Question about Shark Vacuums
Power nozzle for a shark rotator vaccum. Power Nozzle for NV652, NV752
  • 15 Answers
SOURCE: electrolux power nozzle not working
FIRST OFF EACH OF YOU HAS A COMPLETELY DIFFERENT MACHINE. ESPECIALLY THE OXYGEN WHICH IS MADE BY THE "NEW" ELECTROLUX. THE OTHER TWO ARE MADE BY THE "OLD" ELECTROLUX WHICH IN NOW CALLED AERUS. THE ADVICE WITH THE GUARDIAN TO GET IT SERVICED BY THE DEALER SINCE THE POWER NOZZLE IS PROBABLY STILL UNDER WARRANTY IS A GOOD IDEA. (THE 25 YR. WARRANTY DOESN'T APPLY TO THE WHOLE MACHINE SO YOU HAVE TO READ CAREFULLY WHATS COVERED. THE MAIN MOTOR DEFINITELY IS.)
ASIDE FROM ALL THAT
DID ANY OF YOU HIT THE RESET BUTTON ON TOP OF THE POWER HEAD?!
Posted on Apr 10, 2008
Agent Don
  • 310 Answers
SOURCE: no power in power nozzle
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=493359
No power in power nozzle
Posted by pjs5451 on Apr 06, 2008
Vacuumed with power nozzle one day working fine took attachment off to use crevice tool reattached power nozzle and no power whatsoever.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow Power Nozzle does have a reset button on the newer model on the top of the power nozzle, just push it and it should reset, or check all your pigtail connections to make sure they are connection and the cord leading to the actual Rainbow Vacuum itself. Out in left field might be that the power nozzle motor could be shorting out or not working or dead and might be in need of replacement. Check the cord for any frays or bad connections. If you have a problem please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 12, 2008
#1 Taper
  • 1040 Answers
SOURCE: Miele power nozzle quits after 10 seconds of working.
Even though the brush is spinning, you probably need to replace the belt2_bing.gifbecause it is stretched. It is probably slipping on the beater bar.
Jim
Posted on Dec 03, 2009
ThinkVacuums
  • 144 Answers
SOURCE: Need a new electrolux power nozzle model N106m
If you're looking for a new head for your vacuum. Then you're going to have to replace it with the same type of nozzle.
However, wall inlets are standard so you can purchase any kind of attachment kit and it'll fit your inlets and work with your system. Their are many online retailers that offer a wide range of kits that will fit your system.
Posted on Mar 23, 2010
VacuumRepair
  • 438 Answers
SOURCE: Need to replace belt in Kenmore Vacuum Power-mate nozzle
Here's what you'll need to replace a belt on a Kenmore canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
There are two different types of belts that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking. On most Kenmore models it's either a grey switch cover to the right of the neck for your power nozzle, or it could also be a little red colored pole. The reset switch will turn all power off to the power nozzle. If you turn on the vacuum, and try turning on the power nozzle and you hear absolutely no noise, then it's possible it may just need to be reset. It also could mean that your hose may have a short circuit in it (pretty common on Kenmore), and the hose is not getting power down to the power nozzle. If however you turn on the power nozzle, and you can hear the motor in the power nozzle come on when you switch it to carpets, then mostly likely your belt needs to be changed. On the model that I was fixing, the reset switch is a grey color, and I highlighted the reset switch in red:
So we'll just say for this repair that you are able to hear some noise come on in the power nozzle, but the brush is still not turning. This indicates a bad belt. Here's how you can fix it:
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. Look on the both the left and the right sides of the power nozzle. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Step 5. Once the top housing has been removed you should now either see a white semi-circle shaped housing over top of the brush, or your model may not have this part (some did and others didn't). If yours has a long white part over top of the power nozzle, look at the back corners of this white colored housing, and you'll see two clips, one on each side. You need to push these clips in, and pull backwards at the same time.
Step 6. Once this white colored housing has been removed, or if you model didn't have this housing, you'll now have full access to the roller brush and belt. You should instantly be able to see the belt if it's broken, as it won't be connected to the roller brush. Simply pull straight up on the roller brush to remove it from the vacuum cleaner:
Step 7. Wrap one end of the belt around the metal motor shaft in the back of the nozzle. Wrap the other end through the roller brush, and stretch the brush back into the housing where it belongs. Simply reassemble the parts, and test the vacuum to make sure the brush spins!
If you don't hear the power nozzle motor come on when you change the hose from Floors to Carpeting, this either means the reset switch needs to be pushed, or that you have a bad hose that needs to be replaced.
If you would like help on how to diagnosis the electric hose to see if it's bad, please just use the Clarification Request here on Fixya. If you have any other questions, please feel free to ask me, I'm always more then happy to answer follow up questions. If this repair was helpful to you, please be sure to rate it as helpful by clicking the thumbs up icons at the top of the repair.
Thank you very much,
Chris J.
GoVacuum
Posted on Apr 07, 2010
Shark NV350NZ NEED 2Filters 1 foam 1 falt and pipe on rotating head were I get them and price please
Shark Vacuum Parts & Accessories ' eBay
www.ebay.com/sch/Shark-Vacuum-Parts-Accessories/42146/bn_7722312/i.html
  1. Cached
Shark Professional Rotator Lift Away UV560 Floor Nozzle Part NV501 HEAD ... Shark NV400 Rotator Rocket Vacuum Cleaner Motorized Floor Nozzle lower ...
You can obtain parts from the above. Quote model number.
May 24, 2016 | Shark Vacuums
HOw do I get the brush roller to operate on my NV400
Hi, it's Allie from Crucial Vacuum!
To make your Shark Rotator Professional Upright Vacuum's roller brush to run properly, make sure the nozzle or floor base is flat against the floor and the unit's handle is tilted back and engage the brushroll setting. If your unit's red light is illuminated on the floor power nozzle, your unit has a blockage and will not allow the roller brush to run efficiently. Check your unit for blockages, hair strands or debris tangled in the roller brush and/or dirty filters, these may all cause a blockage and loss of suction in your unit.
Last, make sure the canister is properly installed and engaged, making sure it is correctly making an electrical connection with the floor nozzle.
You can purchase direct your replacement filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=NV400
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 04, 2014 | Shark Rotator Professional Upright Vacuum,...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The power nozzle on my c141b model aerus electrolux canister vaccum no longer turns on. It was working when a large stringy object was sucked in. When hitting the red reset button, nothing happens. Is...
It's not a fuse.
Turn the power nozzle on it's top. Try to rotate the brush. If it won't spin, there's till something holding it. Remove all strings, threads, and whatnot from the roller. Try to rotate it again. If it still won't spin, it needs to be taken to an authorized Aerus Electrolux store for diagnosis and/or repair.
Try connecting the hose directly to the power nozzle to see if runs. If it does there's most likely a broken or disconnected wire/cord somewhere in the wands, or the power nozzle. If it doesn't, the problem is with the power nozzle. It could be the motor, although that's unlikely. Other possibilities are broken or disconnected wires or a bad switch. Again, it needs to be taken to the shop to be diagnosed.
Disconnect cord to the power nozzle and examine the prongs on the cord and the terminals in the power nozzle. If there's any discoloring or cracks, they need replaced. Reinsert plug and make sure it fits tightly.
Disconnect cord from wand plug and check for the same things.
Jan 24, 2011 | Vacuums
Electrolux central vaccum works sporadically
The the hose, wands and power nozzle to the nearest AERUS store for repair. You have a short that needs to be fixed. They should just be able to replace the wire assemblies inside the wands, handle and power nozzle.
Jun 09, 2010 | Electrolux Central Vacuum
Rainbow vaccum power nozzle model number r-2800c is getting power but the motor does not run
If all connections are good and taking power, this simply means that you need a new motor.
Good luck
Sep 15, 2009 | Vacuums
Vacuums Logo
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
