Question about Vacuums
Miele s812 Hoover has a red light on and won't start. I have left for 30 mins etc to let cool but still won't start. No blockages and filters are intact. Any suggestions
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: my miele hoover was
Is this a Miele or a Hoover? What is the model number. Need to know if you want help.
Posted on Mar 13, 2008
  • 25 Answers
SOURCE: Hoover Light on
ALTHOUGH MOST FILTERS SAY WASHABLE THEY DO STILL NEED TO BE REPLACE AS WASHING THEM SHRINKS THE FILTER AND EVENTUALLY CLOSES THE AIRWAYS. WHICH ALSO IF NOT REPLACE WILL OVER HEAT MOTOR IN MACHINE AND CAUSE MOTOR FAILURE.
Posted on Mar 27, 2008
  • 40 Answers
SOURCE: my dyson animal just cuts out mid vacuming ,the
this is a feature so that the motor does not burn up check all tubes
Posted on Apr 23, 2010
  • 14 Answers
SOURCE: The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Posted on Oct 20, 2012
Hoover vacuum shuts off after 10 minuts of use.
If there is no clog the filters may need replaced to improve airflow
Jan 21, 2014 | Hoover Vacuums
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Jun 02, 2011 | Miele Vacuums
Red light came on, and vacuum won't operate. We changed the bag.
you have to make sure the filter is clean and there is no blockage in the hose. try this and hope everything is fine hope this helps. have a good day!
Jan 15, 2011 | Miele Blue Moon Bagged Canister Vacuum
Vacumm when hot will not turn on
My hoover Windtunnel has a 30 minute delay according to the instruction book, if it overheats. Then it resets itself and is ready to go again.
You might check for blockages and check your filters if it is doing this so easily.
Aug 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
Shuts down after 10 min use
I would clean or replace filters on it check the hose to make sure it is not blocked . It sound like it is over heating and making the breaker kick off and after it cools down it resets this is caused by dirty filters or blocked hoses.
Feb 22, 2009 | Hoover U5753-900 WindTunnel Bagless...
Miele white star canister vacuum - won't turn on, but isn't clogged
Miele S251i Plus Bagged Canister Vacuum
Miele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
ALevy
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430
Apr 18, 2008 | Miele S251i Plus Bagged Canister Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Hoover Light on
Mar 27, 2008 | Vacuums
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
