Question about Eureka Vacuums
I Have a Eureka central vac that won't start.
  • Eureka Master
  • 1,534 Answers
First determine if it's the suction unit or the low voltage wiring and switches. Close the circuit to see if unit runs, if not it's an internal problem.
Posted on Jan 03, 2017
Central vac is Eureka Altima CV1801M. Tripped the circuit breaker when I turned it on. Discovered bag was full. Replaced bag and now vacuum won't power on without tripping breaker. Any idea what could...
Ok thiese are my specialty. Somemodels have a cloth filter, make sure it is clean. Also check the hose or pipes for a clogg. The best way to do this is turn the machine on, put hose in, if the motor winds up like its labouring there is a clog in ther hose. Do this with every inlet and listen for the same. If the vac. is hot it will not turn back on until it cools. Hope this helps, if not let me know. Chris
Feb 06, 2011 | Eureka CV1801 Bagged Vacuum
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
I am buying a central vac system, can you tell me the better of the easy flo or nutone brand. I want the one with the least problems. It appears to me that the easy flo has fewer problems, thank you
between the two brands... stay away from the nutone. If you can get it, the Beam, Eureka, or even the Electrolux and Kenmore(sears) would still be better. The warranty would be better on the Beam and Eureka (7 or 10 and one model is even 15 years)
Good luck on your purchase.
Mark
Nov 09, 2010 | Easy Flo EF1525 Central System Vacuum
My eureka central vac power brush turns off when pushing forward than back on when pushing back. Ever seen this before?
Yes I repair them all the time. What that means is that the connection of the hose handle to the power brush upper wand is loose. This can happen over time with use. The connection just loosens up. Do you have the exact model of the power brush?
Nov 22, 2009 | Eureka 1810 Central System Vacuum
Getting a Eureka central vac cloth bag back in after cleaning
The easiest way is probably to take the unit off the wall turn it upside down. This will give you some leverage. I would not try to get the ring in all at once, but leave a little out and then that piece that is left out you might need to bend it a little to get it in. There really is no trick that is why I am not a big fan of filtered central vacs. I prefer true cyclonic.
Feb 21, 2009 | Vacuums
Eureka central vac 's power stopped won't start again.
I took to dealer I bought from . He examined it. The motor is gone needs new one. Thanks, Ann
Jan 24, 2009 | Eureka 1810 Central System Vacuum
Continuous running
Central vacs have relays in them, some stand alone, others mount on a circuit board. A stuck relay causes this type of problem. At the unit disconnect the low voltage wires, plug in your unit, does it still come on, if it does then you have a bad relay. If it doesn't then you have a problem somewhere in your low voltage wiring. One of the outlets, the wires may be touching or there is a staple casuing a short.
Mar 05, 2008 | Eureka 1810 Central System Vacuum
Vacuums Logo
62 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
