Unit wont turn off - Heating & Cooling
Pioneer cd player pdc-q180 wont turn and ejects disc, any advice??
have a look inside to see if any forien objects are in the area.otherwise the unit needs to go to a specialist.internal driver unit could be faulty.
Aug 14, 2014 | Televison & Video
My maytag electric oven mer5750 wont turn on OFF is showing up on the screen
If the unit was off, and the on light, not the hot surface light, was on, then when you turned the unit off, the light went off, you may have a bad switch on the unit. You will need to turn the switches on and off one at a time until you locate the switch with a bad terminal. Post back your results.
Dec 09, 2012 | Maytag MER5750 Electric Kitchen Range
Power button keeps blinking dvd player wont turn on
the disc or mechanism may be jammed and the unit knows this, someone (most shops do this) needs to open the unit and safely cycle the disc out of the unit---many times with this done the unit will suddenly work again.
If not and it is not a expensive unit you have the disc back and time to go shopping as most of these are throw away units.
Sep 03, 2012 | Televison & Video
Hip street hs3245 mp3 player wont charge
my problem is my mp3 wont turn on. it turn on just when i plug my hip-streed on my cumputer, but when i disconnect it it wont turn on...
Jan 12, 2011 | Kobian HS-3245 MP3 Player
Circut breaker turned off then turned on dryer wont turn back on (kenmore serial #86982800)
i ve seen this in the field alot of times make sure you actually are getting full 220 to unit.. sometimes these dang breakers look like they are on but they fail to send full power back to unit... it is even happened to me in the field i go to turn power off to a customers unit and when i am ready to turn back on the breaker wont fully reset... check it out if it was working prior to the bresker turned off and you didn't operate on the dryer disconnecting or replacing anything this is your problem...
Jan 02, 2011 | Kenmore Dryers
Air condition wont turn on
Do you have enough power to unit? Check plug for any loose wires on unit, with unit unplugged of course.
Jul 07, 2010 | Fedders A6Y18F7BCOM Air Conditioner
My air conditional unit outside ,fans turns on but the unit compressor wont turn on,just stopped working this morning.i turned the thermostat to 72 but only the fan on the outside unit comes on and it is...
Somethings aperson cant fix without a service tech. First it could be wire burnt of capacitor going to compressor. Second it could be bad capacitor. There is a dual capacitor on the ouside unit one side says herm that runs the compressor. Turn power off to check to see if wire is burnt of the herm terminal or the C ternminal. Wire burnt off compressor common terminal.. Could be locked up compressor. Unless you know how to troubleshoot unit. You may have to call service tech. Cost if bad cap. is about 100 to 150. But unit wont run without it. Rus
Jun 21, 2009 | Emerson Quiet Kool 12HT13 Air Conditioner
Not turning on
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If it wont work replace your Room Air and Coil Thersmistor or test the thersmistor with mulitester. The resistance reading of thermistor is 10 kilo ohms @25deg. C room temp. If it is shorted or open the unit wont operate.
Hope this can help :)
Dec 30, 2008 | Carrier 36KCARMS Air Conditioner
Ilo 32 lcd
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Sep 08, 2008 | iLO 3200 32 in. LCD Television
Maytag 300 Quiet Series Dishwasher
Unit will not turn on..had this unit for 6 months..worked fine..all of a sudden wont turn on now..checked power and connections..all were good..im stumped..just wont turn on.
Feb 15, 2008 | Dishwashers
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
