Question about Dell Laser 1720 Printer
My DELL 1720 Laser Printer will not print envelopes. The Paper Jam light comes on. Anyone know how to fix this problem?
JSPCEXPRESS
  • 178 Answers
SOURCE: Dell 3000cn Laser Printer Problem--Paper Jam
Hello how are you Take the tray out on the bottom and see if there is a piece of something in there. Mine does this sometimes. Also on the back there is a drawer open this up and check. Have you taken out the toner yet. Do this and once you check every area as described turn power off to it and leave off for min. Then power back on and push cancel button about 5 times let me know if this works for you. It does for me
Posted on Feb 13, 2008
  • 5 Answers
SOURCE: Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Posted on Jan 09, 2009
  • 461 Answers
SOURCE: How can I un jam a paper jan in Dell 1720 laser printer?
Open the front cover and remove the toner cartridge to see if you can access the paper, if not open the top and inner cover to locate the paper and gently pull it out.
Posted on Jan 19, 2009
SOURCE: step by step - how to print envelopes with Dell 3110cn laser printer
floppy will not work
Posted on Feb 02, 2009
SOURCE: I have 2 Dell model 1700n laser printers and they
Take off the two rubber rollers, turn them inside out and replace them, Voila!
Posted on Aug 23, 2009
My envelopes will not print -
Did you remember to specify envelopes in the printer properties dialog box? Click the button that says Preferences. Then click the Paper/Finishing tab. Under Paper Size, select your envelope size.
The printer will not feed the envelopes correctly without specifying this. The Lexmark printers adjust feed tension based on paper size settings.
Oct 15, 2014 | Lexmark E260dn Laser Printer
I cannot get the envelope fuction to work correctly. The printer tells me I have a paper jam, when in fact I am trying to print an envelope
The printer will stop printing is there is an error, check for any paper jam before printing. Take note of the error message and locate the exact jam.
Use the manual feeder when printing on envelopes. You may click on the link http://bit.ly/rnHp5b to see instructions on how to go about the procedure using the manual feeder.
For further assistance, please call Lexmark Technical Support.
Mar 08, 2011 | Lexmark C532n Color Laser Printer
I use a Dell 3110 cn printer. There were black splotches whenever I printed envelopes.I had a serviceman look at it to no avail so I changed the black toner cartridge. I am now getting blue splotches. ...
when you print envelopes you have to choose the envelopes in the printer settings then only machine knows that envelope is printing. when you don't select envelope in printer settings when you sent a print, the printer knows the a normal paper is coming through. the difference is that the envelope is a bit thick the normal paper. when envelope is selected in printer properties then the printer adjusts its settings to print on envelopes.
Jan 06, 2011 | Dell 3110cn Laser Printer
HOW DO I PRINT ENVELOPES ON A BROTHER MFC-465CN PRINTER? SCREEN TELLS ME THERE IS A PAPER JAM WHEN THERE'S ONLY ONE ENVELOPE IN THE TRAY.
my brother mfc 7860 tells me i have a jam when i print envelopes only- there is no jam and will print the next 'page' fine- have to turn it on and off 4-5 times to get it to print one- any ideas anyone???
Aug 11, 2010 | Brother MFC-465CN InkJet Printer
Dell 1720 laser printer shows paper jam after clearing jam and turning off and back on.
some paper piece may be left in the printer.
Please check where was the leading edge of the paper when it was jammed. some sensors may have got stuck while removing paper. open the toner door remove the toner cartridge, just see all the sensor flags with fingers, refix toner and power on and try printing
Dec 01, 2009 | Dell 1720dn Laser Printer
Problem with printing an envelope
Not an ideal solution, but, Dell printers were not desined with envelopes in mind. (I used to work there)
My solution, if you value your time at all, pick up an HP personal laser printer. Costs a little more, but the time saved will much outweigh the inital cost.
You CAN get the dell printer to work a few times maybe but consistently is not a possility....
Feb 26, 2009 | Dell 1710n Laser Printer
Jan 18, 2009 | Dell 1110 Laser Printer
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
Dell Laser 1720 Printer Logo
50 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
