Question about Home
Mansfield pro-fit 4260 tfs jetted tub will not turn off.
3 Suggested Answers
mrhotandcold
  • 248 Answers
SOURCE: i have a leaking jet in a pearl jet tub. it's an
one of the quick ways to fix leaks at jets is by using Millaput two putty resins mixed and worked round the outside of the defective jet hope this helps
Posted on Oct 03, 2009
SOURCE: I have a Mansfield, Swirl-way tub. Jets won't come
on mine water got behind the soft touch controll and corroded the connection see if there is green gunck on the phone like plug
Posted on Mar 12, 2010
Replacing jet
When you installed the new jet, did you install a new gasket on the wall fitting or use 100% RTF type silicone?
In order to seal a wall fitting that is cracked an leaking, the replacement must have either the gasket or silicone to seal the wall fitting against the wall of the tub or it will leak when filled with water.
Rod
U S Parts Center
Jan 03, 2014 | Jacuzzi Home
Can I simply silicone jets in a tub to seal them completely, so the jets don't leak? It's for a rental unit I own, bathroom on 2nd floor. Don't want to tear out the bath tub or ceiling on Main floor.
In order to properly seal the jet in place with silicone you must remove the wall fitting from the inside of the tub. The wall fitting is threaded into the jet body from the inside of the tub.
Once the wall fitting has been removed you can put a small bead of silicone around the underside of the flange and thread it back into the jet body. Clean up the excess silicone after it squishes out with DeNatured Alcohol.
If you plan on just putting a bead of silicone around the outside edge of the jet body behind the tub, do not waste the silicone or your time as it will not solve the leak in the tub.
US Parts Center
Sep 12, 2013 | Jacuzzi - Bathtub - Alcove - Navona -...
Jets will not turn off
Sounds like your air switch is bad in the little box on top of the motor.
It is part # TBS-339
Rod
US Parts Center
888-521-6183
Apr 25, 2013 | Whirlpool 6060 DL Corner Pro-Fit Acrylic ...
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
One of the jet assemblies on my Jacuzzi 325 hot tub popped out and I can't get it to stay back in. i've been pushing it in as hard as I can but when I turn the pumps on it pops back out. Should I be...
once a jet face has fallen out of a hot tub that means the insert has failed and is broken. you will need to locate a new jet insert. Jet inserts have little tabs on them that hold them in place and when they get worn out the jet face will fall out into the tub.
Jan 29, 2011 | Jacuzzi Home
I have a narrowboat which had a mansfield toilet fitted, the toilet has been removed but the tank, pump etc is still there, I would like to refit a pump out, can you get just the toilet or would another...
While toilets can look the same there are several variables as to whether ony particular one would fit. As far as maceator toilets go, they are a little spendy but can do the job when others can't. I sugest you continue your search by googling Saniflo and go from there. There is just no single answer for you.
May 26, 2010 | Mansfield Plumbing Products Mansfield...
Connecting a mansfield whirlpool tub pump don't know the model number pump is in the floor and tough to get to. there are 2 cords hanging out. 1 male end and 1 female end. When I plug in the male end, the...
Hello Joe, Typically when you have a whirlpool type tub, there is either a built-in air switch on the tub that will turn the tub motor, on and off, or the tub needs to have a wall switch to turn it on and off.
The switch has to be located so it is at least a minimum distance of 3-4 feet from the edge of either a tub or shower stall, and it must be connected to a GFCI protected circuit. Normally any whirlpool tub requires a separate dedicated 20 Amp 120 Volt AC circuit for proper operation and to meet code.
I believe that the female plug is for an optional, in-line heater that can be installed into the tub unit. You should be able to check the installation manual that came with the tub to verify the proper wiring required for your specific unit and model.
I would contact the manufacturer to get a copy of the installation guide and instructions for your model, so you are certain that it is properly installed and the wiring you are using meet the NEC (National Electric Code).
Here is a link to the Mansfield web site with some FAQ's and their phone contact information.
http://mansfieldplumbing.com/v3/support02-03.html
I hope you find this Very Helpful and best regards!
Dec 11, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a Mansfield, Swirl-way tub. Jets won't come on. Lights are working, but no action from the jets.
Oct 04, 2009 | Whirlpool Home
My jets in my new tub will not turn on.
You could have a GFCI receptacle tripped or in test mode. look close to tub or in and around tub area for this. This receptacle has a test and reset button on it.
Aug 30, 2009 | Mansfield Plumbing Products Mansfield...
Hot tub jets stopped working
yes my jacuzzi uses air on the suction side to make bubbles. you must have clogged it. how long is tube can you slide a rod in there to check if its blocked?
Apr 16, 2009 | Maax Calla 6042 Bathtub - 101058-000
Home Logo
96 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
