Question about Dyson Vacuums
Cleaning dyson most dirt is not going into filter it stays on area of rollers and inside the head
  • 4,201 Answers
Must be a blockage
also check micro filter is not blocked.
if you do not know what or where this is then google dyson cleaning micro filter {whatever your model number is}
or go to dyson website
http://www.dyson.com.au/supportv4.aspx?mkwid=skGSqCBV4_dc&pcrid=51598771556&pkw=www%20dyson%20com&pmt=e&gclid=CMiznc6jltECFQxwvAodKE8MQQ
Posted on Dec 28, 2016
Dyson DC62- I've cleaned all parts of the roller head, checked filters, connections The roller will start then top seconds later. Is there more that I can do or do I need to replace the whole part?
Have you checked that there is nothing behind the roller or in the outlet 'neck'/pipe which is still blocking the roller-head.?
Have you checked that the machine is actually sucking properly at the forward nozzle.?
Have you checked that the locking end caps on the brush roller have been twisted back into their 'locked' positions.?
Best of luck
Mar 17, 2018 | Dyson Vacuums
My bristles wont spin
Hi Maggie,
Alec from VacuumSpot here. There are 3 reasons why the brushes might stop.
The first and easiest is to check if the turbo head is set to carpet - there is a selector on the side that also acts as a bit of a filter. It's an obvious one but sometimes overlooked.
The second and cause is also easy to fix is if your filters are worn or dirty. You wouldn't notice a marginal drop in suction from day to day but over a year the filters do reduce in performance. Once they wear (I know they are meant to be lifetime but they are not) they just need to be replaced. For the best performance just buy new DC11 filters every couple of years they are cheap and it's worth it.
The other thing can be that the roller brush is in need of a good clean. Remove the base plate and pull the rollers out to either side, you will find they simply slip off the shaft with a bit of effort. Clean inside the brushes and also the shaft. Normally you will find a bunch of hair and fluff inside which can slow the roller down.
If you clean this and also make sure you have clean filters and the roller still doesn't spin unfortunately the bearings in the head are wearing and the head needs to be replaced as Dyson hides the bearings in a sealed casing forcing you to replace rather than repair.
I hope this helps you out.
Regards
Alec
Dec 08, 2012 | Dyson DC11 All Floors Bagless Canister...
I have a DC07 which is not picking up very well. I've cleaned the pre motor filter, was not aware of the post motor and will check. However, do the Dyson brush rollers wear to the point of not picking up...
Hi The filter is only part of the cleaning process with a Dyson.
I would suggest you get a 2 p peice and unscrew the plastic screws on the base. You will likely find that this area has clogged up. Clean this area out and put soleplate back on.
Also check your u bend and at the side of the Dyson there is a a piece called the valve carriage which also comes off.
You can put your filters, u bend and valve carriage release in the washing machine.
Feb 23, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The turbine head on my dc08 will not turn although there seems to be lots of suction
The dyson have a bit of an achilles heel with their turbine heads. Half the time you can resurect them by simply removing the baseplate and pulling of the rollers and emptying out all the **** that seems to accumulate inside the brush roller. The other half of the time that same dirt has worked its way to the centre part that holds the rollers, this is where the bearing is and unfortunately there is no way to access the bearing to change it. Not the best design really. If you clean the inside of the rollers very regularly you will not have this problem but who remembers to do that kind of maintenance often enough.
If you need to buy a turbine head to replace a broken one try vacuumspot or nelsonvacuums if you are in Australia.
Hope this helps you.
Jan 03, 2011 | Dyson DC08 Cylinder Bagless Canister...
No suction - Dyson vacuum
Hi If the Dyson is throwing out dirt at the back, it could be three possibilities:
1) The main floor head suction channel is blocked. Check the sole plate where the beater bar is, or if you have a cylinder/pull along model check the floor heads and main extension pipes.
2) Check all the inspection tubes especially the bottom part where the main handle hose is. Also check the filters are clean as well as the Cyclone shroud honeycombs are completely unclogged. Use of the upholstery brush is ideal for dust removal on the cyclones.
3) Check the main inspection areas on the Dyson as sometimes a back log of clogged dirt can get stuck. Also check the dust channel points when then bin is taken out.
Hope all this helps!
Jun 19, 2009 | Dyson Vacuums
Dyson o7 animal pick up problems
Hi.
If your machine is A few years old it may need new brush roller fitted.
To check roller for wear lie machine on the floor & pull back head end as if vaccuming carpet.
Now get A rule or straight edge hold this over brush roller & sole plate oppening.
Now rotate brush slowly by hand the bristles of the brush should just kiss the edge of rule. If ther is a gap you will need toreplace the roller.
http://dysonmanuals.llc.nu/
Jan 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Clogged filter
I found that the rubber seal on the bottom of my cyclone is not properly seated to the bottom of canister, I guessed when I removed the clear canister bin completely from cyclone unit for cleaning, I put the cyclone down on the floor and rubber seal accidentally move upward just a little. this creates a small gap on the bottom when I reassembled it, (since seal is up from it original position a little). I pulled rubber seal down to its original position, you will notice that there should not be a gap on the bottom at all, this way you do not have to clean or should not have to clean the filter but once a month or even less.
Oct 31, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Spitting Out Debris
the hose from brush go to the bag need to check for blockage you have to open there hose to clean
Aug 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
