Question about Cell Phones
How to set it up
Does it have to be charged first, and if so, how will I know when it is charged?
  • kakima Dec 27, 2016
    Hi Deryl Davis, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model is "it"?
Why plugged in not charging
Is the computer at full charge (or at least 90%) prior to the attempt to charge it? I know that my Lenovo is set to not charge from 90% in order to keep the battery from overcharging.
Jul 02, 2014 | Lenovo ThinkPad T410 Notebook
Battery won't charge
In most things I get biofeedback telling me I have either screwed something on correctly, or that I know it's cross-threaded. I know from the feel as I make the connection.
With my UV5R+ and its charger stand, I really don't know if it's sitting in the charger stand and making contact -- unless I see the light turn solid red. That means it's charging.
I have set it in place and it slipped right in, making the light go red. And I have set it ip place, jiggled it and set it again, and have slammed it in, all without success It is of a very poor design.
That may be your problem, you have it "cross-threaded" and don't know it. Have you ever seen the battery charger show Red?
I don't know if my experience is a one-of-a-kind or if it is widespread.
Now, if you do get around the design flaw I have described and the charger does go red, your battery may be faulty. it's not charging.
Feb 12, 2014 | Baofeng UV-5RA Dual Band Transceiver
How do I know it's charging?
If you put a meter across the battery posts, set to dc volts, while it is charging, it should read about 13.5 volts.
Dec 05, 2013 | JUMP START SYSTEM
Air hogs jet set plane won't charge
This situation happened to me too after using it like 10 times it doen't
charge anymore does anyone knw what to do and what is the neutral position for the rudder how does it have to do with charging the plane I know what the rudder is and where it is ,ut don't know how to put it into neutral position.Help???
Jan 20, 2012 | Master Heaters Air Hogs Jet Set Assortment...
Remington Cordless Salon Hair Straightener I don't know if I should charge it when it is set 'ON' or set 'OFF' ? Lost the instructions but seem to remember it was a definite one...
charge it after use ,, allow the battery to go down almost fully , then charge it . this will prolong the life of the battery
May 22, 2011 | Vacuums
HOW DO I KNOW IF MY NANO IS CHARGED
While the Nano is charging there will be a symbol like a "lightning bolt" across the battery.
Once it is finished charging and charge is full there will be a graphic of a plug over the battery.
If the unit is turning off before it is finished charging and you cannot see the graphics you can go into your backlight settings and have it set to stay always on.
Then you will be able to see the plug graphic to tell when it is fully charged.
Hope this helps. Thanks for using FixYa.
Apr 25, 2011 | Apple Audio Players & Recorders
DOES ANY ONE KNOW, HOW LONG A MOBILE CAN BE CHARGED...
OK, on the first original charge that is required when you first purchased this unit, it can charge for at least 8 to 10 hours. this is called a set up charge. After the first original charge, it is recommended to not charge over the set amount of time given by the actual cell unit. your phone will beep or, display a completed charge message after the charge has been completed successfully. if you go over the set charge, this can damage most cell battery's. Standard charge time after the original set charge is 2 hours.
Jun 13, 2009 | Nokia 1600 Cellular Phone
Charging the Razor
I would set it for the max timebecuae, when you charge it for shorter times it ruins the battery faster.
Apr 04, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
