Question about Refrigerators
Ice tray will not come out of the ice maker. - Refrigerators
  • 358 Answers
SOURCE: water leaks from ice maker in ice tray.
When the ice maker calls for water it'll be filling for about 7 seconds if is more the ice maker inside control board is bad , but if there's water in the ice maker all the timeeven after or before it calls for water it means that the water valve (solenoid) that supplies water to the ice maker is leaking and you have to replace it.
Posted on Apr 27, 2009
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Posted on Apr 28, 2009
  • 136 Answers
SOURCE: ice maker is not making ice...no water to tray
there may be a sensor in the bin where the ice cubes drop into. It tells the ice maker when the bin is full so it stops making ice. Check to see if that sensor got bumped or moved or needs to be reset
Posted on Jul 07, 2009
SOURCE: ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Posted on Jul 24, 2009
SOURCE: LG SXS Refrigerator LSC26905 ice maker
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
  1. Remove the ice bin, set it aside (don't forget to deal with the ice melt).
  2. Turn the ice maker off (LG says to unplug the fridge, I didn't).
  3. On the left hand side of the ice tray dumping mechanism there is a screw helping to keep the entire thing suspended from the ceiling of the freezer. Remove that screw- don't worry, the mechanism will stay put for now.
  4. The dumping mechanism can now slide forward- note that you can't completely remove it from the freezer yet, but slide it forward and it will no longer be suspended from the ceiling. Don't let it drop or hang.
  5. You need to disconnect its power supply now. On the left hand side you should see a small bundle of wires coming from the back of the freezer to the dumping mechanism. It connects to the dumping mechanism's set of wires with a pair of white plugs. Pull these plugs apart. You may need to pry the catch on these plugs apart while you pull.
  6. Now you can take the dumping mechanism out of the freezer (and close your freezer).
  7. To remove the ice tray you need to slide the housing that contains the rotating motor out of the housing. This is on the right side of the mechanism. If you have trouble identifying it look at the underside of the entire thing and you'll see a small "test" button. That button is on the motor.
  8. To remove the motor you'll see two catches on the right side- you'll need to pull these catches out without breaking anything. You'll be able to slide the motor down and out when you get it right.
  9. Sliding the motor out lets you get the old ice tray out now. There is probably a set of white wires routed through a little catch on the old ice tray that you'll need to free.
  10. Put the new ice tray back on the motor. You'll need to get the left side secured at the same time you get the motor housing in its catches of the dumping mechanism.
  11. Reroute those white wires back on the new ice tray.
  12. Reconnect the electric wires to the housing.
  13. Slide the entire dumping housing back onto the ceiling of the freezer and screw in on the left side.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
Posted on Aug 28, 2009
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Freezer wont make ice cubes
This is not difficult to troubleshoot.
  • When the arm is up the ice maker is off
  • When the bucket is full the arm is up the maker is off.
  • If the ice maker has a on/off button in off the ice maker is off
  • If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
  • If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
  • If ice in tray and ejector arms vertical several possibilities.
    • Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
    • Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
    • Ice maker motor failure,
    • Internal ice maker electrical connections rotary switch failure,
    The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
Dec 22, 2015 | GE Monogram Side by Side Refrigerator
Ice maker is slow to make ice. It dumps sometimes. it builds a large mountain of forzen ice that mounds up under the tray. even though we remove it it always comes back. ice is also runnig down the...
Ice maker problems are almost always a problem. Sometimes I will locate an issue and fix it and then it will work for a short period and then break again. So, now I just replace the ice maker as a general rule. This is much more likely for success. However, the replacement ice maker is often not an exact match. And again, the this and the that sometimes causes problems. I will never accept a new customer on the grounds that I am going to fix their home ice maker. Make sure the ice machine is getter water like it is supposed to. Check the filter and the tubes. If the problem persists, get a new ice maker. If that ice maker angers you, get some ice cube trays.
Jun 11, 2011 | LG LSC26905TT Side by Side Refrigerator
Bosch Evolution B20CS50SNS about two years old. No ice is dispensed. Looked inside and tray is frozen over solid. Also looks like water has overflowed and frozen down in bin. Could not figure out how to...
I've had lots of problems with my Bosch refrigerator ice maker. The ice tray has a tab on the back corner that twists the tray when it cycle to empty the ice. That tab broke off and when I looked into replacing the ice tray the authorized Bosch dealer said the tray is only sold with the complete ice maker unit. Sells for about $160. I have a hard time spending $160 for another complete ice maker when I only need a $10 replacement ice tray. This ice maker is sub-par for an appliance name brand like Bosch.
Dec 08, 2009 | Bosch Refrigerators
Ice maker drips water into ice tray
Probably the solenoid valve leaks(electric valve that opens when the ice maker calls for water) and overflood the ice maker,the only way to fix this is replacing the solenoid.
Sep 22, 2009 | Kenmore Refrigerators
I have model 3XART720F02 ART706 TYPE 2055A The water ice distribution area needs cleaning. Can this area be dismanteled
Prepare the Ice Maker For Cleaning
Step1Lift the power located above the ice maker storage tray.
Step2Unplug the refrigerator.
Step3Allow the refrigerator and to defrost. This will melt any large blocks of ice that have accumulated in the ice maker
Clean the Ice Machine
Step1Remove the ice machine storage tray.
Step2Dump any water in the ice machine storage tray.
Step3Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
Step4Sanitize the lines of the ice maker. Consult your manufacturer's
directions for steps to do this, because it's not available on all models.
Reassemble the Ice Maker
Step1Replace the ice machine storage tray.
Step2Plug the refrigerator into the outlet to restore power.
Step3Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
How to Clean an Ice Maker
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 21, 2009 | Whirlpool Refrigerators
Sub zero particles in ice from ice maker
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1 Lift the power bar located above the ice maker storage tray.
  • Step 2 Unplug the refrigerator.
  • Step 3 Allow the refrigerator and freezer to defrost. This will melt any large blocks of ice that have accumulated in the ice maker.
  • Step 1 Remove the ice machine storage tray.
  • Step 2 Dump any water in the ice machine storage tray.
  • Step 3 Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
  • Step 4 Sanitize the lines of the ice maker. Consult your manufacturer's directions for steps to do this, because it's not available on all models.
  • Step 1 Replace the ice machine storage tray.
  • Step 2 Plug the refrigerator into the outlet to restore power.
  • Step 3 Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
  • Jul 20, 2009 | Refrigerators
    Roper Ice maker wont kick ice cubes out of tray.
    Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
    Apr 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
    Ice maker not ejecting ice and then tries to fill tray and leaks
    Mar 31, 2009 | Bosch Evolution 500 B20CS50SNS
    2003 whirlpool ice maker doesn't work
    May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
    Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
    Make sure that the ice maker is in "on" mode.
    May 03, 2017 | Refrigerators
    Refrigerators Logo
    27 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
