Question about Dyson Vacuums
Waiting for new vacum, the inoperable one was returned on 12/14/16 UPS.
I ordered vacumn cleaner bags. Wrong size. How do I send them back I asked for ups to pick up at my house no one has come
firstly you need to contact the seller for return authorization . when they send that they may tell you how to return them
Dec 08, 2016 | Vacuums
It makes a squeaking/scraping sound when you stand it upright while machine is turned on. Only way we can use it is to keep the machine tilted back. The release lever is broken in that the vacuum tilts...
Check belt and roller or take it for vacum tuneup. Tune ups are real cheap, like $20 and they will adjust, replace belt and clean. Well worth it as it is a great quality vac
Feb 10, 2011 | Riccar R100 Vacuum
We were having issues with its lack of suction - we took it to an authorized Dyson repair shop and now sparks are shooting out and its smoking! What the heck is wrong now?
SO MUCH FOR REPAIR SHOPS. WHEN THEY PUT THE VACUME BACK TOGETHER THEY MUST OF PUT IT BACK TOGETHER WHERE SOME THING IS RUBBING TO CAUSE THE SPARKING YOU SHOULD RETURN IT TO THE SHOP AND COMPLAIN, THEY SHOULD NOT CHARGE FOR THEIR MISTAKE
Sep 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Bissell turbo revolution
you can wash that sponge filter by hand but you must let it dry compleatly before putting it back in the machine, I found a filter pack for the lift off vacume at walmart, make sure teh bottom filter is clean as well. the lift off vacume has 3 filters there is one filter in the tray under the dirt cup, one in the top cup, and the hepa filter in the back the 2 foam filters must be clean or you can have reduced suction, the lift off vacume I have I found thrown away because they never cleaned it outthe brush was dirty and full of strings the belt was worn, the hose under the vacume was full and stopped up the hose in the back was compleatly stopped up all filters were compleatly clogged, and the hepa filter was missing entirely. Not to insult you or anyone but i've found that a lot of people are jsut to lazy to clean their vacume out it fills up with dirt they throw it away and get a new one, i've gottten many like new vacumes for this reason, this bissell is working like brand new now. and I just replaced the belt and all filters in it saving me approx. 150.00 for a new one
Dec 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vacuums Logo
26 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
