Have no signal, but other TVs are ok with signal
  • Brett Duxbury
    Brett Duxbury Dec 28, 2016
    Hi Elizabeth potter,weI want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    How are other tv's connected
    Are you using a cable from the tv to the aerial connection point and is the cable an aerial cable at 50 ohms impedance or a video cable ? they look exactly the same ! but electrically are not the same impedance
    Are you using 300 ohm aerial wire. ? or 50 ohm cables ?
    Problem Solver:
  • 17 Answers
Not sure what you are really asking here. Are you staying that you have tried one tv and you don't obtain a signal and have tried others and have received a signal? And what are you connecting to, a HDTV transponder, cable, or an antenna? Please provide further details to be able to help you.
Posted on Dec 28, 2016
Initially looking for logik spport logik tv support. cannot now tune in tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 08, 2014 | Televison & Video
No signal for my 40" smart tv
Check the connections to all the input signal cables first for firmness. If all are found OK, the fault is with TVs input selector switch IC [inside]; and should be replaced. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 29, 2014 | Vizio Televison & Video
Does my Curtis Mathes Tronics model 19001 have a digital tuner?
No,all small tvs CRT tubes analoge tvs design under 35" none of the tvs have a digital tuner inside of it tv Tuner signal board.Must get a signal through a Digital Converter box to recieve a free on AIR broadcating channels from a Digital broadcasting signal.Tvs that are analoge CRT tubes design that have a Digital Tuner design inside of it are only some DLP tvs analoge CRT tube design 40" and above have it only.
Aug 09, 2011 | Curtis-Mathis CM19011 TV
Please advise me what to do: recently I moved to Hungary with Sony TV Bravia KDL-40VL130 bought in the USA. I thought that this advanced TV would work anywhere in the world. However, it turned out it is...
Sorry u can't use this tv,because the US,Mexico and Canada tvs use a signal which run in call the NTSC signal frequencies.The European Union,Asia and the Middle East tvs use a signal which run in call the PAL signal frequencies.So,Pal or NTSC tvs signal frequencies can't not be mix.Can't modtifies these tvs it a PAL or a NTSC tvs and all it eclectronics circuitries run on that signal design frequencies.Those tvs,that call regions free tvs,Those tvs are design to run all over the world.Run on NTSC or PAL signals frequencies.
Oct 24, 2010 | Sony KDL32L4000 32 in. LCD HDTV
I do auto programing some chanels get program some don't
Hello
Check first your set top box's, or TVs antenna or ariel connection is tight or not. It it is Ok, if you are receiving signals from cable, ask the cable operator to check the signal strength at the cable end of your home. It is measure with a 'db' meter. If the strength of the received signal is very weak, the same channels should not mamorized, and strong signal channels only will lock in. If you are using external antena, try to reorient its postion.
Anyway your TV doesn't get sufficient signal strength.
Oct 19, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My Transonic LCD tv was connected to the aerial via my video recorder which is now out of order. I connected the aerial directly to the TV but now only get black & white! The DVD channel etc are...
Ok, if all you did was remove the vcr out of the circuit and put the aerial directly to the tv and now the color will not come in. That means your signal is not strong enough to provide a good picture. Some new model tvs have weaker tuners compared to older model tv and vcr tuners causing them to have weak snowy or black and white picture. The idea being most newer tvs are designed for cable or satellite hd use not for aerial use. What you wear doing before was amplifying the signal by running it thru the vrc first then viewing the output on the tv. Get another vcr or amplify the signal with an signal amplifier.
Aug 19, 2010 | Televison & Video
Pixelation of TV channels via Settop box
Pixelation is caused by poor signal strength. Check the signal strength in the setup section. Unfortunately some boxes and TVs don't handle poor signal as well as others. It might be worthwhile trying a signal amplifier
Jun 12, 2010 | Televison & Video
Can't pick up BBC1, BBC2, ITV1, ITV2, CH4, CH5 on DTV (JVC LT 19DK2BJ). All other channels OK
Solution - Replaced cheap and very basic B&Q signal splitter with a better splitter/amplifier. Signal then perfect for both TVs (signal split to TV in Lounge + TV in Kitchen)
Dec 29, 2009 | JVC Televison & Video
3 PANASONIC TVS HOOKED UP TO CABLE SYSTEM AND ARE ON 37" PANASONIC TH-37PX50U WORKS FINE BUT THE OTHER 2 TVS DO NOT WORK. THE CABLE SYSTEM HAS BEEN CHECKED TWICE AND WE ARE TOLD IT IS OK BY TIME WARNER...
unhook 1 tv at a time leaving 2 tvs each time hooked up. try every combanation Possable to see if it's a tv problem or if when you have all 3 tvs hooked it makes the signal weak. this can happen cable guys say no but it can been there done that. if 2 works and 1 dont in every combanation the problem is in the cable system. most cable guys check the signal outside. with the splitter block unhooked. this gives a false reading.
Oct 31, 2009 | Panasonic TH-37PX50U 37 in. HD-Ready...
Tv hookup problem
Ok you must plug it in your DVD player in the A V in cause some TVs do not have it and dont have a signal.+
Mar 19, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
