Question about Miscellaneous
How would you solve for x? - Miscellaneous
  • kakima Dec 27, 2016
    Hi blondene smith, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Solve what for x?
Can the scientific calculator solve all maths questions
It depends on your application? I had one on a construction site and it was wonderful. Look up the particular model and see if it applies to you Obiri. Thank you and leave some feedback for I'm a newbie!
Jul 13, 2016 | Scientific Calculator Office Equipment &...
When i ask to solve it wont let me
If it is not accessible (grayed out) then the context is inappropriate. The reason could be the misuse of the verb solve. A lot of people confuse calculate with solve.
If you care to tell us what you were trying to do, exactly, maybe we can help.
Nov 12, 2013 | Texas Instruments TI-Nspire Graphic...
Need instruction how to solve ploynomials/trinomials
You can do it two ways.
Open the graph utility, enter a function y1= expression(x) where expression(x) is the polynomial. Graph the function y1(x). Play with the window dimensions to display the interesting part of the graph. You can then see if there are any zeros (roots).
While the graph is displayed, press SHIFT F5 (G-Solv). Press F1:Root to look for a root. Read the value of the root at the bottom of the screen (to the left).
Solve utility
Open the QEquation solver, select F2:polynomial, or F3: solver.
The polynomial solve can solve polynomial equations up to degree 6.
The solve solve polynomial and any other type of non algebraic equations
Mar 16, 2012 | Casio CFX 9850GA Plus Calculator
How to program the calculator TI-nspire to solve the quadratic formula
Whay would you want to go through the hassle of writing a program to solve to solve a quadratic equation`The calculator has two buit-in command to do just that. It has Solve and cSolve (for complex solutions).
Open a calculator sheet, and on the command line, type in solve(ax^2+bx+c=0, x), press ENTER and wait for the solutions
May 10, 2011 | Texas Instruments TI-Nspire Graphic...
What are the tips of sodoku
Sudoku Tips: Learn How To Solve Sudoku Puzzles Illustrative Sudoku tips teach you how to solve difficult Sudoku puzzles and games. Learn techniques that will make you a pro. Sudoku Tips-Advanced Sudoku Solving Tips These amazing sudoku tips and tricks will show you how to solve sudoku puzzles faster than ever before. Killer Sudoku Tips and Strategies There are three basic methods used to solving killer sudoku puzzles. The first is to use the strategies for solving regular sudoku puzzles.
These sites have some great Sudoku Tips
Mar 18, 2011 | Excalibur Electronic New York Times Sudoku
Solving a linear equation from TI 83
You have two ways to solve an equation (not just linear) in the TI83Plus
  1. The solve( command the syntax of which is solve( expr, var,guess, {lower_limit, upper_limit}). Here expr is the expression (without =0), var is the variable you solve for, guess is you estimate of the solution, lower_limit and upper_limit are the bounds of the domain where you are looking for a solution. Of course your guess must be between theses limits.
  2. The Interactive Solver.
The solve( command
  • The solve command is accessed through the catalog of commands [2nd][0] (CATALOG).
  • Press [LN] (S) to let the cursor jump to the first command that starts with s.
  • Scroll down to reach the solve( command.
  • Select it and press [ENTER]. The command echoes on main screen.
  • Enter the different arguments: expr, var, guess, etc.
  • Close the right parenthesis and press [ENTER].
  • Wait for the solution to be displayed.
The interactive solver
Press [MATH][0:Solver]. You see what is on the first picture (I entered K-0.5*V^2). Press [ENTER]. You see what is on the right picture.
In the interactive solver you enter a value for all the parameters, constants, for all, save the entity you are solving for, here V. So you must clear the 0 to the right of the = sign after the V. when finished you press [ALPHA][ENTER] (SOLVE).
Here is what I get for the small exemple I chose.
Left -rt=0 shows that the root was found to within the calculator's tolerance.
Hope it helps.
Thank you for using FixYa.
Nov 19, 2009 | Texas Instruments TI-30XA Calculator
Solve comlex equation
I do not understand what you mean by solve complex equations, but if you want to manipulate complex numbers here are the tools you need to enter your complex numbers. Operations and function evaluations do not need special symbols.
b4c488c.jpg Hope it helps.
Oct 31, 2008 | Casio FX-9860G Graphic Calculator
Solving multiple non-linear equations
Type it like this: solve( equation1 and equation2 and moreEquations, {list of variables to solve for})
Put all of your equations right after the opening parenthesis separated by the word and, then a comma, then within curly braces each variable you want to solve for each separated by a comma.
Apr 26, 2008 | Texas Instruments TI-89 Calculator
How do i solve for x on my ti-89?
First to solve a problem, write it like this
Second, for inverse, do this (note the "y=" part)
solve(y=3x^2 -2x+1,x)
The calculator will rewrite the formula as x = ...
Oct 23, 2007 | Texas Instruments TI-89 Calculator
Miscellaneous Logo
15 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
