DC250 error code appearing randomly even chain link 744-350 value setting to 0. please help.
  • 2072 Answers
SOURCE: Xerox DC250 error code 093
either you are out of black toner, or the toner dispenser needs serviced. It is not seeing the proper amount of black ink.
Posted on Apr 23, 2008
tweety607
  • 30 Answers
SOURCE: how to set the value for event log in the registry
If I understand what you are needing to do is to Disable Print Job Notification in Event Viewer for Windows Vista Home Premium
When you are in the registry editor
and at
"System Key: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Providers]
you should have seen and entry, right ?
name type Data
eventlog Reg_DWORD 0x00000000 (0)
To change the DATA value, double click on the NAME Eventlog
A small window will open that says "edit DWORD value"
Value Name: event log
leave this the same, it is not changeable
Value Data:
Change this data to 0
You can go back into the registry to confirm this value was changed, then turn off your computer and turn it back on again.
This should work for you.
Posted on Jun 25, 2009
yescopier
  • 22 Answers
SOURCE: I have a xerox DC250
CHANGE NVM 850-001 TO 0
0 - FDI NOT PRESENT
1 - FDI PRESENT
Posted on Aug 10, 2011
  • 693 Answers
SOURCE: how to set DIPSW 3-1 to 0
You need to set DIPSW 3-1 to 0. You need to boot into mode 25 to do this. If you didn't fix the problem in the fixing station that caused this it could be bad.
Posted on Oct 31, 2011
  • 6702 Answers
SOURCE: Black Toner Cartridge Not Recognized.?
Check the contacts on the toner cartridge and in the printer are clean and shiny. They also must have no dent.
We on Fixya only try to answer questions via this page. We don't send mail.
Posted on Mar 13, 2015
Xerox workcenter m-133 and the error code is 010-313 and how to fix it
Perhaps the info here might be of help to you...
Fuser Related Status Codes & how to reset them:
C123 style (C123/128/133, M123/128/133, Pro123/128/133) 010-313 Fuser Control Thermistor failure (open Control Thermistor) 010-314 Fuser Side Thermistor failure (open Side Thermistor) 010-318 Fuser temperature did not rise quickly enough during heating cycle 010-320nakeder Overheat (must be reset from diagnostics by resetting NVM (Non Volatile Memory code 744-220 back to "0") * 010-327* Fuser took too long to warm up (must be reset from diagnostics by resetting NVM (Non Volatile Memory code 744-220 back to "0") * * C123 style: Resetting Fuser Codes (010-320, & 010-327) Accomplished by resetting NVM code 744-220 to '0'... First enter UI (User Interface) Diagnostic Mode: Hold down the '0' button for 5 seconds and then press the 'Start' button while still holding the '0' button. The machine will prompt you for a Password. Enter the default Access Number: '6789' and press "Confirm". The colors on the display will be reversed to indicate that you're now in diagnostic mode. Next press the Dual Heat Lamp Assembly (C123 version) www.partsdrop.com 201-387-7776 Page 4 of 5 AC Connector: C123 version "Log In/Out" button on the Control Panel. Select 'System Settings', 'Common' Settings, followed by 'Maintenance / Diagnostics'. Now you will find the main menu includes one choice called "NVM Read / Write" (NVM is Non Volatile Memory)... Now you can enter your "Chain-Link" code (in this case 744-220) and press 'Confirm / Change'. The current value will appear (if the machine is in a fuser fault condition, the value will be set to "1"). Select the "New Value" column and input your new value ('0'). Select "Save" and the new number should now appear in the "Current Value" column. You can turn the power off and back on at this point. The machine will attempt to warm up the fuser again. If the condition which caused the fault in the first place is still happening, the Status Code will return after a few minutes of attempting to warm up. C118 style (C118, M118, M118i) U4-1000 (U4-1) Fuser failure (did not come up to temperature in time)... must be reset from diagnostics (NVM code 50-20 must be reset to '0')*. U4-2000 (U4-2) Fuser over temperature.... Must be reset from diagnostics (NVM code 50-19 must be reset to '0')*. U4-3000 (U4-3) Fuser thermistor circuit is detected as being an open circuit. * C118 style: Resetting Fuser Codes (U4-1 or U4-2): Enter diagnostics (from the powered on state, hold down the '0' button and then press 'Start'. The display will change to opposite colors to show you it's in diagnostics)... Select 'Chain-Func' in the 'CE Setting' screen by using the 'Select' button, followed by 'Enter'. Select "NVRAM R/W". Enter the "Chain" (in this case '50'). Next select "Func" (function) by using the "Select" button. Enter the "function" ('20' if you're clearing a U4-1 code or '19' for clearing a U4-2 code) followed by 'Start'. The current value for that memory code (50-20 or 50-19 in these cases) will appear in the "Read" column (if the machine is in a U4-1 or U4-2 status condition, the value will read as '1'). Change the value by pressing the "Select" button at the "Read" column to switch to "Write". Enter a '0' for the new value, and then press 'Start'. Finally, select "Write NVM". You'll probably be well served by being able to test the lamp and thermistor circuits from the AC Connector so you know what you're looking to replace before you even rip into the fuser. On the C123 & WC-5225 versions, there are slots for 8 pins (2 rows of 4 arranged vertically). Pin 7 is on the upper left and Pin 8 on the upper right is empty. Pins 7 & 1 are one of the two Heat Lamp Circuits. Each Heat Lamp Circuit goes through its respective half of the Heat Lamp Assembly, and then through both thermal fuses to the return wire (pin 7 is the return wire which is common to both heat lamp circuits). Pins 7 & 3 are the other Heat Lamp Circuit. If either Thermal Fuse is blown, neither lamp circuit will conduct. If one circuit measures good and the other measures bad, then the Heat Lamp Assembly must have failed. The Thermistor circuits for the C123 are between Pins 2 & 4 and Pins 5 & 6. If you set your meter to 200K ohms, you can measure the Thermistors... they should measure a high resistance and then if you were to warm up the Thermistor's head, the resistance should begin to drop. These Thermistors are unusual in that the heads are ***** (no yellow kapton tape). www.partsdrop.com 201-387-7776 Page 5 of 5 AC Connector: C118 version The C118 fuser's AC Connector is shaped the same as the C123 version (slots for 8 pins) however there are only 4 pins actually present and they numbered the pins differently for this one. On this one, Pin 2 is in the upper left corner and Pin 1 is in the upper right. On this connector, Pins 1 & 3 form the Heat Lamp Circuit. The Thermistor Circuit is between Pins 2 & 6. Hope this turns out to be valuable information for you. It'd be a shame to replace one of these fusers and then throw out or return the used one without at least inspecting it for the possibility of fixing it for the next customer who needs one. Be a green-tech and fix'em when you can. Happy Repairs everyone! Britt works for The Parts Drop, a company whose primary business is providing parts, supplies and information for Xerox brand copiers, printers and fax machines. You can find more information, including many of Britt's past ENX articles on their website, www.partsdrop.com. If you'd like to read more about Xerox brand office equipment, there's also a complete listing of past articles under contributing writers on the ENX website (www.ENXMAG.com).
Hope this was helpful, good luck!
Nov 01, 2015 | Xerox Office Equipment & Supplies
Error code cof32 & c0070 at bizhub 210 how con i fix it?
Solution for Error code C0F32
1-Turn the machine ON. 2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
Error Code C0070
Solution:
1- Open the front door and bring the bottle out.Now restart the machine.if the code appears then open the toner hopper section.Toner hopper drive motor is not working, Dis mental the hopper section.
Jan 27, 2014 | Toshiba E-Studio167 Copier
E studio 520 code c447
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0." also 447
Jan 17, 2014 | Toshiba Office Equipment & Supplies
Error code c43
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jan 14, 2014 | Toshiba Office Equipment & Supplies
Call for service C 430
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Dec 31, 2013 | Toshiba estudio 255 Copier
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jul 08, 2012 | Toshiba E Studio 207
Minolta bizhub 162 error code 32
In Konica Minolta bizhub 210,162,211,163,182, error code "cof32" means "Automatic toner density control abnormality.
To remove this code or you want to get rid of this problem, simply call your technical service representative to solve this problem.
If you want to remove this code by yourself then please perform these actions attentively.
8-Press YES button.
11-Restart the machine.
Oct 04, 2010 | Konica Minolta bizhub C351 All-In-One...
Code erreur
CAUSE: Adjustment mode 11 is not set to correct value.
SOLUTION: To set Adjustment mode 11 to proper value, perform the following:
1. Enter Tech Rep mode (Counter, Stop, 0, 0, Stop, 0, 1).
2. Press Stop and then Start. AJ- will display.
3. Enter 11 from the keypad.
4. Press Start. Current value will display.
5. Press Clear.
6. Enter a value of 1 from the keypad.
7. Press Start to save the setting.
8. Press Auto Reset to exit Adjustment Mode.
HOPE THAT HELP
Oct 20, 2008 | Konica Minolta DiALTA Di183F Copier
HI, I have a Xerox DC240 that has an error code 093-317 and I need to get a job out tonight. Can any one help.
Try replacing the Xerographic Module, if that doesnt work then the donor roll in the developer housing is bad.
Aug 04, 2008 | Xerox Office Equipment & Supplies
27 people viewed this question
k24674
