Onderdelen leverancier torpedo crosstrainer, wie kent deze?
Gaat om onderdelen
Bajanguru
  • 7752 Answers
SOURCE: Vast staan
sorry english
Posted on Aug 26, 2008
  • 9 Answers
SOURCE: ik heb geen handleiding voor mijn hp ivent agency
I think you have an HP iPaq rz1710. If you Google "iPaq rz1710 manual" you will get several hits for English-language manuals.
Posted on Feb 22, 2010
rajdeepdutta
  • 2517 Answers
SOURCE: mp190 geeft E3 code aan gaat om een canon
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Jan 12, 2011
SOURCE: Ik ben in het bezit
Ik spreek geen Nederlands
http://translate.google.com/#
Bevriezing ijs bevat Gardena timer Breake plastic onderdelen.
Gebroken plastic is veel voorkomend probleem. Verschillende mensen vragen over dit probleem.
Ik denk niet dat lijm zal het werk.
De waterdruk zal breken de lijmverbinding.
Gardena bedrijf zou verkopen onderdelen. Maar ik heb net gezien dat een internet bedrijf verkopen Gardena onderdelen.
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
http://www.gardena.com/
Posted on May 07, 2011
technolust
  • 340 Answers
SOURCE: De telefoon is geblokkeerd en
Your PUK code is set by your carrier. You'll need to phone them for it.
Posted on May 11, 2011
On this drill , to which side is the slider for the hammer drill. Looking from the top, to left or right ?
Wat voor een merk machine en welk model hebben we het over
Naar links of rechts draaien gaat tegenwoordig vaak met de kantelbare koolborstelhouder aan de achterzijde bij de ventilatiesleuven. anders met een kleine hendel welke onderaan de handgreep zit of een hendeltje boven de schakelaar als het een klopboor betrefd ipv een roterende hamer altijd rechtsom draaiend (altijd dezelfde draairichting gebruiken voor de klopstand net als je een gat kan boren de klopstand is de stand meestal recht bovenop de machine is welke pas als je de machine op een werkstuk zet merkt dat deze in de klopstand functioneert want bij alleen draaien van de machine zonder tegendruk op de boorkop hoor en merk je niets in tegenstelling je dat wel bij een roterende hamer kan horen welke een volkomen ander werkingsprincipe heeft en met een duidelijk hoorbare slagcilinder en slagstuk werkt. een klopboor machine is niet bijzonder geschikt om in echt zwaar beton te boren maar in steen is het afdoende tevens is het niet gebruikelijk om gaten voor te boren in steen wat in metaal wel gebruikelijk is , een roterende hamer is wel geschikt voor beton , maar een roterende hamer is eveneens meestal (uitgezonderd merken als Hilti en Duss )niet gemaakt om langdurig achtereen te gebruiken en vooral niet om langdurig breekwerkzaamheden mee te verichtten. de breekhamer is wel speciaal gemaakt voor langdurige belasting en met name de machines welke op lucht werken.
Apr 13, 2016 | Hammer Drills
Tip
Cavity wall insulation
Er zijn altijd creatieve Vlamingen die denken dat elke subsidie meegepakt moet worden. Zo gaan zij proberen om de optimale hoeveelheid subsidie te krijgen van de overheid. Wat doen deze mensen die gaan nieuwe kozijnen plaatsen. En als ze dat doen in combinatie met het na isoleren van de spouw (spouwmuurisolatie), dan krijgen ze 2x zoveel subsidie voor de nieuwe kozijnen als zouden zij dit niet doen. Maar zoals altijd is het niet aan elke slimmerik gegeven om deze subsidie binnen te halen. Ze hebben wel het papierwerk ingevuld en bij een bevriende aannemer een factuur gehaald voor leveren van de dienst. Echter wonen ze in een huis wat is gebouwd begin jaren '90. Nu is de overheid niet helemaal van gisteren en stuurt een controleur ter plaatse. Het is namelijk zo dat huis met een spouw werden gebouwd tussen 1920 en ongeveer 1980. Daarna werd er glaswol in de spouwmuren geplaatst voor een optimale isolatie. Wanneer men wordt gepakt voor een dergelijk vergrijp, dan wordt niet alleen de subsidie niet uitgekeerd, maar ook wordt er een strafrechtelijke procedure opgestart. Deze wordt niet alleen tegen de fraudeur ingesteld, maar ook richting de aannemer. En voor deze partij kan het nog wel eens veel grotere gevolgen hebben, omdat men geen opdrachten meer krijgt van de overheid. In het slechtste geval raakt de firma zijn aannemingsnummer kwijt wat wettelijk verplicht is.
Maar gelukkig zijn er ook brave Vlamingen die een keuze gaan maken om de spouw te laten opvullen. Hierbij moet men vooral niet uit het oog verliezen dat de technieken op elkaar lijken, maar datgene wat er in de muur wordt gespoten zeer verschillend kan zijn.
Spouwmuurisolatie, de verschillen
Er zijn een aantal stromingen gaan, maar steeds meer aannemers kiezen de wijze van isolatiemateriaal waar het grote publiek om vraagt. Je kan als aannemer wel kiezen voor andere isolatieproducten, maar dan mis je op de lange termijn de boot. Daarbij is het aantal na te isoleren huizen niet oneindig. Eens dat alle huizen in Vlaanderen zijn aangepakt moet je het terrein verleggen naar het buitenland. Hierbij moet je denken aan alle landen waar men te maken heeft met slagregens. De spouw tussen de buiten- en de binnenmuur moest er voor zorgen dat alleen de buitenste muur vochtig kon worden en er geen 'koude brug' werd gemaakt met de binnenste muur. Indien dien dit wel zo is, ontstaat optrekkend vocht. Dit geeft uiteindelijk schimmelvorming in huis.
Spouwmuurisolatie producten
De ingespoten producten zijn:
Glaswol
In de muur wordt inblaaswol ingebracht wat een soort glaswol is. Deze is het meest populair in Vlaanderen.
EPS Parels
Er kan ook worden gekozen voor EPS parel. Deze bestaan in verschillende kleur, maar het rendement is sterk afhankelijk van het gekozen type korrels. Deze manier van is minder brandveilig en geluidisolerend dan glaswol.
PUR-schuim
Als het gaat om het vochtwerend maken, dan is PUR-schuim het beste materiaal, maar is niet echt goed voor de gezondheid en daarbij ook niet echt milieuvriendelijk, omdat het moeilijk te recycleren is.
Steenwol
Steenwol is gelijkbaar met glaswol, maar heeft als nadeel dat allerlei ongedierte zich er in nestelt en het materiaal op eet. Deze gaan wel dood, maar weg is weg.
Wanneer u zich gaat verdiepen in de materie van het isoleren, dan kijkt u het beste op http://www.isolatie-vlaanderen.be./
on Jan 13, 2016 | Insulation
Gaarne toezending activeringscode
Cees, Deze site probeert mensen te helpen met technische vragen. Daarvoor is het belangrijk, dat er een duidelijke vraag wordt gesteld. Ik denk dat het voor jou niet moeilijk is om te zien welke GPS je hebt, maar voor ons is het een compleet raadsel.
Mogelijk heb je een apparaat gekocht, dat je na aankoop moet activeren, maar dat moet je dan toch echt doen op de site die hoort bij het merk dat je hebt gekocht. Meesal staat het gewoon op de doos of in het handboek in de doos. Met site naam en wat je allemaal moet invullen voor de activering.
Als het niet om een nieuwe GPS gaat, maar als je zelf een kaart ergens vandaan hebt gehaald, moet je echt andere wegen bewandelen om achter de activering te komen. Daar zijn vooral in Nederland veel sites actief, die, weliswaar tegen een geringe vergoeding, alle mogelijkheden ter beschikking stellen om in oudere apparaten nieuwere kaarten actief te maken. Maar het past niet op deze site daar al teveel over te zeggen. Dus zelf even google gebruike.
Als je een technische vraag hebt, is het handig als je zoveel mogelijk gegevens geeft over het apparaat, het operating systeem en over de situatie waarin het is, alsmede hoe het in die status of situatie is gekomen.
apparaat : merk en model
OS bijvoorbeeld Windows XP of Mac OS 9.6 Of als het om een GPS gaat, bijvoorbeeld welke boot loader en welk systeem erop draait.
Sorry dat er na zo'n lang verhaal geen oplossing is, maar ik heb goede hoop als je iets technisch hebt we je wel kunnen helpen.
Oct 01, 2014 | GPS
Ik ben in het bezit van een GARDENA C1060 profi. Ik heb er geen garantie meer op en heb deze opengeschroefd. Het huis heeft een scheur, waardoor deze gaat lekken. Het water spuit eruit. Is er geen...
May 07, 2011 | GARDENA Water Timer
Deze webpagina is niet beschikbaar Fout 324 (net::ERR_EMPTY_RESPONSE): Onbekende fout
Probleem Dit bericht wordt weergegeven wanneer Google Chrome de gevraagde webpagina niet kan vinden en laden. Oplossingen Het webadres en uw internetverbinding controleren Controleer de URL in de adresbalk om er zeker van te zijn dat u naar het juiste webadres gaat. Als u zeker weet dat u naar het juiste webadres gaat, controleert u of u dezelfde webpagina in een andere browser **** openen, zoals in Internet Explorer of Firefox. Als u de webpagina in geen enkele browser **** bekijken, is de webpagina wellicht tijdelijk niet beschikbaar. U moet er ook voor zorgen dat u een goede verbinding heeft met internet. De fout controleren die u ontvangt Als u met een andere browser de webpagina wel **** laden, maar niet met Google Chrome, controleert u de specifieke fout die u ontvangt. Klik hiervoor op de link 'Meer informatie over deze fout' op de pagina. Als u 'Fout 124 (net__ERR_WINSOCK_UNEXPECTED_WRITTEN_BYTES)' ontvangt, raadpleegt u het artikel over probleemoplossing voor fout 124. Voor de volgende fouten probeert u de onderstaande oplossingen:
  • Fout 2 (net::ERR_FAILED): onbekende fout
  • Fout 104 (net::ERR_CONNECTION_FAILED)
  • Fout 105 (net::ERR_NAME_NOT_RESOLVED)
  • Fout 102 (net::ERR_CONNECTION_REFUSED): onbekende fout
Mar 10, 2011 | Google Chrome
De magenta cassette van mijn epson 7800 geeft steeds signaal "cassette is leeg -vervangen" de cass is niet leeg en als ik een nieuwe insteek blijf ik steeds hetzelfde signaal krijgen. ik heb al...
Ik neem voor het gemak aan dat het om de originele cartriges gaat.
Je zou eventueel de chips van twee inktpatronen onderling kunnen uitwisselen om te zien of de klacht met de chip mee verhuist of zich enkel bij Magenta voor doet.
Verhuist de klacht naar een andere kleur is de chip defect, blijft deze enkel bij magenta problemen geven dan kan het zijn dat de contacten in de inkthouder welke de tonerchip uitlezen niet in orde zijn.
Jan 06, 2011 | Epson Office Equipment & Supplies
Mijn vraag is, dat ik een jumbo universal remote controler heb gekocht maar deze niet kan laten functioneren, ik zou dus willen weten hoe je hem kunt installeren op betreffende apparaten? Ronald.
Normaal zouden instructies meegeleverd zijn.
Ik neem aan dat het om de grote zilveren afstandsbediening gaat ?
1- zet het apparaat wat je wilt bedienen aan
2- druk de knop "code search" ongeveer 3 seconden in tot het lampje blijft branden.
3- druk op de knop tv/dvd afhalkelijk voor welk apparaat je programeert (led knippert en blijft aan)
4- recht de afstandsbediening naar het te programeren en druk met korte pauzes op de stand-by knop tot het apparaat zich uitschakelt (het led knippert bij indrukken telkens een keer)
5- waneer het apparaat uitschakelt is de code gevonden en dient deze worden vastgelegd door op de knop "enter" te drukken (led schakelt uit)
engelse instructies staan hier
Dec 25, 2010 | Universal Remote Control Remote Control
Waste ink near full
I'm having the same problem. Lots of solution for resetting the printer, but none of them helping me to lead me to the absorber itself inside the printer. It seems to be a lot of work and disassembling half of the printer! Looking on internet I haven't found any answer yet.
As I am living in The Nehterlands I'm looking for solutions in Dutch. One solutions discribes disassembling another Canon printer. This could possibly help. I'll paste the text below. It's dutch, so you'll have to translate it.
Wishing you succes with this matter!
Dutch text:
Wat te doen bij de melding 'Afvalinkt bijna vol'?
Onderstaand verhaal geldt voor de Canon SmartBase MPC200; voor andere Canon
printers geldt ongeveer hetzelfde, met uitzondering van de reset-procedure (zie
hieronder).
Oorzaak
Onderin de printer bevindt zich een langwerpig, dik vloeiblad (een soort spons van
vilt). De overtollige inkt, bijv. de inkt die gebruikt wordt bij het reinigen van de
koppen, wordt afgevoerd naar deze spons. Als deze spons bijna verzadigd is,
verschijnt bovenstaande melding. Dat is ook nodig, want als je gewoon door zou
kunnen gaan, zou de spons geen inkt meer opnemen, en op een bepaald moment zou
je merken, dat de printer zou gaan 'lekken'. Geloof me, dat wil je niet meemaken.
Printerinkt is gemeen spul!
Canon
Het lastige is alleen, dat Canon nogal moeilijk doet over deze melding. Zij hebben
maar één oplossing: opsturen en het probleem door hen laten verhelpen. Kosten: ruim
€ 100,-!!! Toen ik dat van de telefonische helpdesk hoorde, reageerde ik met: "Dan
kan ik beter een nieuwe printer kopen!" De telefoniste was dat eigenlijk wel met mee
eens.
Zoeken
Vervolgens ben ik gaan zoeken op het internet. Wat je daar niet kunt vinden, bestaat
niet, tenslotte... Toen merkte ik al snel dat ik niet de enige was met dit probleem.
Iedere eigenaar van een Canon-printer krijgt er na verloop van tijd mee te maken.
Helaas was er geen kant-en-klare oplossing voor mijn printer, maar door de
beschrijving bij andere printers kreeg ik wel een idee over de oorzaak van het
probleem en wat ik eraan zou kunnen doen.
Oplossing
Over de oorzaak heb ik al geschreven. Over de oplossing gaat het nu. Die gaat in twee
stappen:
1. De vilten spons schoonmaken.
2. De printer resetten.
Dit is een vies werkje. Doe een schort om en gebruik huishoudhandschoenen! Inkt in
je kleren gaat er niet meer uit en op je handen duurt het een hele tijd!
De spons ligt helemaal op de bodemplaat onderin de printer. Je moet dus een beetje
handigheid hebben en niet bang zijn om een schroevendraaier te gebruiken.
Schroef eerst de beide zijkanten van de printer los. Die zitten elk met twee schroeven
vast (één aan de voorkant en één aan de achterkant).
Verwijder dan het toppaneel (met de scanplaat). Die zit vast met twee schroeven aan
de achterkant en drie aan de voorkant (deze drie zitten aan de onderkant van het
bedieningspaneel). Let op: zodra je het toppaneel verwijdert, merk je dat die op drie
plekken vastzit. Op één plek met een schroef (gewoon losdraaien) en op twee plekken
aan de elektronica. Trek die twee punten voorzichtig los. Je kunt het toppaneel nu
opzij leggen.
Dan moet je de printplaat verwijderen. Maak eerst alle 'draden' voorzichtig los. Kijk
goed hoe het vast zat, om het later weer te kunnen bevestigen. Maak dan de printplaat
los (4 schroeven). Verwijder daarna ook de metalen plaat, waarop de printplaat vast
zat.
Je bent er nu bijna. Het bovenste deel van de kast (voor zover die er nu nog staat) is
op de vier hoeken met schroeven bevestigd op het onderste deel van de kast. Je moet
misschien wel even zoeken, want ze zitten diep weggezakt. Schroef ze los.
De bovenkant en de onderkant zijn nu los van elkaar, maar nog wel met draden en
elektronica aan elkaar verbonden. Maak die verbinding niet los, dat is niet nodig.
Doe nu het schort om en de handschoenen aan!!
Je kunt nu bij de bodem van de kast komen. Daar zie je de spons, die zwart is van de
afvalinkt. Kijk eerst hoe de spons erin zit, voordat je die eruit haalt.
Maak de spons voorzichtig schoon. Niet wringen en zo, alleen uitspoelen en eventueel
induwen om de inkt en het water eruit te halen. Ga een flinke poos door, totdat er
alleen nog schoon water uit de spons komt.
Hang de spons een paar uur te drogen in de zon. Gebruik daarna een föhn om ook het
laatste beetje vocht eruit te halen, zodat de spons weer kurkdroog op zijn plek gelegd
kan worden.
Zet de zaak nu weer in elkaar. (Als je het net zo doet als ik, houd je twee schroefjes
over, maar mijn printer doet het nog steeds prima. )
1a. Niet schoonmaken maar bestellen...
Sinds kort weet ik dat je de spons ook kunt bestellen. Dat scheelt een boel pruts- en
schoonmaakwerk.
Je kunt de vilten spons, die uit 2 onderdelen bestaat, bestellen bij ETB (Electronic
Trading Benelux).
Bel naar 0165-850500 en bestel de volgende artikelen:
HC1-0795-000
QA4-0213-000
Toen ik ze bestelde (in maart 2006) waren de kosten voor deze 2 onderdelen samen
maar E 1,04!!
Deze prijs was wel exclusief btw en verzendkosten. Maar omdat ik het samen met
andere producten bestelde, had ik daar geen last van.
Als je nu de printer weer aanzet, kun je merken hoe dom het apparaat is. Hij heeft niet
in de gaten dat de spons weer schoon en leeg is. Dat moet hem nog verteld worden.
Op het internet kon ik daar geen geschikte procedure voor vinden, dus ben ik maar zo
brutaal geweest om Canon op te bellen. Eerst deden ze afwerend (ik moest de printer
opsturen), maar toen ik vertelde, dat ik het grootste deel van het werk zelf al gedaan
had, kreeg ik een technicus aan de lijn, die me stapsgewijs uitlegde wat ik moest doen.
De stappen laat ik hieronder volgen:
1. Zet de printer aan
2. Druk op de (langwerpige) menuknop
3. Druk op de meest linkse ronde knop (Copy)
4. Druk op de ronde knop rechts daarvan (Scan)
5. Druk twee keer op de meest linkse ronde knop (Copy)
6. Druk op het min-symbool (links van OK); het scherm zegt nu: 'Test mode'
7. Druk op OK
8. Blader met het plus-symbool (rechts van OK) tot het scherm zegt: '#8 Printer
Test'.
9. Druk op OK
10. In het scherm staat nu: '8: Printer Test' en daaronder: '- 8 - 2 +'
11. Druk 1x op het plus-symbool; in het scherm staat dan: '- 8 - 3 +'
12. Druk op OK
13. In het scherm staat nu: '[0]: Ink Count'
14. Druk op OK
15. Druk op de knipperende oranje knop om die uit te laten gaan.
16. Mogelijk werkt dat niet. Trek dan de stekker uit het stopcontact.
17. Wacht even. Doe de printer weer aan.
18. Als het goed is, ben je nu bevrijd van de irritante melding over afvalinkt.
Succes!!
Nov 04, 2010 | Canon PIXMA MP750 All-In-One InkJet...
Hoe oud is deze wasmachine(lavamat 88840-w type nr 15190302) verwarmings element en thermostaat zijn goed maar toch wast ie koud!!! dus hoogwaarschijnlijk electronica stuk??? moeite nog waard om hem te...
Ik heb een lavamat 88840-w wasmachine en het deurslotje is net gebroken. Er zit nog een stukje in het deel van de wasmachine, Wie weet waar ik onderdelen kan kopen voor deze machine en hoe ik bij het slot gedeelte in de machine kan komen.
Feb 23, 2010 | AEG Lavamat 88840 Front Load Washer
k24674
