minute.Now check the voltage on the motor line marked.If present ,then the motor is fault.If not the controller board is faulty, and must be traced.Can be the relay drive or the relay. hope the other sections are working fine.
Aug 31, 2010 | Microwave Ovens
Turntable not turning
you should be able to repair this your self the turntable motor is fairly easy to get to.it does sound as though your motor has gone bad.
Jan 31, 2010 | Dacor DCM24 Convection/Microwave Oven
My turntable is not moving. it was working very well upto now.
Not familiar with Kenmore, however, in most cases the turn table is turned by a small motor under neath the microwave, which is probably faulty.
I don't advise you to repair without trained safety knowledge on microwaves, this should not cost too much to repair by an approved engineer.
Sep 20, 2009 | Kenmore Microwave Ovens
Turn table doesn't turn
Is the plate engaging the drive?
Jun 15, 2009 | Kenmore 63792 Microwave Oven
TURN TABLE QUIT WORKING
take down the bottom panel and replace the turn table motor p# wb26x10038
Mar 20, 2009 | GE JVM1631 Microwave Oven
I believe the inline fuse is blown - where is it
my microwave will not heat food turn table is not moving and showning red smybols
Jan 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
