Question about Amazon Fire TV Stick
How do I get a replacement remote for my fire stick
Lost my fire stick remote. can my phone be used as a remote?
apparently it can!
Amazon Fire TV (Stick): How to Use Your Phone as Remote Control ...
streaming-blog.com/amazon-fire-tv-stick-how-to-use-your-phone-as-remote/
  1. Cached
  2. Similar
Sep 13, 2015 - Make sure that the Phone with App and the Fire TV are connected to the same Wi-Fi network. ... Enter this code on your Phone. Done. You can see all of the remote apps that are paired with your Amazon Fire TV device under "Settings > Controllers and Bluetooth Devices > Fire TV Remotes".
Amazon.com Help: Download and Pair the Fire TV Remote App
https://www.amazon.com/gp/help/customer/display.html?nodeId=201640980
  1. Cached
  2. Similar
Fire tablets (with a microphone); Amazon Fire phone; Android 4.0 or higher ... Note: The Fire TV Remote App is compatible with Amazon Fire TV devices with ... settings on your router, you need to enable Multicast support to use the app. If you're not sure how to manage these settings, your router manufacturer will be in the ... Lost my fire stick remote can my phone be used as remote Google Search
Dec 31, 2016 | Televison & Video
Connecting fire stick to tv. i am a prime member with amazon
Setting up Amazon Fire TV Stick hardware
  1. Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
  2. Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
  3. Next, turn on your TV and switch the input to the right HDMI port
  4. You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
  5. Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
  6. Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
  7. If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
  8. Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
  9. From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
Now you've set your Fire TV Stick up, here's how to install Kodi on it.
How to set up your Amazon Fire TV Stick
Dec 23, 2016 | Televison & Video
Cannot open remote battery compartment
Amazon.com: Customer Discussions: battery installation for remote ...
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Jun 11, 2014 - As strange as it may seem to everyone else I cannot figure out how toopen the remote for my Kindle HD TV to put the batteries in.
Amazon Fire TV Stick: How To Open The Remote's Battery ...
? 0:44
https://www.youtube.com/watch?v=F__fFr7nZOE
Nov 30, 2014 - Uploaded by The App Store Chronicle
Here's how to put the batteries into the remote for the new Amazon Fire TV: ... Amazon Fire TV Stick: How To Open TheRemote's Battery Door.
Open Amazon Fire TV 2015 remote battery compartment ...
? 2:35
https://www.youtube.com/watch?v=FyTHjZu3L6M
Oct 6, 2015 - Uploaded by sfsilicon
I am not responsible for any damage to your remote. Proceed with caution. This video shows you how to open ...
Jan 12, 2016 | Samsung TV Remote Control
Went to settings and accidently turned off blue tooth wi fi now my fire stic remote will not respond air won'' scroll up or down and I can't get back to settings
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
Apr 03, 2015 | Amazon Fire TV Stick
When I went to settings I accidently turned off blue tooth wi fi now remote will not allow me to do anything It will not scroll off home screen
Accidentally turned off my blue tooth on my fire stick now my remote will not work
1,Before you pair an Amazon Fire TV Remote or Amazon Fire TV Voice Remote, verify that the remote is compatible with Amazon Fire TV, is within range, and has the required batteries installed. 1. From the Home screen, select Settings, and then select Controllers. 2. Select Amazon Fire TV Remotes, and then select Add New Remote. 3. Press and hold the Home button on your remote for five seconds. Fire TV Stick searches for the wireless signal of the remote. After the remote or game controller is discovered, select it from the list of discovered devices using your already paired, existing remote or game controller.
Apr 02, 2015 | Amazon Fire TV Stick
Accidently turned off blue tooth
Amazon Fire TV Stick Logo
29 people viewed this question
Top Amazon Televison & Video Experts
Andrew Taylor
Andrew Taylor
bigdawg7299
ray gallant
Are you an Amazon Televison and Video Expert? Answer questions, earn points and help others
