Looking for a recall on cabrio top loading washer lid has a crack and doesn't close properly glass lid is not cracked.
Sn is C12170181, model # WTW 7800XL2
huuum
  • 750 Answers
SOURCE: crack on glass top stove
Hello
Welcome to Fixya
My name is Huum,
You can replace the smooth top !.
But I will tell you not to spend more than half the price of a new stove. How old is the stove and what's the model number!
Waiting your response.
Please remember to leave a rating before you leave
Posted on Dec 11, 2008
philbran
  • 242 Answers
SOURCE: Glass cook top has cracked ...
They are expensive but not very hard to change if your carefull. They are about 300-400 on the norm , You may be able to get a new oven on sale for that much ,its up to you. Check with sears parts first. good luck
Posted on Dec 30, 2008
appldoctom
  • 311 Answers
SOURCE: Broken glass top range
im sorry about that.i have replace many of those running around 400$,that a lot of money.i have see glass top stoves on sale 4 that much.and i think they all are about the same as quilty goes.God bless,tom
Posted on Jan 02, 2009
SOURCE: F1 error code on cabrio washer
CALL 18002531301 AND TELL THEM YOU HAVE THE F 1 CODE PROBLEM. THEY HAVEN'T CALLED THIS A RECALL, BUT THEY ARE CALLING IT A CUSTOMER AWARENESS PROBLEM.
WHIRLPOOL IS SENDING TECHNICIANS OUT NEXT DAY FREE OF CHARGE.
T W
Posted on Feb 04, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
I have a Whirlpool Cbrio top load washer. it won't start it's cycle. Once it senses the load, the lock lid light flashes and it does nothing. can this be fixed?
I would say that the lock has failed. Either the lock itself or maybe the pin or latch that fits into it when you close the door may have cracked / broken. If the machine thinks the door / lid is still open, it wont let you start it.
Jan 03, 2015 | Whirlpool Washing Machines
Has anyone had the glass top just popped off and is this a common problem?
Yes you would have to open the top cover and tilt it back to be able to get to the lid holder that breaks. Holders are at each end of lid. Labor will cost you if you call a repair company to replace those little weak holders. You may be able to do it your self. Good luck.
Dec 11, 2014 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool washer wtw 6500ww1 does not work.
the micro switch may need to be changed ..this is near the lid area
May 23, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire washer recall
You should contact the company. My washer had a part recalled, which was causing it to throw error codes our all the time. Luckily it was still within the warranty so a replacement part was sent right away. Good luck
Jan 03, 2014 | Washing Machines
Glass separating from lid
Replace with steel lid. Parts below but first I have to get my 2 cents in!
I bought the replacement glass lid and it broke within the first week. Terrible design! They are using double sided tape to hold the glass to the hinge. There is too much spring tension to be held with tape. Way to go whirlpool engineers. I'm just a welder with 1 year of school and I figured that out? Hmmmm?
Steel lid retro fit
Whirlpool will tell you it can't be done. However I did and it works and looks perfectly.
here's the parts you need
All from a WTW8200 series washer
Part prices from Sears. I'm sure you can find them cheaper elsewhere if you look. I bought from sears to utilize the return policy while figuring out what parts to get. Thanks Sears! Give them the business if you can!!
1 pc 8572026 Steel lid $40.90
2 pcs 8563964 hinge $6.99 ea (hinge from the glass lid are different and the screw holes won't line up)
4 pcs W10119828 $3.99 ea (could probably get from the hardware store for half the cost.
Solution 2:
buy a replacement glass lid from whirlpool and send them your broken original glass lid and get a refund for the one you just bought. Repeat as needed until they figure out they need to produce a quality product.
Keep your whites...White and your colors bright America!!!
Nov 20, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
A heavy object was dropped on the lid of our whirlpool cabrio washing machine, and it is cracked throughout, like a windshield, though still encased and not broken through to the outer surfaces of the lid....
you can buy a new replacement lid from applianceparts pro.com part number AP4360341 for $159.50, if you do not have the money you could patch the crack from getting worse by covering the cracked surface with clear 2 inch wide carton tape so it would not be that noticeable of if you do not care of the appreance you could use duct tape, good luck mike
Nov 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Cabrio top load washer, Model WTW6300SWD and it makes a terrible noise only when in spin cycle
you have a cracked motor housing at the bottom of the machine. lay the machine on its back, remove centre bolt with allen wrench, pull off rotor. Remove four bolts holding the windings. Lift off windings, unplug wires and speed sensor. Inspect plastic housing with windings. You will see cracks. There's your problem
Oct 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
T W
Feb 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer displays message of dl when trying to start washer
Hello bculwil Welcome
“dL” (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid
keeping it from closing. Press PAUSE/CANCEL once to clear
the code.
Or the lid lock sensor is faulty and needs to be diagnosed and replaced
Please remember to leave a solved rating before signing out.
Thank You Huum
Dec 21, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
