Question about Samsung HP-R5052 50 in. Plasma HDTV
Hi, I have a samsung HP-R5052 plasma TV. The screen started acting up and has washed out colors (yellowish/dimmed colors)
It starts with black patches of pixels then as it warms up those patches go away but the overall picture is washed out, kind of yellowish/pastel color. Do you know what board could be failing ?
5 Suggested Answers
  • 77 Answers
SOURCE: blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Posted on Jun 25, 2007
SOURCE: Samsung HP-R5052 50 bottom hallf screen turns black
its the lower buffer card.. (y buffer lower board) they cost about $90.. i changed mine myself on my samsung hpr-4262 42 inch plasma.. pretty easy,, took approz 20 minutes.. the card has 3 ribbon cables and 3 other connectors and 1 screw.. removing all the screws out of the back pannel took the most time.. i found the repair manual for my tv on line for $13 (download PDF file) the manual had a trouble shooting section and what board to replace for each problem.. got the manual from here http://store.payloadz.com/ ordered the replacement board from www.partstore.com
good luck
troy
Posted on Sep 24, 2008
  • 98 Answers
SOURCE: Samsung HP-R5052 Plasma TV
It related with Power Board(50%) or Y-Main(50%).
But, if you use the power bar with surge protacton, need to check
the power bar's lamp when the TV is turning on & off.
Posted on Feb 06, 2009
romsky79
  • 822 Answers
SOURCE: Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. romsky79@yahoo.com
Posted on May 29, 2009
Troubleshooting
Over 4 years old buyed convex topped capacitors to find ? if not ... then
Buy a canister cold spray open the backsite take a chair and place a mirror in front of your tv spray on the components spray on the passive components like capacitors or on the power supply/ backlight inverter and t-con board . if the right place is sprayed you see something happen on the picture.
Aug 14, 2016 | Samsung HP-R5052 50 in. Plasma HDTV
Bad picture on Samsung HP-R5052 50 in. Plasma HDTV
Hi there!
I suggest changing the screen , it is getting worn out
peace.
May 18, 2017 | Samsung HP-R5052 50 in. Plasma HDTV
No HD pic on Samsung HP-R5250
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
Samsung screen black out
Sir,
your screen has got lose solidation which is usually ocuring in Samsung screen and Philps that is why you are suggested to get your screen resolidated through near by electrition
Aug 28, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
BROKEN SCREEN CAN I REPLACE IT? IF SO WHERE DO I FIND IT
You need to contact Samsung call center or serching web site which Samsung authorized TV reparing company.
Feb 24, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
Jan 31, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
good luck
troy
Jun 24, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
NO VIDEO
I have a Samsung 50" plasma, that has been blacking out over the last 6 months. A 9/2005 set. Now its practically unwatchable as it happens 3 times in an hour. Its not heat related - I have a high volume 9" fan activated on TV power on. Turning the set offf/on usually makes it come back for a now short while. Considering to go put it in the back of my pickup and park it in front of Best Buy and discourage Samsung purchases. This is the 2nd Samsung TV I've purchased (the other a 32" tube) I gave to my folks a couple years ago and its gone bad as well. Samsung product may look good, but their video engineers are not.
Jan 19, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
Samsung 50" plasma tv
search "black green" -- there are at least two solutions offered.
Dec 10, 2007 | Samsung HP-R5052 50 in. Plasma HDTV
Black Screen
I have a Samsung HP5053 Plasma Flat Screen and there was a cracking noise and the picture clarity changed to dull. Does anyone else have information on recalls for this TV?
Oct 25, 2007 | Samsung HP-R5052 50 in. Plasma HDTV
Samsung HP-R5052 50 in. Plasma HDTV Logo
Henry  Thomas
Henry Thomas
