Question about Singer Sewing Machines
How to put needle plate back on Singer 30518? :(
  • Singer Master
  • 9,304 Answers
Manual (pg 9) should be helpful:
SINGER 30215 Instruction Manual Page 9
Posted on Dec 27, 2016
yeroc
  • 397 Answers
SOURCE: needle keeps hitting the plate and breaking
possibly off timing,
Posted on Jan 21, 2008
  • 46 Answers
SOURCE: singer 6038 needle issues
That sounds like the needle is not in straight or is bent.
Posted on Oct 24, 2008
  • 76 Answers
SOURCE: alignment of needle.
make sure the needle is positioned correctly and all the way up into the deedle slot. lower by hand and check again, if still doing so you can tilt the needly slightly befor tightning the screw. lower by hand again an see
Posted on Aug 27, 2009
  • 1788 Answers
SOURCE: I have a Singer 5430c and the needle plate is
They can be bought for around $28 online. Or else call Singer at 1-800-4singer and order from them
Posted on Feb 21, 2011
SOURCE: My Singer 6160's needle is hitting the bobbin plate.
first change the needle--flat side to the back of the machine, make sure the needle is inserted all the way up into the needle holder
make sure it's the correct needle for the machine
if the needle keeps hitting the bobbin plate then the machine may be out of time & would have to be take to a sewing machine shop for retiming.
Posted on May 04, 2012
Can't get the needle plate back on sinner 8780
I have a feeling that your bobbin case is not properly seated, and it's easy to do. If it isn't, it will prevent the needle plate from seating properly.
There is a pointed part on your case at about 5 o'clock that must be resting against a spring in the same position. In addition, take a look at it visually; it is easy to put it in so it is slightly lopsided. (How would I know that?) Make sure all four sides are evenly resting in the bobbin basket (holds the bobbin case). I find it easier to insert it so that it is slightly clockwise of it's proper location, then turn it counterclockwise into place.
Also, download (free) your user's manual from the Singer site; it is pictured on page 80.
Mar 11, 2017 | Singer 8780 Sewing Machine
My needle is hitting the metal plate on a singer cg590 sewing machine. Is there a way to adjust it back into its correct position?
Your needle plate may have been place incorrectly, and it's easy to do. Even the slightest variation can cause the needle to hit it. Try taking the metal plate off and then reseating it -- testing the needle position before you tighten the screws.
Dec 18, 2016 | Singer Sewing Machines
How can I get the needle plate back on my singer Curvy sewing machine model 8763?
If it fit when you took it off, but you're having trouble putting it back on again, chances are you haven't put your bobbin case in correctly--that's why it won't fit. Review the placement of the case in your user's manual; if you can't locate it, you can download one free at the Singer Sewing Machine site.
May 11, 2015 | Singer Sewing Machines
Singer 8734 machine. The needle sounds and looks like it is nipping the front edge of the needle plate. How can I adjust it more back towards center of slot in plate?
See if you can just turn the plate half way around after thread is through it. Could be the wrong plate for that machine. Sounds like machine could have been dropped in the past and knocked it off center if it is the proper plate.
Sep 09, 2014 | Singer Merritt 8734
How do I replace the slide plate on my Singer 416?
Lift the sewing machine pressure foot and make sure the needle is not in the way. Slide the plate under the foot control. Use a flat head screw driver to lift the spring back onto the plate then slide it back.
Jul 21, 2014 | Singer Sewing Machines
May 03, 2012 | Singer Sewing Machines
Just purchased a Singer Inspiration model 4205. Seems as if the feed dogs do not align properly with the holes in the needle plate causing the plate to move up and down as the feed dogs move.
Take it back where you bought and have them show you how to do it. Or, see is you can tighten the needle plate yourself, If, you can't call Singer (1-800-4singer) and find out where the authorized service center is. You should not have to pay anything with it being new. Good luck
Oct 24, 2010 | Singer Sewing Machines
How do you attached the darning plate to sew on buttons?
Raise the needle and presser foot, and position darning plate onto
the needle plate with the two pins on the back inserted to the holes on the needle plate.
Sep 27, 2010 | Singer Confidence 7463 Computerized Sewing...
How do i put the bobbin case back in correctly?
The zigzag setting should not have caused it to jam up unless the tensions were off and the thread was bunching up on the bottomside of the needle plate. If you ever jam or break a needle be sure to replace it with a fresh new needle. A slightly bent needle will cause all kinds of problems.
When putting the bobbin back in make sure you keep a good amount of thread hanging out and manually turn the hand wheel around until the needle make a full rotation. The hook should catch the needle thread and allow you to pull the bobbin thread out through the needle plate.
If you jammed it really good it is possible that the needle and hook timing is out of sync in which case you may need to have it re-timed.
Jun 08, 2009 | Singer 6038 Mechanical Sewing Machine
Singer 6038 needle issues
Oct 13, 2008 | Singer 6038 Mechanical Sewing Machine
Sewing Machines Logo
52 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
