Question about Hoover Vacuums
Hoover elite rewind, dust escapes when using hose
reddevil6
  • 1673 Answers
SOURCE: Hoover U5507900 Elite Rewind problem
May have to replace the cord reel asm. It will have to be taken out and inspected, if can't see a problem, then replace it. If this is less then one year old, then it is still under warranty and should be taken to a warranty shop along with proof of purchase.
Posted on Jan 15, 2008
  • 126 Answers
SOURCE: Changing the belt
I'm not familiar with that model, as it is fairly new to the market, but the previous models had a plastic plate that covered the roller. There are two clips that must be depressed as you gently pull the plate away from the machine. This will allow the removal of the plate so that the roller can be removed and a new belt installed. This is a new model, so you must have the manual still. You can also check www.hoover.com for more instructions and last time I checked, they had a manual download feature available.
Posted on Jan 27, 2008
SOURCE: hoover eite rewind vacuum has blocked airflow, how do i fix?
i had the same issue, but with a little time and a screwdriver, i got my vacuum working like new.
First, remove the bottom cover where the brush is located. Once the cover is off you'll see the vacuum inlet hose just behind the brush. Clear out any debris you find in there.
Second, on the back of the unit, where the attachment hose connects to the vacuum remove the three screws and clean out any debris you see in there. (dont be afraid to get your hands dirty)
hope this helps!
Country Music Guy
Posted on Apr 19, 2009
SOURCE: Hoover Deluxe Elite Rewind does not pick up
Check the hose and take the bottom plate of the vacuum off to check for obstructions that you can't see right away. Use a wire coathanger (unwound) to push any clog through. I also have dogs and this vacuum. It does get clogged with fur occaisionally.
Posted on May 24, 2009
SOURCE: Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
Posted on Jun 22, 2009
What is the cause of a Very loud noise of Hoover Elite UH72011? Also some dust can occasionally escape.
The most likely cause of a very loud noise is the motor or brushroll. Dust escaping occasionally could indicate a clog somewhere.
Mar 05, 2017 | Hoover Vacuums
What is the belt part no. for a hoover elite rewind?? model no. UH71009RM
If you look up the Hoover page for the UH71009 (the non-remanufactured Elite Rewind), there are 3 different belt model numbers listed. One part number is simply for a 2 pack of the belts. See http://hoover.com/products/details/uh71009/elite-rewind-bagless-upright/ . Click on the Parts & Accessories tab.
I believe the belt part number is 38528058 , http://hoover.com/parts/details/38528058/sra-r-b-562932001-belt/ .
I hope this helps.
Oct 04, 2015 | Hoover Vacuums
No suction
Check the airflow. A hose or filter is clogged, restricting the air flow. Change the filter (or clean it out according to the manual). Most likely, the machine sucked up some liquid, which mixed with dust and dirty clogs the filter. Also check the brush area for any blockage.
Dec 01, 2011 | Hoover Elite Rewind Bagless Upright...
My deluxe elite rewind vacuum spits out dirt
The elite rewind does not have any fancy features. This sound like you have a blockage in the foot or base of the vac. remove the bottom cover to look under. Also check the hose, it can be in there as well.
Apr 16, 2010 | Vacuums
When i use the power brush attachment, dust flies out of the hole that the hose attaches to... is there a way to prevent this or is it just how it works?
this is the nature of this vacuum, the roller will always spin, when the vac is turned on. You can either cover wit tape or maybe find a sock to put in it (remember to remove sock) when putting hose back
Oct 12, 2009 | Hoover U5507900 Elite Rewind Bagless...
HTH!
May 27, 2009 | Hoover Elite Rewind Bagless Upright...
Blowing out dust
The reason most vacuums blow dust is because there is little or no suction in the foot of the vac. on this model, check to make sure that the hose is installed in the recepticle on the back to draw vacuum from the floor. verify the filter is clean, and there is no obstruction in the bottom foot.
Jan 18, 2009 | Hoover U5507900 Elite Rewind Bagless...
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
