Question about Xerox 5855/APT COPIER PRINTER
Xerox 5855, dc604 IOT Registration value inputting for side A and side B making very complexity! Please help with some tips.
XEROX, DC-12... How do I fix eror 10-398 Please help me...thanks
10-398 Fuser Fan Failure RAP
See Service Manual pages 2-175 (10-398 Fuser Fan Failure RAP) and 6-131 (How to Enter/Exit the UI (IOT) Diagnostics Mode):
XEROX DocuColor12 DC12 Service Manual free download schematics datasheets...
(download parts 01.rar to 09.rar and unpack)
Jun 01, 2015 | Xerox DocuColor 12 Printer
Dc 236 machine has a fault code 010-320. fuser is new, lvps is new and so the small board, i dont know the name of that board... but still 010-320 is there... trying to reset the value of nvm from 2 to 0,...
Well since you know how to enter diagnostics. Go to DC132 and select all copier nvm. Do an all copier nvm initialization, it will correct any default errors in the memory.
You will just have to then reset things like the power save timers and I would also go in and do a dc604 registration adjustment.
Apr 18, 2011 | Xerox DocuColor 3535 Copier
I have Color Registration problem in Xerox m24.I hv checked all 4 Drums.They are free .IBT assembly is free.On PWS Regicon setup, it gives NG.There is Color Regidtration issue.Kindly suggest solution
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Xerox WorkCentre M-24 Color Copier
Xerox Dc12 9-345 error how i solve it please any body help me
The RAP does not lead you to the connector unless you trace the wiring in the BSD. This connector is located on an air duct on the bottom right hand corner of the IOT Drive PWB and acts as a double plug to connect on one side to the connector of the IBT Cleaner Blade home position sensor and the other side to a connector that leads to the IOT Drive PWB. After firmly plugging in the connector, the fault code went away. call 98413 40555
Dec 17, 2010 | Xerox DocuColor 12 Color Copier
Error code 9-342 at start up of Dc 12 xerox printer/copier
change the IOT back side clutch that appear behind the back side of machine which rotates the ITO (black roller in main path of paper) just try with cleaing clutch other wise change it
and remove that IOT back side gear which rotate IOT black roller without that gear u can print
i solve my problem with this methods
Mar 28, 2010 | Xerox DocuColor 12 Printer
How do i shut off the energy saver compliant on xerox c20
For majority of the models Xerox entry in service mode holding [0], include the device.
Entry in service mode
Xerox 5845, 5855
Or include the device with simultaneously pressed button [Interruption] and [2], or on included device to press and hold these buttons more than 2 sec. If device faulty - an entry is realized button [Interruption] and [5], with restriction function (consecutively appearing reports on fault are thrown double keystroke [Foots]).
Hereinafter, the device calls четырQхзначный code of the access: this or 8765 (by default), or the last four numerals counter mines in inverse order (if counter mines shows 01234567 - a code of the input 7654).
Xerox N17, 24/32/40, 3225/4025
There is 3 diagnostic modes:
1 - are checked breakers, sensors and are removed parameters фьюзера, input: (2+6), after "IOT?" press "7" 2 - haves something published the test-sheet "net" in simplex or duplex, input: (2+6), after "IOT?" press "4" 3 - are changed parameters and adjusting the printer (NVRAM), input: (2+6), after "IOT?" press (4+7), "7" immediately release, "4" keep before appearance "3" on дисплее, then release.
XD102...155, XE60...84, XC800...1255
stop auto stop auto
sometimes write as C Density select C Density select (that same)
WC PE 16(e)
we type on keyboard [menu] - [#] - [1934] - [menu], after entering inscription "TECH" will appear in service menu
Oct 12, 2009 | Xerox CopyCentre C20 Black and White...
Xerox DC12 gives error 14-372 please HELP!!
ERROR 14-372 ROS MOTOR FAIL , ITS THE MOTOR THAT ROTATES THE POLYGON OF THE LASER BEAM , ITS LOCATED , BELOW THE SCANNER UNIT AND OVER THE COPY/PRINT CTG. 13R557/13R558 . IT CAN BE ONE OF 3 THINGS THE ROS ASSY. (LASER SCANNER UNIT OR ROS) , IOT DRIVE PWB(THE PC BOARD BELOW THE NVM AND IOT-SYS) OR A PROBLEM ON THE WIRING HARNESS / POWER SUPPLY. WE CAN REPAIR THOSE UNITS OR I CAN PROVIDE YOU THE PART NUMBERS IF YOU WANT TO ORDER THEM NEW FROM XEROX . diesco_cxl@hotmail.com
Mar 23, 2009 | Xerox DocuColor 12 Printer
Xerox DC 12 Error : 9-667
Hy there
Try to replace the print drum unit.
this is the information of the error code
9-667 VH/VM Out Of Range RAP
Description
The selected LD value was out of range.
Initial Actions
·Refer to BSD 9.1 and BSD 9.15 for the following procedure.
·Clean the ESV Sensor.
· Check that the P/J141 on the ESV Sensor, and PJ 422A on the IOT Drive PWB are firmly connected.
Procedure
Perform the following in the order listed.
·Go to the IQ 38 Charge Corotron HVPS RAP and check the Charge Corotron HVPS for proper operation.
·Ensure that the Charge Corotron Wire and Grid are in good condition.
·Go to FLAG 6 and FLAG 7 on BSD 9.1. Check the wires for an open circuit or a short circuit. If the wires are good, replace the ESV Sensor ( PL 5.1 ). If the problem continues, replace the IOT Drive PWB ( PL 9.2 ).
·Replace the Drum CRU ( Machine Consumables).
Mar 08, 2008 | Xerox DocuColor 12 Printer
Xerox 5855/APT COPIER PRINTER Logo
62 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
