Question about Home
Installation video of B37 Flush valve would be helpful, where can i obtain?
Flush tank leakage
hey,
If it is new, I assume a small stone or left-over is stuck where the seal is, You need to disassemble the valve, clean it and re assemble.
If it is an old installation, it is possible that the seal is worn and need to be replaced.
Look at this guide that might help you. though it is not the exact model, principle is the same.
Have fun
Avi
Grohe GD2 flush system concealed cistern repair fix and disassembly...
May 24, 2013 | Grohe 38 749 001 Rapid SL Flushing System...
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
I love my Cadet toilet. It looks perfect in my bathroom, but the flush isn't as powerful as I thought it would be. Can someone help me?
The flapper is secured with a rubber band. The rubber band must be removed from the flapper for the toilet to function properly. Please check the flush valve prior to installation and if the rubber band is present, simply cut it and remove it.
Jan 27, 2011 | American Standard Cadet 3 Right Height...
I have a Duravit Starck 2 toilet cistern which is approximately 5 yrs old, recently water from the cistern runs constantly into the bowl. I have renewed the flush value without any success. I would...
Did you replace the flush valve or the flapper?
There must either be a problem with the seal between the two surfaces of the flapper and flush valve or the flapper is being prevented by the flush system to returning to make a seal against the flush valve after the water completes draining during the flush cycle or more likely water is draining through the overflow tube.
Make sure the sealing surfaces are clean and not damaged.
Make sure the flapper is not being interfered with and is able to return to the closed position to make a complete seal against the flush valve.
Check adjustment of the water fill level to make sure the water is not filling above the water overflow. If the inlet valve does not shut-off when the level is adjusted to the proper level the water inlet valve may need replacing.
The following videos may prove helpful.
Dec 22, 2010 | Home
Tapping noise at 3000 rpm on 4.0 litre 1996 ford explorer.Valves are quiet at idle and up to 3000 rpm
have the oil pressure checked. i believe the specification is 40-60 psi at 2000 rpm. sticking valves and lifters can cause valve train noise. weak vavle springs can also be the problem. try running an engine cleaner such as gunk motor flush at your next oil change. follow directions specifically. obtain a product designed to aid in cleaning deposits on valves.
Jun 01, 2010 | 1996 Ford Explorer
I installed a Moen Adler faucet. It will not shut
You may just have a piece of sediment lodged in the cartridge from when the water was shut off during installation. Carefully remove the cartridge and turn the water on to flush out any obstructions. re install the cartridge and test.
Feb 18, 2010 | Moen & One Handle Tub & Shower Faucet
What space is required behind range to allow for gas hook up
If you follow the installation directions for this range, you should be able to have zero clearance from the wall IF the electric outlet and gas shut off valves are located in the proper places. The gas valve should not protrude more than 2" from the back wall in order to have the stove sit flush against the back wall, when pushed all the way in.
Here's a copy of the installation instructions from Jenn-Air for your stove. Please see page 10 for their recommended location of the electric outlet and gas supply line and shut off valve
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208101P629-60.pdf
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kohler Cimmaron Toilet Flush
You might want to check the flush cylinder, to see if it has water in it. It has to be water free, that way the air in it, lets it go down easier, during fill up.
Jan 23, 2009 | Kohler Cimarron 2-PC Elongated Toilet with...
Home Logo
55 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
