Question about Sanyo CE22LD94DV-B 22 in. LCD TV/DVD Combo
Sanyo tv and DVD CE22LD94D.and same model without DVD, both say no signal, other TVs are fine, but the little blue light is on but not the bigger one above it, same in both teles, don't reply if costs
5 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Posted on Apr 12, 2007
  • 556 Answers
SOURCE: Sanyo 25" tv
blue clock set screen. is seen due to no signal as due to Accidently hit remote might have got defective or setting must have disturbed. refer owner's manual which you must have received during buying set. good luck
Posted on Sep 24, 2007
  • 298 Answers
SOURCE: No progressive scan from component input
Sanyo DS27930 does not support progressive scan
DVD player must be set to interlaced scan
Posted on Nov 24, 2007
SOURCE: We have 42" Sanyo tv
Check first the menu setting.If the setting is in VIdeo or in Tuner.
Posted on Sep 04, 2011
How best connect external DVD to TV: Composite or Component? Both available on both units
If the TV does have a component input, that will be your best choice. Component video provides an HD signal; composite is only an SD (480i) signal. However, if the TV doesn't have 3 RCA ports (red, green and blue) for the video itself, in addition to the red/white RCA audio ports, you may be missing an adapter that allows the port to be used properly. You'll need to set the TV to the external video input with a Source or Input button on the TV or the remote. If you press the DVD button on the remote, the TV will only attempt to get the signal from the internal DVD.
Please add a comment with the make and model of your TV for additional information. A number of TVs (like some LG models) share the composite and component inputs and use an adapter to reduce the input to a smaller area on the TV. Without the adapter, the TV can't correctly identify the signal. The component video adapter for my LG TV looks like this: http://www.amazon.com/LG-OEM-Original-Part-EAD61273107/dp/B00C5HXILE . There's a second one for the audio signal.)
I hope this helps.
Jan 06, 2016 | Philips Televison & Video
Tv shows a blue screen with no signal counts down from 5.00 minutes to nothing
Check and replace its tuner. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 11, 2015 | Sanyo Televison & Video
Sony Trinitron screen turned pink
Hello
Absence of green is the problem. You see mixing of red and blue, which will look like pink.
the fault must be of its video output card. This card can be located at the neck of the picture tube. Check this card, for any loose solder. This is a common problem seen in most CRt based Sony TVs.
Just resolder all the suspected solder points on this board, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals.
images of two models of sony trinitorn TVs, [back cover opend] has been attached here. you can see the boar under suspection, along with the picture tube neck. [See the rectangulat printed circuit board attached to CRT base]3_9_2012_2_12_06_pm.jpg3_9_2012_2_12_38_pm.jpg
Mar 08, 2012 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Hooking up a dvd player
If the three cables are yellow, white, and red, then the red doesn't need to be plugged in. The yellow is for the video signal, the white is for one sound signal, and the red is just for a second sound signal (not necessarily important). Everything will work fine if the red cable isn't plugged in at all.
Apr 01, 2010 | Emerson SpongeBob SquarePants TV
I have a PS42B541 plasma TV and a 1080P9 DVD player, but the HDMI interface is not working at all. The DVD player is sending the video signal to the TV, but not the audio signal. Also Anynet is not working...
This is a compatibility problem between this model of samsung dvd player and samsung B model tvs. the only solution to fix this problem is disabling anynet option on samsung B model tvs.
Mar 02, 2010 | Samsung DVD-1080P9 DVD Player
Why wont my digital tv work now?
External antenna is not adequate. Need more and bigger antennas for digital TVs. Also, several BAD problems with digital TVs - including weaker signal, picky signal, inability to use in a moving vehicle (kids can no longer watch TV while moving from place to place). More expensive receivers, not normally useable in remote places (like you could with analogue).
Rarely, two or 3 antennas on a vehicle will allow for some reception in a slow-moving vehicle - otherwise, portable digital TVs are useless.
Oct 20, 2009 | Jensen VM9510 Car DVD Player
Nov 24, 2007 | Sanyo DS27930 27" TV
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
Sanyo 25" tv
Sep 23, 2007 | Sanyo AVM-3659S 36" TV
Sanyo CE22LD94DV-B 22 in. LCD TV/DVD Combo Logo
19 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
