Question about Amana Kitchen Ranges
I have an amana electric downdraft range ARDS801 and the digital control module for the oven stopped working? any thoughts?
SOURCE: electric oven range not working
I put my 12 year old self-claening oven on ,afterwards I tried to open the door and it will not open. I set it again to go thru the self- cleaning cycle and noticed the cleaning light was not on during the cycle. The oven is clean and it will work,I can't open the door.
I have cleaned the model number off. I can' seem to find another number,except for the one on the diagram on the back of the stove. There are two different numbers 316063400 and316002052. can you help me?
Posted on Jan 25, 2008
  • 1073 Answers
SOURCE: oven burnout
replace the oven control
Posted on Apr 25, 2008
SOURCE: Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
Posted on Dec 01, 2008
alandc
  • 25 Answers
SOURCE: Don't know if the oven part of range is gas or electric
The model number can usually be found just inside the door or drawer (on the range itself).
All the Jenn-Air convection ovens I'm familiar with are electric even if the cook top is gas.
Posted on Jan 31, 2009
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
Downdraft
I would leave it alone, taking the oven door apart is a real pain in the rear.
May 24, 2017 | Amana ARDS802 Electric Kitchen Range
Oven won't work - digital display/control stopped working
probably a bad control board chekc out www.appliancepartssolutions.com
cheep parts...good luck
Jan 17, 2010 | Kitchen Ranges
Kenmore Classic Grille model 911-469-8813 error F2
Over time I have had to replace the control module at the front of the oven. It gets baked by the oven heat, and unfortunately costs hundreds of dollars to replace. I have avoided further failures by making sure the downdraft exhaust fan is ALWAYS on when the oven is on. This seems to keep it cool enough.
Nov 18, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Range top ignitor stopped working. electronic panel and oven work normally. Any idea what the problem is?
Hi, your spark module,for ignitor could be damage, sometimes they burnt out, or could be broken wires, or corrosion at electrical connection, (terminal) , normally it's spark module, that's faulty or burnt out. let mechanic check. or remove range plug from receptacle, and lift top of range, check all electrical wiring, check all connection for rust (corrosion) clean and retry range, if it didn't work, call mechanic to check spark module. good luck.
Aug 12, 2009 | Amana ACS3350AS Gas Kitchen Range
We have an electric Kenmore Classic Grille w/downdraft vents and the F1 alarm goes off routinely. It is about 16 years old and otherwise works fine.
Your control module is overheating because of the oven just below it. Be sure to use the exhaust fan every time you turn on the oven, which helps to cool the controls.
Jul 14, 2009 | Kenmore Kitchen Ranges
Our Amana AGDS902 Gas Kitchen Range is beeping and flashing an F7 error code. We have found solutions for other Amana ranges online, but none of them seem to be for our exact range type. We can stop the...
AMANA – Range/Stove/Oven Fault Codes
Glass link Electronic Range Control (ERC)
F7=Shorted touch panel Verify glass to adapter board connection good, if so, replace glass panel.
Dec 02, 2017 | Amana AGDS902 Gas Kitchen Range
Amana over
as far as the elementy working, if it glows red, its working. if the unit is preheating within 12-15 min, id say the elements are fine. as far as not maintaining temp, thats strange, if the elemnt turns on the control is sendinding power, and its shuttin off so its stopping power, sounds as if a relay is geting stuck on the control board, strange thngs happen when you short things out like that.
Nov 25, 2008 | Amana ACF4265 Electric Kitchen Range
Replacing oven ignitor in Amana AGDS901WW
The ignitor can be replaced through the oven. When you take it loose, If you cant find the plug just cut the wires and wire nut the wires together with the porcelin wire nuts provided with the ignitor.
Nov 21, 2008 | Kitchen Ranges
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ www.jennair.com or click
https://www.jennair.com/customer_care/contact_us.jsp
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Kitchen Ranges Logo
51 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
