Question about Car Audio & Video
Mag. CD plyr., CDB586, 6 disc, works ok, but keeps advancing, the CD's, get CD error, only.No snd., no rev.s?Nice mch. don't want to toss it out. Scotty of TO., ON.
Hi laptop error 203 when making recovery disc 2 using packard bell recovery management. the disc is OK & tried restart and doing it all again disc 1 burns ok. what's the answer please
Try another new dvd and it should be a dvd -r. havn't had good luck with dvd + r or dvd r/w when making recover disks.
never try to reuse a dvd or cd that has given you an error. toss it.
Apr 11, 2010 | Computers & Internet
How do I remove cds from a pioneer 12 disc changer with no power?
You can remove the CD's with no power just use a pin to open the CD drive. you can see the a small reset hole to open the drive. You just insert the pin to the small hole and push now you can pull the drive slowly to open and remove the CD's.
Mar 19, 2010 | Pioneer CDX-P1280 12-Disc CD Changer
Have alpine chm s620 ,error message say no disc magazine is loade
have you tried a different magazine.  Could this one be warped?
Apr 03, 2009 | Alpine CHM-S620 6-Disc CD Changer
Disc error
hi, does it take the tray out or stop half way?
the alpine changer mechs have a problem with jamming up.
this also covers the mercedes and BMW models too.
if its just tray 3 thats not working then it could be the tray try swapping the tray around this will rule out the mag/cart/tray. that way we can tell if its the changer or the mag/cart.
if its all trays that it dont work on the try tapping the mag with the handle of a screw driver while its trying to load, this is normally enouight to unjam the loading arm..
Mark
Blue ICE
Feb 24, 2008 | Alpine CHA-1214 12-Disc CD Changer
My disc is not changing and is stuck ( CHM - S620 by Alpine )
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Feb 16, 2008 | Alpine CHM-S620 6-Disc CD Changer
Extracting the cd case without power
try a flat bit of card or ruller. insert it under the cart/mag and wiggle it. you will need to trip the catch, its about half way accross the middle of the magthis wil onlt work if the mag is not half loaded ie the trays are not out.
Mark
Jan 05, 2008 | Alpine CHM-S630 6-Disc CD Changer
TDK dvd+r home copied disc
check drive properties inorder to verify whether ur drive support +R dvd
Nov 30, 2007 | Computers & Internet
Pioneer 10 disc changer magazine stuck
i would like to be of assistance but i need to know the which pioneer 10 disc changer it is. send me the information and i may be able to help. thanks
Nov 26, 2007 | Pioneer 6CD CHANGER
CDAC ER2
CDAC ER2 usually means a cd is stuck, not reading properly, or that the magazine is stuck or broken. take out all cds and try it with a known good cd (one that played ok in the past). if that doesn't work, try unplugging the unit and plugging it back in.
if it still doesnt work, take the magazine out, power it up so that you get the "no mag" error, then insert the magazine with no discs and see if it still errors out with ER2. if it does, then the magazine is bad, or the changer is bad..
if it works, then try the known good disc again, if it works now, your magazine was probably stuck, or one of the other cd's isn't liked by the changer.
hope this helps,
trin
Nov 17, 2007 | Clarion DC625 6-Disc CD Changer
Ejecting CDs
The safest way to remove the cd mag is to take of the outer cover and wind the mech until the mag pops out
Regards
john
Oct 17, 2007 | Kenwood KDC-C465 6-Disc CD Changer
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
