Question about Magic Audio Players & Recorders
The diamond magic sing Et19kv has been delay the sound and the screen was black and white
SOURCE: magic (karaoke) mic sound delay problem when connected to HDTV
Ok..I found a workable solution. Essentially using my HDTV only for the lyrics(video output) and using a RCA to stereo mini plug cable to send the sound output to my amplifier that has a analog stereo input. Works like magic. No delay. It went from being unusable to WOW!
Posted on Aug 28, 2009
SOURCE: 2-second delay with Magic Sing
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
Posted on Sep 17, 2009
SOURCE: Magic Sing EG-18000 Microphone Delay
but how do the other competing products work ok on Plasma tv, Why does the magic sing have a problem?
Posted on Jan 10, 2010
criss_michae
  • 63 Answers
SOURCE: magic sing ET18K delay problem
The instruction manual should have a calibration section. If not, you can probably find the instructions at the manufacturer's website.
Hope that helps!
Posted on Feb 11, 2011
moska_1982
  • 15 Answers
SOURCE: interference problem on my wireless magic sing, i
Hi
If you know anything about RF stages of your unit you may be able to adjust IF transformer next to the crystal and do the same little adjustment in the receiving stages of the receiver.
Posted on Oct 01, 2012
Does the Magic Sing ET19KV require a special "3.5mm to 3 RCA" cable? How to get it to work with aftermarket "3.5mm to 3 RCA" cable? "3.5mm to video only" works.
Hi
firstly check that the 3.5mm plug has the same number of contacts as the original there should be 4 segments
The three rca plugs are coloured red white and yellow
white is left audio,red is right audio and yellow is video
usually composite video.
some tv,s have an rca input some have two
and some have rca outputs
the sockets on the tv are also coloured to match the plugs
please check that the plugs are inserted into the correct
coloured input sockets
I would plug in the 3.5mm plug then the yellow untill i get video,once i have video i would connect the red plug untill i have sound,same with the white
Dec 03, 2017 | Televison & Video
Magic Sing ET19KV On connecting Magic Sing through RCA Cable, get buzz sound on my speakers Have chked on diff TV's and replaced the RCA cable.The Video is clear, but getting buzz on speaker
Most buzzes are caused by one of two things: "DIRTY" power or a lifted\non-existent ground. Allow me to explain;
"DIRTY" power is just that. It comes in and carries a lot of static with it. Most newer systems have filters built in on the power side of the main board. The fix? Try running your Magic Sing from a wall socket that doesn't have anything else pulling from that particular circuit. You should also invest in a GOOD power strip and not one that cost $5-$10 bucks. All these are good for is getting power to multiple products simultaneously, AND they don't have the resistors and filters to give you a constant 120v AC.
Monster Cable Co. was a very sought after item up to the point to where Radio Shack no longer carried their products.
If you really want to get your money's worth out of the instruments you buy, don't slack on the power strip. This will be the most costly mistake ANYONE can make.
Here is an article that explains what I did and gives you answers on how to fix this issue.
Hope this helps. Dirty Power What It Is and Why You Need to Clean It Up Schneider Electric...
Aug 12, 2017 | EnterTech Magic Sing Et19k Et-19k Et19kv...
HOw do I connect my Magic Sing to the Samsung wireless Soundbar and my Sharp LED HDTV to avoid 2 sec delay?
Which version did you buy? the latest version is ET23KH. I am on the waiting list at love2karaoke because the hindi version has not been released yet.
I used to have the ET19KV and my friend has ET18K, which are older models 2011 and 2009 respectively.
ET23KH supports HDMI connection with the cables included so that problem u should not have.
Which model do u got?
Dec 18, 2012 | Magic Sing Along Consumer Microphone
DELAYED AUDIO USING MAGIC SING ET23KM
Where did u buy this from? I have not heard of this model yet but I might be able to help.
Nov 08, 2012 | Magic Sing Along Consumer Microphone
Magic Sing ET-18k output delay
The delay is introduced by your high end HDTV. To alleviate this problem, connect the music part carried by the red and white wires a separate analog sound system.
May 15, 2010 | Magic Singalong Karaoke Consumer...
Aug 20, 2009 | Magic Sing Along Consumer Microphone
Magic (karaoke) mic sound delay problem when connected to HDTV
Jun 14, 2008 | Magic Sing Along Consumer Microphone
Mar 16, 2008 | Magic Sing Along Consumer Microphone
49 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
conquer111
Level 1 Expert
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
