Question about Whirlpool Washing Machines
Whirlpool cabrio model wtw7600xwo runs for a few seconds then shows fault code f
Starts to fill with water then stops
    Top Expert:
  • Whirlpool Master
  • 40,262 Answers
Could be a defective fill valve. The level sensor could be at fault, also.
Posted on Dec 28, 2016
What is the LF Code my washer puts out
Hi Sherry,
The code definition for LF is a LONG Fill (F30). What does that mean is the next question? Here goes.
a. The fill hose may have a pinch or fold between the connections on the pressure in .
b. Are the hose screens plugged at the connections.
c. Is the water siphoning out of the drain hose ?
d. Is the water pressure at peak, check valve, filters before washer.
Now if your savvy hungry. Here is a learning curve link
Washing Machine Diagnostic Test Error Codes Cabrio Bravo Kenmore Oasis .
Okay. The next link is for the manual for your favorite machine. Manuals and Troubleshooting Whirlpool Whirlpool Cabrio Washer Fault Codes . I tried this and you need registration.
I decided to go one step further and track down a printable and savable resource for you. Yes, all, the fault codes and what they mean.
I did pretty good from memory but that link leads you to a printout you can keep right by your washer. Most of the occurrences are easy to fix without a technician. Hope this makes your day. Better. Fare. Well.
Jun 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
How do I fix my whirlpool cabrio washer is showing code sD
Ideally, you just run the washer without any detergent and it'll rinse out all the soap. Try that first. My Cabrio started doing that all the time, then stopped spinning out all the water. It had a host of problems and I opted to replace the washer. Hopefully the water rinse will fix the problem for you.
May 23, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
What dose a FL code mean on whirlpool cabrio platinum
I will try and help for some reason Whirlpool likes to flip letters around which differ from the service manual FL would be an LF long fill or is it a F1 the model doesn't show in the Whirlpool data base nor parts suppliers I suspect wtw6600sb1 does the machine from initial start fill correctly then wash if so we can eliminate the pressure switch and hose after wash cycle unit should drain then fill with rinse water if the inlet valve does not let water into the machine to satisfy the pressure switch the control times out and flashes a long fill code this unit has a log valve system possible you have a bad inlet valve on the bank of valve or a bad control not outputing voltage to the valve, hope this points you in the right direction
Jan 14, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio he washer stopped in drain and spin cycle. Won't drain or spin. drain hose seems clear. Powered off for a few minutes. When I powered on and pushed "start" it poured water in...
You may perform an automatic diagnostic test to check the machine functions and view any saved fault codes. Fault codes may also appear during the test when a problem is detected. Be sure the washer is in standby mode (plugged in with all indicators off, or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, and STOP) and follow the steps below, using the same button (remember the button):
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.
The program then automatically checks for saved fault codes. Record the fault codes and post it back.
Press the same button used above in activating the test to advance through the automatic test steps. The basket must be floating in order to agitate. Allow step C1 to complete before advancing to the other steps. Record any fault code shown during the tests and post it back including which step the code is displayed.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Jul 20, 2011 | Whirlpool Cabrio WTW6800W Washer
Whirlpool Cabrio is showing a error code of F1 what does that mean?
Typically, we're going to be looking at a pressure sensor failure here, although there are a few possible culprits. There's some pretty detailed troubleshooting here:
Jul 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio F1 code
have the same the washer show F1 I have to hit pause start 3 time befor it will wash severly people have the same proble with this whirlpool washer it is a tiner proble i hve been tool.
Jan 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal De
