Question about Vacuums
Cordless vac Vac motor pulses when button pulled on a fulled charged. Less than one year old. SV 03
headstrong
  • 233 Answers
SOURCE: cordless vac won't hold a charge
Like all batteries after a while they go bad/will not hold a charge. especially the kind that is always plugged in/always charging, like electric shavers, cordless vac and so on.
get a new battery
thanks for rating
Posted on Jan 14, 2008
  • 120 Answers
SOURCE: burned out motor on QPL625 Shop Vac
well if you can find the motor ( find a place that deals with the manufacturer directly so you get the right part ) and it isnt to expensive, most shop vacs are pretty easy, if you look under the top you should see about four screws, remove those and the top should come of giving you access to the motor, take note about the wires and what they hook up to. i doubt the motor is fastend down other than that.
Posted on Sep 18, 2008
MrScary66613
  • 1990 Answers
SOURCE: Craftman Canister Wet/Dry vac- Motor just stopped working
It is Repairable But, The parts will cost almost as much as a New Vac. I would just get a New Vac and save the Hastle and the Cash. The choice is all yours Though. Please Rate My Response! Thanks!
Posted on Feb 07, 2009
  • 18 Answers
SOURCE: Hoover Freejet Cyclonic will not charge after battery run flat
basically, the batterie pack is shot and it will cost about £40.00 ish to replace. as you said, a right rip off
Posted on Sep 15, 2009
Richie_asg1
  • 1036 Answers
SOURCE: old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Posted on Sep 22, 2009
I just received my cordless dyson vac. i charged it for 3 hrs and started vac. it lasted 10 mim . how long should the power last? I'm very very frustrated.
Although your Dyson vac is new, the battery may not be and it is failing to charge. Another possibility is that the charger is defective
Nov 18, 2016 | Dyson Vacuums
Miele 228 power brush stopped working
Does the motor on the Head Run but the Brush does not turn... change the Belt, the brush head is operated by a rubber belt this is so it has no direct drive so if you suck up something then you ruin a belt and not the motor. Besides you should change the belt as per MFG directions. I change ours at Least 2 times a year and if you do.. say Pull in a Rug corner and it smells like Burnt Rubber? ... you just decreased your life of the Belt.... you'd be surprised on how well a New Belt helps your Vac pick up things. Change the bag often too, do not wait till it can pickup no more. The bag is Not meant to be FULL to be changed, besides it keeps Mites in the trash where they belong and not a breading ground in your closet... If you have a bag-less clean and rinse (All Filters Every Vac has a Filter even the Bag-Less ones) and let dry after a day of vacuuming follow MFG directions, Hope this helps.
Jul 22, 2014 | Miele SEB 228 Powerbrush
Vac will not come on?
If it's less than 30 days old take it back and go get a good vac from a vac store. If it's 9 months to a year old, it's probably got a bad motor. It was made in China, and built to fail in one year. Buy a Riccar. Made in America and built to last for 20 years
Apr 30, 2010 | Hoover U8315960 Bagged Upright Vacuum
Charge doesn't last 2 minutes and what it starts with is weak. the vacuum is 7 years old.
batteries do have a life. its probably reached its end, sad to say. if the battery can be removed, i would attempt to find a replacement.
Apr 26, 2010 | Dirt Devil Royal Cordless Rechargeable...
Very loud motor
If you are sure the noise is comming from the motor, either the fan on the motor is damaged and now not balanced or the bearings are bad. If it's a year old or less you can get it repaired under the guarantee at a Eureka Nationwide service center. Proof of purchase is needed. If it's over a year old it probably won't be worth fixing as the motor and labor charge may equal the price you paid for the vac.
Noise can also come from the spinning brush. If you disconnect the belt and turn on the vac and the noise is still there it's the motor. If its gone it's the brush roll.
Oct 08, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Our wet/dry vac is losing power, could it be the battery (not taking charge) or the motor??
It is cordless / rechargeable ?
The batteries are good for around a year or so..
Please dont forget to rate well ;o)
Aug 11, 2009 | Vacuums
Central Vac does not shut off
Sounds like the relay that is in the central vac unit is stuck to the ON position. When you plug it back in..does it start right up ? If so.. You should be able to disconnect all the receptacle feeds to the central vac unit at the central vac unit to determine which one ( if any) is calling for the vac to stay on.. if none are.. then it is internal to the vac and may be a stuck relay... Hope that gives you some ideas to check...
Aug 28, 2008 | Vacuums
Shop Vac just stopped
If you remove the motor, you will see that the wires that go from the switch to the brushes. On one side there is one wire connected directly to the brush. On the other side the wire goes to a plastic plug with a second wire going to the brush. This is probably where the problem is. This is a fusible link and it has most likely melted creating an open in the circuit. I put a piece of solder where the link was and the motor ran BUT the brushed arced like a sparkler. Upon further examination the brushes were crumbling apart. I have been unable to find replacement brushes.
This machine has a five year warranty. I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor.
I had a Shop Vac QL50EIC which had exactly the same problem but the warranty was expired so that I had to buy another motor for about $50.
Mar 08, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Cordless vac won't hold a charge
get a new battery
thanks for rating
Jan 14, 2008 | Vacuums
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
