Question about Saeco Coffee Makers & Espresso Machines
I have Saeco Odea Giro Plus (4 years now) and the pucks in the drawer became very wet all of a sudden (it's not forming any shape), and espresso tastes very watery. Does anyone know how to fix it?
  • 1089 Answers
SOURCE: Waret Pucks
Hi There are 2 problems that can cause a watery puck. 1. Like EsWorld said, If the grinds is too coarse it leaves room for more water and you get a watery puck. 2. But if your grind is like a grain of salt, the you don't have enough coffee going into the brew unit, and this leaves room for extra water. To fix this, there is a lever on the top center of the door. The lever will increase the dose if pushed towards the back. DON'T push the lever to the full back position. This could cause an over charge, which could cause the brew unit to dump the ground coffee with out making because it could not compress the charge, or it could break the brew drive. 1 click back from the full plus is fine and will give a great shot.
Posted on Jun 04, 2009
  • 81 Answers
SOURCE: New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Posted on Jan 21, 2010
  • 81 Answers
SOURCE: Red light is on (looks like an M) and I don't know why??
It means time to descale , however if you want to get rid of it, just press and hold the water button until it goes off.
To descale..fill the container with descaler and let water goes through the system by openning the valve and catch the descaler with a container. Turn off the machine a few minutes and start the process all over again for 1/2 hr, and finally with water to wash the system.(donot want to heat up the descaler too much)
Posted on Jun 09, 2010
SOURCE: Hi, I have a saeco odea giro plus that has just
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Posted on Oct 10, 2012
SOURCE: How can i reset de saeco odea giro plus ?
Turn off the machine. Open the side panel, remove the dreg tray, remove the dreg box and remove the brew group. reinsert the dreg box without the tray. Using a flat head screw driver insert lightly into the slot where the brew group sensor is until you hear a click. Hold the screw driver in place while closing the side door and turning it on. The head will re-align. Now open the side panel, remove the box and reassemble. Leave the machine off for an hour and turn back on. That should reset it.
Posted on Mar 11, 2013
Grinder problem
try to check the brew group
Jun 18, 2012 | Saeco Odea Giro Plus Coffee Maker
How do I descale my Saeco Odea Giro Plus Coffee Maker
do you have a video on how to operate this machine
Nov 27, 2011 | Saeco Odea Giro Plus Coffee Maker
How do I prime the saeco odea giro plus?
Hi, open the steam/hotwater outlet while its heating. It allows the air to release and water to fill the void. Dazza. Enjoy your coffee
Oct 23, 2011 | Saeco Odea Giro Plus Coffee Maker
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
Jan 06, 2010 | Saeco Odea Giro Plus Coffee Maker
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro tuning on/off
turn off each night and when going away! the machine will last longer.. without repair! also saves money (they use alot of power!
Dec 09, 2008 | Saeco Odea Giro Plus Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
